View Full Version : LT1 Based Engine Tech
- 396 build advice
- 383 build
- Can the coolant hoses to the TB be deleted?
- starting problem
- 96 LT1 engine surging
- Oil Pan
- Removing AIR and EGR?
- Main cap Tightening sequence?
- 96 ss vs z28 - what makes the ss have more power?
- Camaro is finally going back together after 8 years....
- 3.4 M5 to 5.7 A4 swap--- Whats needed?
- advice on cam deal
- Engine swap - will it work??
- 95 Lt1. backfiring no power. need help
- Trying staring my rebuild
- is mechanic right? 94 camaro
- Crank Pully for New Rotating Assembly
- svo 30# injectors part number
- OBD Question?
- 160 thermo
- New car New problems
- coolant leak
- Datamaster logs - Something not right with my LT1 - Any ideas?
- P1416 on a 97 SS
- 2 parts iso-heet 1 part lucas = death
- Replacing Engine
- 97 trans am with 94 harness
- question regarding heater core flushing
- a question about cooling
- Motor Mounts?
- 93 camaro z28 and spark plugs.
- weird sound when I start up
- Fuel system problem
- Radiator flush?? And header bolts!!
- Bad rear main?????
- What valve train parts for cc503
- Need a direction to go with a sitting Camaro
- starter turning only a 1/8-1/4 of a turn
- A DTC36 will NOT shut the engine down... Proved
- I need help with my car please!
- 1.6 roller rockers in stock motor
- valve spring tolerances
- multiple leaks
- Single plane. Holley vs Vic jr.
- 58mm Mono-Blade 1350 CFM
- timing chain?
- Are these longtubes Okay?
- major problem with coolant in '95 Z28--it's full of rust
- Need Help w/ Engine Cooling Fans
- lt1 engine knock
- 1997 Z28 Oxygen Sensor problem, P0141
- ASR light on dash
- 1994 camaro 5.7 ls1 limp mode
- EFI Connection LS1 coil conversion for LT1?
- 95 LT1 into 94 LT1 car?
- TCS = NO Accelerator
- lt4 timing kit
- New to the site could use some help!!!!
- Throttle Body 1350cfm?
- EVAP solenoid check
- please help... car is stuttering
- Exhuast HELP!!!
- engine mounts
- fitment of headers on a sbc
- LTCC Question
- Trick Flow Throttle body- Anybody have one?
- No start.
- Helicoil
- K&M air filter and 93 z28
- E3 spark plugs?????
- Intermittent miss while driving
- lt1 rotating assembly in older block
- Engine work what oil?
- Standard motor products vs. Delphi injectors!
- Difficult starting when cold - HELP!!!
- lt1 throttle response
- another lt1 problem
- Engine runs a little warm at cruising speed in top gear (6th)
- Identifying engine mods in a new (to me) 97 SS
- ses issue
- Help with the LS1 Intake Swap!
- Reasons for computer thinking car is rich when it isn't?
- lt1 ignition problems? brand new arcing wires
- Rear O2 connector location
- ss intake vs cold air intake
- Balancer wobble
- 94 camaro overheating prob. URGENT
- Valve cover issues
- Motor clack when cold
- scanmaster for my 96 lt1
- No spark need some help
- Reluctor ring replacement
- Going thru used LT1 engine, what can I do to freshen it up?
- LT1 ignition question
- 94 z28 wont run after 10 mins
- Alternator?
- Alt relocation for those who wanna save!! look here!
- Anyone make titanium undercut valves?
- Tapping and CPS Codes
- 987 vs 918 Valve Springs
- Just over 90k miles, when I get the spark plugs changed in 10k miles, what else?
- amp draw of LT1 starter
- 96 LT1 Camaro, ran fine but not won't idle well
- P1351 Never went away and now P1371 as well
- code 36 - high res failure
- OMG new 383 LT1 Not firing..
- Eagle SIR or SCAT I beam 5140 forged rods Opinions?
- Installing first 3 cam bearings with motor in car
- What lifters did I buy?!?!
- What are your thoughts on this setup?
- Buddies Camaro Won't Start.
- 94 Z28 missing, need some help.
- 95 opti
- Trouble Starting since using Seafoam Deep Creep
- O2 Sensor Response? Shoebox?
- Head Gasket Replacement - Parts needed?
- Remote Electric Water Pump
- overheating prob
- 355 build
- Cost of Boring an Engine
- lt1 to ls1 conversion
- Need help figuring where leak is coming from
- New GM Opti on E-bay for 64 bones
- High volume vs. High pressure oil pump
- Would these two things cause a blown headgasket ?ASAP
- 93 z28 problems
- problems with my 95z!
- spark, fuel, compression but no start on a new motor
- Need parts advice
- Re tuning after installing 30 lb. injectors-- is it needed?
- Sealing an Optispark?
- Car bogs down after a few minutes
- Which arp head bolts?
- Did UPS screw up my head.
- Engine shuts down after hitting rev limiter?
- wondering how much hp i got with simple mods
- 1997 Z28 - pulled driver valve cover - Issue finding where a (small) vacuum hose goes
- Steam cleaning = opti problems?
- possible IAC bad?
- what is this connector and sensor ?
- 1997 Z-28 problems
- How to check bearings and replace oil pump?
- lt1 build...need suggestions and opinions..really bad
- radiator hoses and radiator cap ?
- Lt4 a good cam for my 94 camaro lt1
- lt1 swap
- recomendation on building up lt1 motor to place in 69 corvette
- new lt1 motor mounts
- LT! Transplant into 60 impala-Help
- DTC 41 questions
- What connectors are these!!
- LT1 MSD BILLET HELP..do I need to take apart?
- Can an opti cap go bad?
- Engine builders info please!
- Where to buy parts for LT1, what parts for this build?
- what happened to the "cylinder head misconceptions" thread?
- What would it cost..?
- OB2 and Pace-Setter mid length question. OB1 conversion
- What to get!
- Possible blown head gasket
- what should i get
- No Spark. Ignition switch
- help identify bracket on engine 96 camaro
- Goodyear hi-miler hoses?
- Schrader valve core
- lt1 plug wires
- Underiven Balancer?
- Balancer keeps moving on the crank.
- Clutch affecting hp reading?
- got another problem
- Help! Car stalls when it gets hot
- Oil leak on back of engine on 1994 LT1
- Header bolt question.
- fan question
- Hmm? Envalve eliminates excess blow by?
- Header Swap - Final Parts List
- mystery scrape
- msd billet opti
- Damper/crank pulley questions
- Valve cover gasket part number....
- whats the best damper to get on my new motor
- is this an ok cam
- LT1 water pump... short of long style?
- Bang for the buck Top end
- lt1 problem
- is missing opti bolt my problem
- Help engine swap 96 camaro 94 motor and crank sensor
- spacer on ATI damper hub or not ?
- early timing chain conversion to later style
- Fouling plugs on 6 and 8?
- Plan didn't work, Plain B
- low voltage at idle
- intake gasket problem
- just got car problems...
- those with asm mid length headers
- Lt1
- Car stutters, lacks power clears up sometimes. O2?
- I hate aluminum heads on a cast iron block
- Valve guide wear?
- Coolant sensor?
- Egr Problem causing high NOx
- 93 Motor swap help!!!!!!!!!!!!!!!
- Engine Replacement -Please Help!
- opti troubles
- Meziere HD Install
- low coolant
- Won't start after rain, coil wire arcing to ground
- Fix Water Pump with JB Weld?
- Differences in lt1's?
- Oilpan gasket removal T56
- car at work for sale
- KB forged pistons
- Parts list (thoughts/comments/suggestions)
- Nur2s
- optispark???? need help
- 383 oil pan
- need help!!! cnt figure it out
- what else do i need for 400 hp??
- AIP optispark/ ebay opti
- Retorquing stock bottom end?
- Going to be replacing my valve springs
- How to add hp for a camaro lt1 z28 4th gen?
- Car starts, but dies
- ati balancer lt4 block lt1 accessories...help
- Failed Emissions. Help!
- Vats
- E-Bay billit opti
- mysterious miss
- dropped the motor today, pics
- Dtc 45
- Where does this ground go?
- what the heck is this?
- oil pump gear
- Motor mount through bolts
- LT1 Camaro Power Steering Reservoir Hose
- Opti Spark Again
- Lt1 383 stoker... broken crank.
- Random Misfire solved , Im an idiot
- trickflow 430 hp kit or le2 kit?
- looking at a 94 LT1, but my car is a 97??
- help a new guy?
- 02 Sensor Help
- griffin 25241
- 1pc rear main to 2pc
- Who makes 65cc or larger lt1 head
- Stalker Raped my '94 Z28 => UNDER the Hood. What could he have used to clog radiator?
- Magnesium centerbolt valve covers.
- A couple questions about stroke vrs wieght?
