What does a closed EGR valve look like?
Old Jul 21, 2003 | 07:32 PM
107's Avatar
107
I took of my EGR to clean it today, and sprayed carb cleaner everywhere for about 20 minutes, the valve was indeed stuck and I got it loose and smooth again. The only thing I noticed is that it does not seem to go all the way up- and if you look at the shaft between the 'bellow' type thing and the casting, there is a good 1/4" there- should this go all the way up or is this normal? Also when I blow on the valve in the closed position, I do hear air escaping- is this normal, or should it be completely sealed? Has anyone tried this on a new valve?! Even a picture of a new valve would help!
-P.J
Old Jul 21, 2003 | 09:06 PM
AsianSensation's Avatar
Normal EGR Valve
Old Jul 21, 2003 | 09:58 PM
107's Avatar
107
Thanks, thats about how mine looked- now I just wonder whether its supposed to let that little bit of air through or not...
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
jocamino
Dec 29, 2014 10:15 PM
kclarson
Aug 22, 2002 04:04 PM
