cluth problems maybe???
Old Jul 20, 2003 | 01:31 AM
marshall93z's Avatar
sometimes while sitting still, at an idle, with clutch out, car while bounce! its definitely coming from the clutch, or at least i think it is, because i can push the clutch in and it will stop.
i have no clue why it does this?.....any ideas?
Old Jul 20, 2003 | 01:50 AM
RedPhenx's Avatar
what do you mean bounce?
Old Jul 22, 2003 | 03:58 PM
like you can feel the car bounce up and down and you can see the shifter shakin, but if you push in the clutch it stops!
Old Jul 22, 2003 | 04:52 PM
jbird's Avatar
sounds more like a tranny problem to me, it shouldn't matter if the clutch is in or out if the tranny is in neutral, however, when you push in the clutch pedal the tranny stops spinning, so something is probably wrong with your tranny.
hope this helps ---J.Bird
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
