View Full Version : LT1 Based Engine Tech
- What plugs are you running and are you happy with them?
- HELP, car won't start and been in body shop for over a month.
- Hotcam's 1/4 times and rwhp
- I don't know what to do anymore!!
- 3.73s on a4, good idea?
- Can I use PA lower A arms with a BMR K member without any problems?
- SLP Linelock is Installed!
- #1 TDC valve positions???
- What the hell is draining my battery? Im at a loss.
- Clutch Talk
- Whats the BEst tuner out there/ i just got new weels??
- rolling fenders, quoted $250 a side??
- should re-install a new cat.? EVERYBODY'S OPINION
- Head plug question
- Bad News Fellas!!!!!!!!!!!!!!!!!!!!!!!!!
- what are some times if you HOTCAMMED cars?
- Buying a stock waterpump...where?
- Harmonic Dampiner
- LS1 brake upgrade people
- Rino Ramps
- Were to find
- 4.88s in a 6spd
- How to install new dash pad?
- CMS cam kits , how much $ ?
- Interior lights?
- Fixing Intake Manifold Leak....any tips?
- Where is the spare? Stupid question I know
- cc305 question
- About to install new OEM lifters...tips?
- Those with ported lt1 heads and hooker lt's
- Fixing leak in SLP headers
- Catalytic Converter or O2's??
- Need a list.
- LT4 intake without the powder coating?
- Early 1993 Trans-Am & Z28 valve covers
- What PSI in 315 555R's on 9.5's
- radio turns itself on/off
- few things wrong with the car
- Pillar Gauge Pods
- Broken tranny mount...
- Users of OVC wires inside please....
- Jet Hot LT Install
- Ported heads and unported heads
- How long do plug wires last?
- Okay Guys one more Post about Exhaust sytems and I will shut up.
- Dynomax Ultra-flo
- Who here has passed Emissions with their mods ?
- What is length and width of Lt1 Camaro?
- Solid vs Poly motor mounts
- Wiring harness question
- Relocating battery to the trunk
- Questions about a hotcam in a 94 LT1
- Question about dyno'ing!
- MAC headers and Percy's gaskets
- Rear End Noise
- filtering alternator noise
- A/F Gauge
- check PCM
- ported heads/which header gasket to use...?
- TFS heads for LT1
- car won't idle
- rear end
- 3.73's
- 396 running, coolint coming from two head studs
- can someone tell me the serial # for a obd1 6 speed pcm
- Can I gut or cut off my Cat Converter?
- Car will not lose traction, bad or good? (a4 3.23)
- LT1 heads
- cc306 problems
- LT1 heads and cam (what springs)
- Gm 847 cam
- Porting the LT1 intake
- Gear noise
- att those who used the felpro timing cover gasket/seal set
- Hotcam
- Will ford motor sports injectors work in my lt1?
- New Exhaust Setup???
- Input bearing/ Bearing Kit?
- PA K-Member VS. BMR
- code 29
- 2500$$ to spend..what mods??
- cammed engine run like crap without converter?
- Et STreets
- Upgrade Torque Arm?
- Need help with screwed motor
- 396 stroker costs??
- How should this sound??
- EGR Valve
- body kits, lowering
- b-body off road pipe
- Big draw on electrical with manual fan switch
- Will this erase my custom PCM tune?
- Scorpion 1.7 rocker arm part #
- Part # needed
- Engine shops...
- Options??
- Converters
- Hat off to Combination Motorsports
- Lloyd Heads/ XE 230/236...Proven 375RWHP?
- burn plug wires cause (serviceenginelight)
- is this good?
- oil pumps
- Pulling motor out of top
- still having troubles please help!!
- How many of you?????
- Gears for a power adder car
- True dual video
- What size lug nuts are on our wheels?
- Lt-1 Questions (oil/tranny fluid)
- F'ed up story.
- 230/236 cam.
- Cut out in the place where catalyst is??? Anybody did it?
- LT4/LT1 Head Casting #?
- Bit of smoke?
- Unhook MSD when programming PCM??
- What size AFR heads do I need?
- LT4 Intake on LT1 heads?
- 3.73 gears, hooker LT's
- MSD Digital 6 vs Mallory Hyfire 6
- Car still acting all weird after new alternater, HELP!
- bellhousing bolts
- jet hot headers
- Y-pipe questions inside
- Bracket on back of head?
- Quietest Catback?
- not an LT1 but i need help
- Computer reprogramed for headers?
- 355 questions
- '95 Z28 LT1 Horsepower Ratings
- Car not starting... need help.
- Need Help With A Lt1 Scanmaster Question
- Best gears to get??
- timing chain question
- Crane 99846 springs
- Torque arm bushing ahhhh!!!!!
- What is this bushing called on my 95Z?
- LT1 Intake Runner Size?
- Is my starter going out?
- 3" true dual with X-pipe?
- fuel problem
- 1.7 Rockers and stock cam.. HP gains ??
- Do i need to upgrade rear and trans with this set-up
- 93 Z28 Rear End
- Got a diagnostic-anyone know what code P1661 is?
- What injectors and fuel pump?
- Scorpion 1.7 rocker arms...where to get them?
- Coolant leaking into cylinder???
- Interior noise question
- Edelbrock Headers on a 1997
- True Dual Quieting Ideas
- ProForm rockers = junk
- Timing Help
- AFR head question
- A4 Shift Knob button gets "stuck" on cold days?
- 305 cam question.
- LT4 Hot Cam Stats
- Biggest CAM and STILL pass sniffer ???
- ****IN-A!! Tranny Mount
- Should I use this oil next time I change mine?
- EGR problem
- part number needed
- please enlighten me to the ECC canister
- People with LS1 mounts inside
- who sells mac headers
- Rear Brake Pad Install
- Running Extremely Rich
- How are the hooker shorties?
- Expertise Needed Re. LT1 Valve Train
- Are STOCK 1995 lt1 pushrods hardend?
- How much does a new GM 4L60-E cost?
- Anywhere to get a dyno in upstate,ny ??
- SLP Eibach sprigs
- Could removing the EGR cause hard starting?
- Thinking about trading up to a 4th Gen any suggestions?
- best place for a Pro 5.0 and Lou's Short Stick
- Engine Rebuild - Hoses, fittings, etc
- NO start!!!!very weird, inside!!!!
- anyone running true duals with chambered mufflers?
- Can I retain my oil cooler after my A4 -> T56 swap?
- suspension upgrade
- who can help me?
- High Mileage
- Anyone run an Ultradyne 230/238 .565/.565 cam?
- stuck while installing fipk
- shorter shifter on ebay??
- Cam affect on milage
- Mac shortys w/cutouts
- So I have an electrical light show under the hood
- Cold Air Question?
- Anybody use this set-up
- attn: shoebox :o
- SLP Shorty question
- Service Engine Soon Light!!!
- Was watching my new camaroz28.com DVD, question about Taners car...
- getting a z28,what to look for????
- Going to carb: best cam?
- i installed my new horn today!
- best tire size??
- Shopping list for a GM 847 cam (searched)
- Whats A Cutout!
- Mass Air flow sensor question
- Will These Wheels Fit?
- Stock LT1 Pistons
- Teflon?? rings on fuel injectors
- Swapping an Impala LT1 into a 96 T/A
- Can't jack up car...
- speed specialty C-5 brake conversion kits.
- whats up w/ my a4
- problems 450~ miles after cam install...
- loading up on fuel???
- Anyone With Autometer F/p Gauge Get In Here....
- OMG, open long tubes!
- Passenger side window motor
- Alot of smoke!
- Installation Order/Advice
- Just broke down.. What could this be?
- Replacing Head gasket??
- Help I think My OPti has crapped
- carsound cats
- Lt4 hot cam HELP
- I need a couple part numbers
- allen key size
- Leather seat rip
- Code =P0420?
- Vacuum leak Question
- Code =P0420?
- Low Oil Level Sensor
- weight difference plz
- Help me with this rattle plz
- Convertible top leaking
- car missing need help
- AAM Diff cover? how much does it help?
- Just bought a pair of Corbeau GTSII seats.
- Jet Hot or Dyantech's...
- MadWolf... need tuning
- 52mm throttle body w/mods
- what should I replace while the heads/intake are off?ff?
- Which Exhaust
- Knock sensor. How do I get rid of it?? (important)
- PA lower A arms vs BMR lower A arms
- Lt4 Hot Cam Immediate Help Please!
- Manual trans question
- 17x11 wheels and rear stud ?'tion
- hoods
- closed loop requirements
- 230/236 sound clips????
- Shaky Motor
- 31mm brass freeze plug??
- reaction to hogging out cat????
- bad motor mounts?
