View Full Version : LT1 Based Engine Tech
- Electric Waterpump installation
- proper way to tight NSA rr's?
- 284 cfm @550 on 1.94 valves?
- BIG cam sounds clips Please
- question
- Can noisy rockers trip SES light?
- Length of Cam Pin for 96/97 LT1 (Vented Opti)?
- Anyone here ever send back their Jet-Hot's?
- SVO injectors, where to get' em?
- 52mm TB
- ANOTHER what cam? thread
- Is this true about heads???
- Working on Plug Wires next... How?
- Where to get a Custom Cam??
- stumble/miss after oil change
- Is this injector enough?
- Anyone know this part #??????
- Exhaust smell
- Crank turning...worth it?
- Paging Brent Franker
- Sputtering and surging ONLY when warm????
- couple 1.6 rocker questions......
- Anyone take their alt. belt off at the track???
- Has this happened to you?!?!?!
- What Tools for Header install...
- some slippage. . . but where?
- New to the Board Need Ideas.....
- Mod Advice
- Can't Do a burn out. Need help!!!!!!!
- Rattling Cat Question
- Tune-up
- code 1641 & 1642
- Stripped Spark Plug Hole
- Rag Joint Eliminator and Jet-Hot LTs
- Does a/c delete need tune w/ obd2?
- Loudmouth, Cats, and Long Tubes?
- Jasper LT1 coming Soon, Any Cam Suggestions?
- Which to get first?
- Hw har are headers to install on an LT1, shoties, long tubes and info about clearance
- Are fuel injectors universal?
- How do you check PTV clearance???
- how much would it cost
- MSD cap and rotor replacement for Opti-spark
- so what happened?
- pushrod problem..
- $2935 for Heads/Cam?
- question about cloyes double roller chain on an LT1...
- What would make THIS noise!!
- Is it ok to lift the car up by the front bumper?
- LT4 Starter - Great!
- Looking at a 1996 SLP SS Questions
- my carbon kit...
- Whats up with this???
- Cooling Issue I don't understand
- Gm 846
- Dynaspark opti spark any good?
- Gear Oil?
- H or I
- how to set timing on CARBED LT1
- WHat would make way too much fuel be dumped?
- Remote starter connection
- just dynoed 1356hp
- Should the ignition coil light up with each spark?
- how much hp
- Low Coolant Light
- Quick Timing Question.
- Need some airbag help!
- rebuildage
- Preliminary numbers from my ported LT1 heads
- loud valvetrain
- Question on High stall (3000-3500) on Stock Heads/cam
- Newbie needs help with Rich mixture (and O2?)
- Alarm problems
- Check Engine Light???????
- Getting starter to line up
- whats the difference
- 911 heads coming off sunday! help!!
- Exhaust Manifold Plugs
- Which oil pressure sensor for my 94 vert?
- How do I index my plugs?
- Le2 cam...
- new mobile 1 oil 5k 7500 and 15k miles between changes
- failed visual smog because of T.B. bypass!!
- Uh oh! Stumble and stall!
- Will this coil work?
- woohoo! finally got a friggin code for my stumblin maybe, whats it mean??
- Broken timing chain
- pcmforless tune and now "service engine soon" light is on...
- Looking for pics of Catted LT Y-pipe
- o2 sensor help
- 2nd gear slector
- Racetronix 255 PnP kit
- Is this difficult?
- Canton oil pan...
- Part # for gm846... and valvetrain help
- Exhaust sounds louder
- HEYA im back and got 1 question about my camaro :) (shes got a problem) help!
- Its Done......
- Bought a 94 Z28 and I love it!
- what mod next, pretty much all boltons??
- Engine Break In
- Advice
- Could this happen? Help!
- CompCams Magnum vs. Pro-Magnum Rockers
- quetoin about some things
- Another cam thread!
- opinions on my fuel problem needed
- Edlebrock heads and cam
- timigs set to gear drive on my carbed lt1 project?
- Need smog legal shortys
- Weird fuel pump issue
- Solid roller opinion
- what header gaskets to use with Mac Mids?
- Things to look for.
- What are Cut OUTS?
- biggest ci?
- At what power level should I replace the stock ignition box
- Major problem, car wont run after 10 min
- 1.6 rockers breaking stock springs
- Questions about my current true dual setup...
- Sweet Thunder X-Pipe
- Fuel pump bucket?
- Cig Lighter Enough To Power Seat?
- Smoking problem!
- Just changed over to poly motor mounts...AWESOME!
- Cloyes double roller instruction manual
- Exhaust manifold gasket?
- Anyone know the flow numbers for the lt1 iron heads?
- Injectors won't fire...
- Problems at start up
- Taylor OTVC Passanger Side Wire Routing Help...
- Idol control
- High Fuel Pressure
- Headers
- power estimates???
- Where is a good place to get a gm847 cam
- DYNO #'s
- Free mods
- New PCM just came in the mail!!!11 Install questions...
- Engine miss
- Transmission Bolt Extraction
- Tricking the comp about ASR??????
- What is causing this trouble code?
- Header ?
- will i need a tune?
- No start problem/weather related
- Catback and Headers with stock Y
- bleeders for aftermarket radiator hoses
- It wasn't my water pump leaking, it was
- Dynamic Compression and Quench
- Help, Bad Opti or Ignition?
- Racetronix 28# fuel injectors questions???
- Does GM sell the cooling fans & shroud?
- Sticky Request
- ATI superdamper snout to hub clearance? Bolt?
- opinions on dynatech long tubes?
- Flow numbers for stock descreened MAF and aluminum intake elbows?
- has anyone run the xe224/230 with 1.7rrs??
- 97 pacestter long tubes on a 93 Trans Am?
- every single knock retard table zeroed out, still pulling timing??!
- Overheating problems and abs and the traction lights come on.
- comp cams double roller
- racetronix FP
- GM 847 Cam on 114 LSA
- putting in new converter rear main seal question?
- M6... T-56 ? what do these mean?
- Gut Cat? or not? How to gut it?
- what octane do you run on?
- LT4 intake/ 58mm TB
- Best Combo for 450RWHP/TQ
- what part is this?
- Help Pick NA 383 Cam
- Adjusting fuel pressure?
- Will not having O2 sensors hooked up make car miss?
- LT4 Hot Cam
- Aside from the pistons, how much power can an LT4 rotating assembly handle?
- Does Anyone Know Of A Good Tunner In Toronto
- Exhaust ?????
- Map sensor voltage
- Questions about installs
- Crane 11308-1 Springs
- CC306 parts list
- Wont start
- 500 hp... best way to go?
- shift light help
- Need help fixing my car
- having some 96 lt1 problems...
- I need a pic of lt4 timing set...
- 96z Bone Stock Miss Fire
- how much lift can press in studs handle
- Does the 95 Lt1 engine have hardened pushrods
- Heads Cam, Wont Idle Power Loss
- LT1 Engine Bolts
- Complete LT1 heater/radiator hose list?
- Loud clunk when turning?
- Future Mod List
- How hig can you rev a stock LT1
- SES light and whirring noise under hood
- Fuel Filter??
- If your running a Highflow cat has this happened to you?
- Help Me Decide my Heads/Cam package
- SLP fuel injectors
- Finally repaired blown head gasket
- car acts wierd on higway.."tranny or miss related???"
- Fuel Pressure
- What is this part?
- Where to purchase opti?
- Partnumbers????
- Intake Manifolds?
- Plrease help, need to fix car
- oil question
- Cam specs??
- Heads/cam whose the best??
- Oil pressure drop at WOT (not cavitation)
- fuel pump removal
- tach reads zero with engine running
- Still cutting out!
- LT headers-Y pipe
- Car's screwed... need some help lol
- Oil Pump Question.
- how difficult is installing new roller rockers>
- Brake Fittings???
- Fuel rail clips
- Today's Dyno Numbers
- Can 02 wires blow ignition fuse?
- Cam or Spray?
- Quideplates?
- Heads
- Opti is crapping out (delteq question)
- Taller valve covers with guidepates????
- anyone put a different pulley on the powersteering pump?
- LT1 shortblock..standard sbc?
- Another ? about slp shorty headers
- Can the car run w/out 02's?
- name that sensor, part throttle stumbling
- xe230/236 on stock heads??
- Cleaning fuel injectors with ultrasonic????
- where to buy spark plugs with paypal?
- insanely dumb question....
- Oil Sensor Switch...
- I want 300-325 RWHP
- LE2 cam sound clip
- Car is Bucking and Poping!!! Info files inside
- 97 LT1 tuning...
- quick help needed for friend at track, dead opti???
- What type of timing chain do I need for my setup???
- New Track Times!!What do u Think?
- Block Questions...
- Richmond whine. 2.73's to 3.73's problem
