install guide for jet fan switch
Old Jul 19, 2003 | 06:42 PM
ebryant1995's Avatar
does anyony know where i can get install instructions for a 160 fan switch on a 1995 ta..............thanks for any help
Old Jul 19, 2003 | 08:00 PM
Bud M's Avatar
Use an 8 mm coolant drain plug socket to remove the plug from the head. The socket I have is KD Tools p/n 3322-0. The plug is between cylinders 6 and 8. A small mirror and a flashlight make it easier to locate the plug. I used a breaker bar with a cheater bar because it was really tight. Wrap the switch with teflon tape. Be prepared to get it in the hole quick when you pull out the plug unless you drain the coolant first. Route the wires so they won't burn on the exhaust. Plug the wire connector into the wiring harness and replace any lost coolant. There's not much more to it than that.
cristian1311
Nov 23, 2014 02:22 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Aug 27, 2002 12:20 AM
slothgrant
Aug 22, 2002 03:01 PM
LT4Ryan
Jul 29, 2002 08:38 PM
