View Full Version : LT1 Based Engine Tech
- Any guess on new 1/8 times??
- Ebay Parts CD????
- MSD coil.......
- Need help: Opti-spark coil wire ends
- Electric waterpump
- Removing AC
- rear passenger side header bolt
- I may have screwed up need help.
- Rookie needs LT-1 basic info
- Miss after sitting a while after hot
- new ac compressor and it flinging out oil?
- GM replacement motor mounts question
- @&^&@ Stupid Roller Rockers
- will 94 manifolds fit on 96 camaro?
- Long Tubes on E-Bay for $279??? What's up???
- LT-1 swap
- Does SES light make car go to limp home mode?
- Who's running a TNT DRP
- Anybody use Sea Foam Deep Creep?
- having trouble removing bolts in the middle of converter swap
- jet hot with or without emission??
- LS1 valve springs on an LT1 head
- exhaust question
- A little help swapping PCM's
- Which is the best ignition system?
- finished A4-M6 swap, speedo is way off???
- Has anyone switched over to a hydraulic T/O?
- Lets Talk SHOCKS... Which would YOU get?
- car runing hot today any suggestions
- Radiator Removal
- Car just died while driving, now will not start
- Header/ ALT. Nut
- removing oil pan with motor in car (in process)
- Very interesting read...
- TRQ specs for RR bolts....
- How are Dynatech Headers ??
- May have helped a victim of a stealership.
- Maybe I can get some help in here...
- 1.6 or 1.7 rr
- Heads/ cam
- Is this OK?
- part # for 94 IAC valve
- HELP ASAP-in middle of converter swap
- LTCC again
- 93 and 94 m-6 wiring ?
- !%&*%#@...i hate my car
- Heater Hoses won't come off no matter how hard I pull!?Ideas
- swapped rear end last night, couple problems
- fluidampr or ati and underdrive pulley question
- 42# Injectors and Tuning
- Custom Exhaust opinions
- Rotors
- Another questoin about the Edlebroc heads...
- 1.7 RR's and XE lobes???
- Thickness of LT1 Flywheel?
- totally stumped LT4 conversion idle sucks, please help (tuners?)
- Extrude hone????
- underdrive pulley belt ?????
- Which ATI balancer to get?
- Need Flow Numbers for LT1 Edelbrock Performer Heads
- Flushing heater core.. Do I need to change radiator fluid after or is it not affected
- Tapping from engine.....ideas?
- Heater Hoses, which ones to flush and clean for hotter air?!?(Picture Inside)
- Oil sender? Cluster? what is the prob?
- i need your advice on cams ((pleas check it out))
- a few 377 ?'s
- R.A.P.-not terminating
- Headlight Problem
- do i have an alarm?
- Stroker Kit
- LT4 Heads and Intake - Any Installation Problems?
- 4.10 and 3.73 top speed?
- throttle sticking, cam surge
- replaced ABS module, now when ABS kicks on pedal goes to floor
- high idle question
- ARRRGHHH this is irritating.
- No spark at Coil??
- Quick question! 1st oil change (oil filter)
- Gonna use a cutout, is the exhaust pipe on a 94 TA 3 inches or 2 1/2 ?
- gas mileage decreased by 60miles to the tank!
- Code 11 and fans on
- Tranny or PCM?
- How hard is it to put in lowering springs?
- hood latch cable route....
- Cam degreeing... Here is an idea...
- CC306 Questions
- headlight motor
- Will this work on my Camaro?
- Does the 3800 V6 have the same tranny bolt pattern as an LT1?
- Fuel Rail Connections
- crazy car trouble
- Drag Radials...what can I expect?
- LT4km Worth it
- Tuneup time...what brands to get for everything?
- will this LT1 pass Emissions Test?
- 3 inch true duals VS 4 inch mufflex with dual outlets
- Who knows Speed Density Formulas?
- Dissapointed in LCA's! Or is it the weather 39Degrees.
- What types of injectors fit/work in the LT1?
- Lloyd's address
- looking for in car videos
- 224/230 112 lsa idle
- Degreeing my new Cam????????
- guy's who are locking the converters manually in the 1/4
- can I use syn brake fluid in my clutch?
- Rear brake line
- Rear Window Defroster ?'s
- cheapest place to get a hot cam kit?
- Over Heating
- Throttle return
- Posi Question???, very confused
- Okay, what do you think of THESE?
- shifting to drive
- Oil Pump Drive ?
- question about rally sport spoiler
- MAF Airflow
- True dual questions....
- Any other heads/cam M6 guys have an aggressive throttle follower?
- Are these the shocks I want??
- Replacing Heater Core Hoses Web page
- Anyone have a Trick Flow aluminum elbow with a K&N CAI?
- Crank Gear!!
- Crank Pulley?
- SLP CAI INSTALL...little tough
- Girlfriend got down and dirty! Helped me install LCA's
- ATTN : Pedals Vibes With Cam
- Edelbrock Midlenght Headers???
- Aftermarket Harmonic Balancers
- Witch Headers???
- Mounting PBR's on a 96
- Underdrive pullies worth it or not
- LT1 opti to LS1 style coil on plug convertion info needed please.
- Crank question
- what a releif
- signs of a bad alternator??
- rough idle but smooth running??????
- Whats all the squeeking?????
- Oil Pressure at WOT????
- generations!!!!
- coolant fans current draw
- help on fixing taillights on trans am
- Drive shaft help
- x-pipe vs. H-pipe
- Intake Gasket
- remote start.. not activated???
- Harmonic Balancer Question
- edelbrock & trickflow heads????
- $100 for 02s
- Good Pininon Angle?
- those using exhaust cutouts, any fumes coming into your car ?
- Anybody give me a rundown on installing an airlift single airbag??
- Underdrive pulleys?
- Can you test an o2 sensor?
- Which harmonic balancer to buy
- What to look @ when scanning o2 readings?
- Can anyone make the make of this wheel?
- Good Fit for SLP torque Arm on Moser 12 Bolt
- Aynbody using a Hypertech coil on their LT1?
- Dreaded white smoke
- Thin ground wire on pass. side of block by dipstick... what is it for?
- Need a good tune, where should i go
- running like worse in closed mode
- Whats Lloyd Elliot's number/webpage?
- Gunk in TB
- Wheels Re-Chrome
- part # for pass. foglight
- Got my Jet-Hot Coated MAC Midlength Headers. Pics Inside!
- Headers Hotttt Or Not
- I am having a few problems with my car and I wondered it you guys would maybe help me
- Followup to Brake Problem after Hotcam Kit! ABS Help.
- TQ and Gears ?
- stock exhaust diameter...
- MSD 6A or 6AL???
- Who is Happy with the 1LE or Slp level 2 swaybars?
- Which headers to get?
- Those With Double Roller Timing Chains Inside Please..
- installing SFC?
- opti swap part numbers
- Do I have an ODBI or OBDII?
- Help With Parts List Please.
- Digital 6, or no digital 6
- Wipers
- Need help picking out heads for build up?
- AFR 190's???
- Car wont idle
- Gas mileage:: 227/233 VS 230/236..Its that time!!
- EMERGENCY...... kinda
- Umbrella valve seal question
- bright lights stuck on!
- Spark Advance 14* knock retard 14*!!
- Shifter Vibration Still There!
- Getting Vibration 2k and up
- My xmas gifts...
- How important is this vacuum line? *PIC*
- What do you think about the Z06 MAF Conversion?
- So white smoke = burning coolant right?
- Cranks made in USA
- Dumb question #702 and #703
- All who have or use a n20 cam come in!
- Iron LT1 head Vs Aluminum LT1 head
- What Y pipe for Jet-Hot Headers?
- Hard miss when cold and directly after startup
- Caliper part #
- high rpm miss when hot help
- purple horny pics.
- I need some advice on true duals before i have them put on tomorrow
- I found this website about Oxygen Sensors
- cc306 tuning question.......
- whats needed for intake manifold leak fix
- Just bought LT4 KM???/
- Opti-Spark??
- forged internals on a LT1
- New cam specs.
- Weird door handle problem
- LT1 is a small journal crank right?
- Continental Tires
- Lt4 heads
- car runs like doodoo with LT's installed
- question
- Need help, car doin some wacky stuff...
- Still Looking for help
- Visual Inspection for Driveshaft Length
- Question for [B]Rob[/B] regarding porting the MAF
- Torqu Arm Bolts for SLP T/A
- Waste Of Money
- Low MAP voltage output!!
- Airlift rear/passenger airbag on a lowered vehicle
- building a remote mount water pump, someone tell me the path coolant makes
- 1.6 Rr
- Who has the fastest 224/230 NA
- Car died..then came back to life..i hope
- brake line question for my 88 gt mustang
- Bosch Oil filters
- Coolant Issue... pressure, leak, something.
- Electric Waterpumps?
- Just got plugs & wires changed and guess what...
- Does anyone know?
- Ses Light
- Shifters
- hotcam tune w/ CC306
- please help my charged ss
- Cam install
- What all controls timing....
- need to beat LS1
- Any one ever reved there car up and the ASR light come on?
- weight reduction parts companys ?
- So I can reuse my stock PP?
- Those with a huffer, what happens to vacuum level???
- 12 bolt fluid (synthetic vs standard)
- Lookin for a good conversion on the opti
