View Full Version : LT1 Based Engine Tech
- Where is the best place to buy intake elbow?
- lakewood d/s loop, who's using one
- Oil Pressure
- Won't turn over... 94Z
- head install guide
- gmmg on lt1
- Steering wheel isnt 100% strait
- My tranny may be dying...
- Mufflex 3.5" or 4"??????
- How do the A pillar covers come out?
- throwout bearing is making noise
- No Tach
- High Beams
- o2 sims
- CAM, can i do it or should i pay
- What does a closed EGR valve look like?
- Sucking noise + hesitation
- Rear end Lube
- Exhaust Cut out
- CO2 Purge?
- One green wire left by the MAF Whats it for ? Shoebox ?
- any websites with guides on replacing the posi?
- Water Wetter?
- Do i need 4.10s for the xe 230/236 cam??
- what size bolts for engine stand?
- need some help on new tranny, stall and old mount.
- Which Cars can I take
- should i keep my LT1???
- worth gutting cats on a dual cat car?
- Bad Opti Symptoms?
- where can I get a 93 single cat off road pipe?
- How to make DFI work in harmony with factory gauges and accessories
- replacement filters slp
- RR size question
- Anyone use Yokohama AVS ES100 tires?
- "Jerking" on acceleration...
- Stock Oil Pan Depth
- Car is running like crap....any opinions.....?
- Difference in quality for Brake Rotors?
- Part number for OEM rear brake pads please?
- What is the fastest anyone here has gone with a stock A4?
- color me confused
- Throttle body bypass
- Transmission help
- Vig 2800
- What is the widest tire for a stock 16" wheel?
- AHH! Exaust Leak !!!
- Anyone have base shift points for 3.42s?
- Can I take out a LS1 Yet???
- how could i tell if this cam is a LT4 hot cam??
- Lloyds phone #
- Stock 6speed Owners & 1/4 Times
- Misfire diagnosis, ECM logs inside
- new to the group, quick ?
- What is a speed sensor?
- Questions about MAF upgrade.
- Correct Fuel Pressure
- McLeod street twin users: does your t/o bearing?
- What advantage will I have with a 2500 stall t.c.?
- Whats going my opti or my clutch???
- Broken exhaust manifold studs
- Why Doesn't My Keyless Remote Work??
- New or rebuild
- HO intercooled w/ P600B / 8psi. 2 core intercooler
- Stall Converter Questions
- 384 rwhp 354 rwtq
- Cant drop the tank for new Walbro
- Speedo cluster swap question
- Oil Pressure Sensor Plug ?
- Oil pressure gauge "bouncing" a little. Anything wrong?
- Cleaning Coated headers
- What would you pay for this?
- T56 removal, installation (with new clutch)
- Ignition woes
- heres a good article on optispark
- Holley HP Annihilator Ignition System any good?
- plug wires
- Just had my first dyno run....NOT GOOD!
- Preps for Starting an engine that hasnt run since at least 1998 ?
- I need a timing set
- Have LT4 conversion, but what NEXT???
- part question
- hesitation? turns off? PLEASE HELP
- T-top leak
- Pace Setters Short Headers
- overheating! friend in need of help
- Options?
- MAC Headers
- Stock Exhaust size
- what would happen if i plugged the wrong wire into the wrong injector?
- Eibach Vs. 1LE springs
- Confirm P/N #'s on LT1-T56 Bellhousing
- Koni DA's
- Difference in these AC delco oil filters??
- hp question relating to time slip
- quick magnaflow question...take a look
- security light on when ignition is off???
- Engine Work
- I can feel my hesitation in my gas pedal..
- need help picking out torque converter
- Mr Gasket Copper Seal Gasket is Part # 7154
- The smell of gas inside my car
- hood heat shield replacement
- Best Shift Points for A4 2.73?
- Lloyd Elliot does it again! flow #s inside
- Help, is this to much airflow at one time?
- help me build my engine
- New Clutch
- nitrous backfire
- Wheel weight question
- which exaust to buy?
- serpentine trick
- Coolant hoses going, all within a few weeks.
- BeCool Radiator
- Catco cat ...is 14" long enough ?
- Worst Dyno Day Ever!!!
- Can I replace my catalytic with a dynomax bullet muffler??
- Mufflex, Install Photos ?
- Alternator output only 14.1 volts
- coil wires and abs light
- plug wires
- all those with jethot lt's...........question
- Bad o2 sensor?
- Possible dying opti Pt. II
- What does this wire go to?
- EGR "valve" removal best tool and what to do with the vacuum hose
- worth it to get emmisions with LTs??
- 12 bolt ABS TC question
- EGR blockoff
- what am I missing?
- Such thing as an LT1 girdle?
- how long does jet-hot coating last
- header bolts come loose
- People with SLP headers (93-95) inside
- How far off is the stock tach?
- Cam selection help please.
- Ok my 12 bolt is pretty damn quiet...will it get louder?
- question about moving car
- what lifters to use with hotcam
- burnt wire?
- Need gaskets
- Converting Victor Sportsman Intake
- looking for an upper control arm bushing
- RPM stumble
- slugish when warm
- Need Hep Asap Please
- need help!
- track times
- I gutted a the cat too....
- homemade 8.8 is in the car. Total cost=$125.
- Dyno'ed my car last night
- doing intake leak
- Southside subframe connecters
- Dynoed my car today
- what temperature do the outside of headers reach?
- Should I do my cam install myself or pay someone???
- ANOTHER exhaust Question Which one..?
- how bad is header "slip-in primary" leak????
- car wants to stall while cruising in neutral!!!
- Wiring CSI, need people w/ electrical knowledge PLEASE
- Please Tell Me Shift Point ! I Have To Go
- How to decode Lucas Fuel Injectors?
- Shift Point For Stock Motor
- A/C Fixed (for now)
- Fixed my car. Thoughts on 306 with stock TC and heads
- Coolant Light- I'm stumped!
- Getting discouraged w/IM fix...need a pep talk
- Hotcam-cc305-224/230-cc306?
- help! goin to the track today
- Flapper doors on the fans, what do they do?
- Can windshield wipersarms be taken off and readjusted/mine don't seem right?
- Wild data log of 1/4 mile run
- Gear Drive
- Need help finding a !CAGS diagram
- lightweight k-member, more clearance with AS&M headers?
- Help! A/C service...
- Heddman X-pipe
- help power window problem!!!
- Tubbing out the rear?
- Loud Thumpin.....tranny????????
- Fixed creaking rear suspension(I think)
- Wierd rumble/vibration/resonance at idle
- XE 236/242 dyno #'s
- HELP!!!!!!!Electric Locks problem HELP!!!!!!!
- PCMforLess question.............
- cluth problems maybe???
- Hypertech or jet??
- Cometic head Gasket users in here
- 30 or 33 spline axles for 12 bolt..
- speedo swap question....
- ran my first track time tonight........
- Aluminum Driveshaft
- Subframes needed if you have a 6 point?
- CRAP! My AC stopped working..plz help
- Oil reading WAY off.
- got a 383 and a hotcam
- Cheap place to buy throwout and imput shaft bearing
- How much is my engine worth?
- Hood rubber gasket,will removing it for summer let heat out faster?
- Help Asap...cam Bearings!!!
- want to see pics of DD subframes installed on your cars
- BMR torque arm hitting floor pan (???)
- better fuel pump and bigger injectors?
- hotcam people in here (shift point for hotcam?)
- LS1 Front Brakes: Wear Indicator Inboard or Outboard?
- Poly motor mounts, will they cause bad vibrations on an A4?
- exhaust question (anyone one with sims)
- code 64 right o2 sensor reading lean
- TC lock up mod
- Car bogs down low and hits wall up high
- Starter Installation
- Help with Crank sprocket.
- install guide for jet fan switch
- I hate taylor ovc's!!!
- Is no muffler good or bad???
- on my 96 will i keep getting ses code p0400 cause i have no cats?
- How do I put a video file of my 383 Idle run on the BOARD?
- Looking for pictures of BMR Extream torque arm cross brace installed.
- Dyno #'s
- little engine help please
- header bolts?
- HELP! Oil pressure drops to zero when braking hard!!!
- Autotapped my car lastnight (many probs)
- LT4 dyno numbers from today
- What do you call these things?
- hotcam with ported heads, what kinda power?
- Any white autometer 2 5/8" gauges that light up blue at night?
- clutch grinding once in a while-is she on her last days?
- Quick zero lash queston.
- Water Wetter? yea or na
- tt2 17x11
- Throttle Position Sensor Wires
- TB bypass
- General wait time for a PCMforless program?
- Just changed my oil.... Kinda Glittery...
- Roller Cam Button??
- Window Help!!! Please Help
- msd plug wires
- Throttlebody Elbow Hose
- would someone please reply to my tread?
- anyone have the water pump housing????
- Need to get a new fuel line
- headlight switch and dipstick part#'s pls
- Decided on 4.10's....what do I need to order??
- Putting a petcock in the block drain hole
- $450 for flywheel, clutch assembly, motor mounts, trans mount??
- is it ok to pull a head bolt to reseal it?
- Nitto Dr's on stock rims?
- 4L60E Locks into Second at WOT WHY WHY WHY!?
- Stock Exhaust
