View Full Version : LT1 Based Engine Tech
- Simple Heated Oxygen Sensor Conversion Question...
- any Delteq bare bones kit buyers?
- Why does my car stumble...please help me
- Exhaust Junkies
- Mod Reviews and Suggestions
- Question on changing U Joints?
- Radio Shack blows. Help me find a resistor to bypass knock sensor!
- Will a 94pcm work in my 95?
- Just got quoted for plugs and wires.
- Opti,Cap&Rotor,Fuel Pump replaced, car won't start
- marble like sound comming from electric water pump, is it the bearings?
- Custom ram air setup from non ram air hood... need help
- Mallory 685 ign box on an LT1, need help
- Oil temp sending unit...Importance???
- Shavings in oil (very small amount) - normal?
- heater still not working
- Am I Running About Where I Should Be Or Should I Be Faster?
- Ethanol to help pass emissions
- lt's or shorties?
- Questions from my Dad... 94 Z28 vert
- Valve seal size question
- Midlengths installed... got ????
- Finally going to the tracks!!!
- Valve Lash
- Bored out throttle body...
- Need some help
- Do I really need a new timing chain?
- 30lb injectors plenty for Lloyd E H&C setup?
- 1.7 RR's installed ??????'s within
- part name??
- When my car's cold and I turn the key, the engine cranks but doesn't fire up.........
- code 22?
- 233/242 .569/.587 115 Lsa too big for stock heads?
- Does anyone make good rings in the stock LT1 size?
- loading pcmforless without floppy
- Stock injectors with CC306?
- How Can I Get Rid Of My Opti?
- Is this a good idea?
- Fuel Line O-rings...
- jackstands under pads?
- stock piston size???
- Looking for the bolt-on pulley set-up that replaces the power steering pump...?
- starter and mac headers
- Harmonic Balancer/flexplate... vibrations..
- Help me choose my exhaust setup...
- Engine oil cooler
- Electrical Problems, opti maybe?
- how high?
- Few problems on 95 Z28
- Help LT1 stumble (long)
- car wont stay on
- Dyno Tune with New Mods
- finally made it to the track this year hypertec is junk
- Long tube, ORP and Borla owners please....
- Fule rail removal - urgent
- Benefits of converting to OBD1
- Trying to remove IAC..Stripped the bolt...
- Will this cause overheat?
- CC 230/236/112 idle question ?
- What year did they switch to the smaller rear wheelhub?
- Antifreeze smell after jet hot lt's install
- What am I missing
- Oil sending Unit location
- What are the limits of the HR cam
- th350 shifter
- timing chain question
- 10 second LT1s...
- Mustang dyno work for my car?
- couple questions about LT1s/LS1s and ordinary SBC's.
- Is this normal?
- MSD Wiring
- Dyno results...whaddaya think...?
- Header leak or Valvetrain noise ?
- how can i reach the 12's?
- GM Head Castings Same Left / Right????
- LT1 in a C3 vette
- MAX Lift for a 383
- Will this hurt?
- Question about HydRoller over.600
- Just bought a '96 M6 with low miles...what now?
- Comp R lifters suck. Worst lifter in the world.
- ****Guess my Track Time**********
- Whats Causing my MAP sensor to set a code?
- Flushin torque converter, How?
- valvetrain help, asap, a quick question, **
- When does the AC compressor engauge?
- Where to buy Forged Internals?
- I need a y-pipe.
- Just fixed Leaking Intake Man. and Opti...one problem still here!
- Wheres your temp gauge at?
- How much fuel pressure on stock LT1's??
- anyone ever had this oil leak
- Car Is Running Like Dookie Experts Please Help
- Difference between 93-95 and 96-97 cat-back
- Peps with oil pressure problems...
- How do I fix this?
- Suggestions
- Hooker fellas...
- stall and gears????
- false knock???
- Cloyes crank hub marks
- Need pix of stock LT1 oil pump pickups installed.
- Arizona Speed and Marine Throttle Body????
- will false knock retard cause stumbling??
- LT1 making weird noises, Video Inside
- car runs like SH** in heavy rain
- Question about OBD connectors.
- Stroker Rebuild LT1?
- loss of power between 60 and 80 kmph
- What is up with code 300 after cam swap?
- Some LT1 questions...
- Should I swap my SLPs for longtubes?
- QUICK ? timing cover
- Looking for 30# SVO injectors
- snow tires
- What are the symptoms of a fried computer?
- 3.42r boom 3.23 now got a cc306 t56
- LS1 28.8lb injectors suitable for stock headed CC306?
- Need Diagram Pics
- Cam/ Vaccum question...
- 95 z28
- I NEED A BIGGER Valve Cover
- 99 Z rearend in a 93 Z
- Anyone ran a cc306 with GMPP 1.6 rockers?
- Best Headers
- question about 93 LT1
- can I use slp shorties and single cat y pipe on a 97 z?
- bad vibrations off idle
- o2 sensor extensions?
- Help with DTCs: 26, 77 and 83
- Please help - oil leakage
- were can i get a good rebuild kit thats cheap for a 94 z28 camaro 350 5.7 ltr
- New times with scorpion rockers and tune
- Code 42 and car acting very odd.
- A/C compressor squeaks bad
- how to remove k&n filter
- is this possible?
- High (2500 rpm) idle
- Cowl hood fan idea
- Just changed the starter..
- Will Holley 58 throttle body fit on my 93 lt1
- Not my opti?
- Took my car to dealer... WOW
- FYI (running problems)
- Master Cylinder U-Bolt
- MASSIVE homemade CAI....
- making LT1 computer work with a Motown block. Possible?
- Head/Cam Questions.
- New engine.. Keeps heating up.. Coolant problem.
- Free mods hurt gas mileage?
- Mangled spark plug hole...fix???
- plastic panel in front of radiator
- Anyone in MD edit a PCM?
- Replace whole EGR system now?
- scanmaster for newbie
- Heater core hose install?
- hard starting!? 96 Z.. whats the problem
- how to install tach
- 4 bolt main questions...
- Magnaflow Exhaust Prices
- How to Prime an Lt1
- shoebox thanks but
- Granatelli MAF Sensor with Madz28 Tuning
- car running like crap at start up, then its fine, then bad once warmed up!
- Alternator noise
- Spark Plug condition/ still cant get passanger wires
- Free Ram Air mod
- Where to put cutout
- Power steering fluid
- Using regular gas?
- help
- Lt-1 Head Bolt question
- datamaster logs
- Alternator Issues!!!
- Plugs and Wires
- Alcohol injection??
- Cc305????
- Jet Hot Longtubes Installed!
- idle speed setting
- Exhaust setups questions
- what is this noise?
- In terms of Aftermarket Crankshafts...
- trying to get the clutch fork in
- Buying Slicks, help need it!
- Oil Temp Gauge, Where do I put it?
- Which are better heads?
- What will it turn in the1/4?
- what makes it choke?
- How much horse power do you think I have?
- Loud Lifters
- Power Window...Neep help diagnosing problem
- what cam?
- Hotcam users come in
- 2 ?'s 1-scanmaster & 2-pcmforless? please help
- Any tips on torquing header bolts?
- Kook's Headers and clearance
- Headers help
- 1 5/8 or 1 3/4 oil pump?
- Sway bar effects performance?
- Ebay Vortec RR's
- One plug wire cause this???
- Golens 396 shortblock and AFR 210 or 220s?
- why is this
- Is it on its way out????
- Will gen I headers fit LT1?
- new delco starter gets HOT but no clicky clicky
- squeak unknown
- 1997 camaro SS seat belt guide broken.
- Knock retard off idle, what could it be?
- Can someone look @ a freescan log?
- How much to install catback?
- Help!! tranny???
- converted LT1 head for SBC, valvetrain questions
- cooling fans
- a lot of parts what order what YOU put them on in
- Ball joint wiggles... time to replace?
- Look at this pic. Who makes this hood????
- Get up and Go Got up and Went
- What does this do???...
- 1.7 rockers with emmission cam
- will 97 Jet-Hot longtubes with Hooker ORY fit on a 94?
- Ta Cover Leak.....
- ignition fuse blowing
- Changing plugs a few at a time?
- HELP!!!!! Problem w/ turn signals.
- What gaskets and sealent to use on intake manifold & throttle body.
- Lt4 Knock mod.
- Might help someone.
- How to identify rod bolt type?
- Quick pushrod and rocker question
- LT1 Coil Pack Conversion From Opti. WHERE?
- Newbie here - Catback help!
- What performance is it capable off ?
- Hardware question for headers....
- Motor Mounts
- How long does it take YOU to change your spark plugs?
- Header question..(AFR?)
- Need advice. LT1 wont start.
- Hypertech?
- More speed. What can I do?
- whats the point of a coil on plug conversion?
- Why is the car running choppy
- Horrible Oil Leak.
- how far can you port a stock throttle body?
- need help on selecting the right heads for my weak 383(help)
- I've tried everything and still can't get my fans to turn on
- Opti problems?
- Car starts, sputters, and then dies...PLEASE HELP!
- question about getting trouble codes
- Low coolant light on, full of coolant. Need help fast!
