View Full Version : LT1 Based Engine Tech
- 94 z28 M6 issues
- 1994 pcm in 1995 lt1
- MIL light out...Fans come on! (FYI)
- LT1 Cam
- DTC 26: Quad driver Fault questions
- Car intermittent start, Weak/no noid light
- Differential gears
- 93 formula LT1 starts and sputters
- comp cams 1.6 rr's
- 94z28 Hypertech Power Programmer III????
- OBDI trouble code issue
- 1994 z28 lt1 engine sucks air inlet hose
- 94 z28 48mm vs 52mm tb &air foil & tb bypass &maf
- Back again Code 18 question
- Upgrade injectors and intake?
- Trickflow/Edlebrock LT1 heads
- LT1 just starts and shuts down
- High Idle fixed
- 97 Z28 hot battery no power
- New clutch - Getting trans back on
- Ohm value of temp sending unit 95 LT1
- 1994 z28 shuts off while driving
- Homemade Cold Air Induction for '93 LT1
- '94 Z28 Stalls!
- Possible Cam Upgrade?
- Rusty spark plugs (with pics)
- Transmission issue
- Fan kick on temperatures?
- LT1 Alternator wiring plug. question
- What is this???
- Removing steel plug from aluminum LT1 heads
- Missing and sputtering with data log
- holy mother of broken
- 94 z28 best exhaust & headers for your $$$$$
- shifting problems after installing a stall converter
- 94 z28 stock 0-60 ??
- Vibration @ ~2500-3k rpms
- In search of a Dyno Tuner in Central FL
- Car shuts off randomly...Any thoughts?
- LT-1 to L31 swap.
- Cam for 93 LT1
- Do I need to change the oil pump
- Hot weather issue
- Feed back on Dyno Don's headers
- low dyno numbers..
- Missing pushrod?
- 93z28 flooding
- 94 z28 camaro lt1 300 hp ?? info
- LTCC Install Instructions
- Fan problems
- Plz help 93 z28
- Intermittent accessory power issue
- 94 z28 noise driving me crazy ?
- 94 LT1 opti issues- won't rev, new opti
- Help with engine miss please
- 1994 z28 camaro smog?? & stock breather ???
- LT1 starting problem
- 1994 z28 tune up lt1 ?? why Chevy why
- Code 27?
- 1994 z28 strange problems
- 94 z28 update ? help
- Help/Car stumbling running rough
- How much is the stock lt1 flywheel offset weight?
- 94 z28 coolant sensor leaking??help
- 95 z28 Randomly dies and wont crank
- Lt1 ovreheating need help
- new z28 owner :) lt1 ?
- Does steampipe steam?
- Intake explosion and white smoke
- 97 z28 will not restart
- injectors
- Opinions on early LT1 timing chain
- Car dies when in gear
- Catalytic converter
- Car Wont Start Help!
- 1995 Z28 LT1 Idle Problem
- 1997 camaro z28 injector cycle problem
- Black smoke, won't stay running
- Ltcc setup instructions
- tach and speedo reading incorrectly?
- Borla Adjustable Cat Back
- 94 issues help please
- LT1 ignition gods please help
- Rough Idle/Skipping
- Issues after spark plug change
- oil pressure concern
- Help please... Starts on second attempt?
- No CATS OR CATS
- Something hitting
- Shbox Opti Test Reults?
- High Flow Cats vs. Stock
- pig tail connector on coil
- What is this?
- Custom Cam Question
- LT1 keeps stalling when warm
- bad backfire hesitating just horrible
- oh god its loud
- Fuel pressure regulator bracket
- security light
- 1993 z28 vaccum diagram
- Idle and Random Stall
- 93 specific internal Trans pan harness
- ignition coil
- 1953 Chevy Custom Sedan Giveaway
- AC compressor install
- Gas in oil and gas coming from exhaust
- header question
- What's it for
- PCM questions
- rough idle, backfiring, fuel injectors
- paranoid or problem
- P100 code Help
- Dyno Number Questions?
- Overflow grommet
- Mustang Dyno Results - Finally hit target
- lt1 383stroke. 153 or 168 tooth flywheel?
- Lt1 has me stumped. missing and popping
- 1993 z28 stall issue
- Wiring 1995 fan relays street rod project
- code 43
- Battery question / minimum power
- 1993 Z28 hesitation problem
- P0400 again
- still no start or spark
- 96 z28 LT-1 cooling issue
- Dyno run: Low Torque?
- EGR Trouble Codes
- 93 camaro z28 383 stroker 6 speed back firing when hot ??
- Throw out bearing problems!
- 1996 camero z28 cooling issues
- LT1 Electric waterpump guys
- 1996 camero z28 cuts out and dies at high rpms
- think i blew it up
- identifying block
- LT1 Swap electrical trouble
- MAC Header Install TIPS/Help
- Motor mounts
- oil pickup install
- 1993 LT1 Fuel Line Leak
- Relocated LT1 Traction Control
- bought a used "lt4 hotcam" is it real?
- Injector question
- this car is driving me crazy
- Water pump drive shaft
- now i have a no start condition
- i have codes P171 AND P336 together and car runs badly
- whats normal oil pressure for an LT1??
- ticking noise and miss
- Cranking motor
- Cam bearings install
- To replace or not to replace (oil pump)
- My next project...
- las vegas Tuner ?
- What head gasket
- New car/ blown engine
- Bad clutch job?
- Lower gearing ratio
- FAST EFI as piggy back with stock PCM
- Lt1 383stroker build questions
- Starting Problems.... Help!
- 58mm BBK on a non 58mm intake
- knock sensor questions.
- 95 lt1 with 700r4
- K&N, AEM, Fram air filters?
- O2 sensor location
- Bad vibration , help needed
- 1995 LT1 engine cooling line routing?
- big trouble
- Need help high idle and a few codes
- the difference in motors
- Fuel injectors /plugs/ wires
- 1994 LT1 log files, runs terrible
- 96 lt1 help plz
- Need to convert to heated o2's???
- 95 camaro vacuum lines
- more power
- 3 opti sparks bad in a row or am I screwing them up?
- High Idle
- Gasket set
- ATI Harmonic Balancer Shell Aluminum vs Steel
- Engine overhaul- main and rod bearings
- block and crank from bad machine shop
- 94' to keep up with new SS
- Transmission Dipstick
- 95z28 fans stay on at cold start and overheating
- Aftermarket tuning computers EZ EFI style
- spark plug wire #5
- lt1 engine swap
- hose size please
- Dumb question but I'm asking anyways
- Autolite ?
- Should I replace my waterpump since i'm already replacing my opti?
- Advice on springs and roller rockers
- heater core flush
- Fuel Regulator?
- New Golen 383 LT1 install
- Spun Bearing possible
- Cooling problem with LT1
- Miss on hard acceleration or WOT above 3500
- Motor Help
- LT1 intake???
- 396 Head Options - Need help
- How to beat california emmisions?
- need help with hard heater hose assembly. I searched google, shoebox, cz28 and Hayes
- Throttle response not as crisp when warm?
- Crank hub fell off with supercharger pulley, options?
- Side Post Battery Terminal Adapter
- Engine Smooth Now
- wanting to upgrade
- stoker motor build help
- Engine banging at start up
- pushrod length
- Stock cam with Head Work
- too much cam?
- potental LT4
- vibration throughout the car
- want to upgrade
- no spark please help!!!
- Rough idle and runs rich
- LTCC coils mocked-up
- need advise for tune
- Rebuilding the Lt-1 from 0 ... Where do i begin ?
- Did I purchase the wrong cylinder heads?
- 96 Z28 Auto trans
- Ignition problem HELP!
- Tired of replacing fuel pumps
- z28 transmission
- Overheat with new Electric H20 Pump
- Can anyone guess my valve springs?
- 96 z28 lt1 after header installation
- Driving me nuts
- Fuel Pump, Injectors, Opti, or all of the Above?
- LT1 into a 3rd gen
- EBAY true duals
- timing set
- oil leak
- 4l60e
- water/coolant leaking through this hose
- Lt4 knock sensor
- Tb bypass
- LT1 engine swap help needed. 1996 z28 motor/trans into 1995 z28
- 93 trans am no spark all of a sudden
- 4l60e
- 97 V8-6SP into a 94 Z28? what to expect?
- Camaro 96 v6 to v8 engine swap
- Cam help
- Do PCMs fail?
- Engine replacement options
- new transmission
- dip stick debacle
