View Full Version : LT1 Based Engine Tech
- GTP stage 5
- O2 questions
- Dyno'd,Car dies after 5600rpm,Help!!!
- few questions on build up
- MAC Mids to Pacesetters LTs: worth the money?
- What is up with my TB?
- Mac headers with dual cat y pipe. Whats your opinion?
- Some questions for those with Delteq...
- Mac shorty question
- what kind of pistons with a 355
- car cuts out kinda below 2500rpm, ?
- Machinist based questions...
- Idleing problem...
- weird rubber-rubbing sound
- Anyone heard of CRYO2 from DEI?
- LE2 sound clip
- Finally figured it out
- ARE Nick Agostino moving to new shop watch out people
- Collapsed lifter question.
- lt4 heads/intake worth it?
- DelTec Question
- Shorted Tach Wire, Now What?
- Newbie Here 1997 Z28 w/Exhaust Q'S
- which fuel pump for up to 500hp?
- LT1 Twins Turbos?
- How loud should 1.6rr's tick?
- Sensor Info
- Weird Sound Comming From Engine Compartment
- Injectors...which should i get!
- Comp magnum 1.6 roller tip rockers?
- Are Camaro and Vette cyl. heads a direct swap?
- Did the SS hood scoop work on LT1 cars?
- Installing 94-97 Corvette LT1 in 94Z28 ???
- Car Will NOT start
- Question about MadZ tunning.
- Car randomly dies! HELP!
- Starter gone?
- Which mod next
- Got around to pulling my AIR system, pics inside
- Mourning the loss of my 95z
- winter starting problem?
- What to do with computer when tranny is gone?
- Replaced fuel pump, car is STILL doing the nostart problem. Options?
- AC „OFF“ light flasches????
- i finally made it to the 4 foruth gen
- 486rwhp, 571lb-ft: Fairly Stock LT1!
- cheapest O2 extension?
- L98 heads on a LT1
- E-Brake Cable problem...
- help! busted the remote to my car alarm/keyless entry - how do i disable the alarm?
- Magnaflow or Hooker Catback
- NGK plugs for AFR heads and 250 shot?
- Helm Camaro service manuals for $30
- which plugs????
- egr
- web help
- High end Stutter found
- cheapest place to buy vigilante!cc306 says today junior.
- Who has put 450+ rwhp NA using a LT4 intake?
- AS&M header installation parts..
- anybody switch steel shaft to aluminum?
- VATS Relay Location/Pic?
- car is missing bad help
- Fuel odor
- Oil pressure problem at WOT solved! Fix within.
- Which Valve Springs?
- PCM Tuning 95 Z28
- left bank to lean shoebox help anyone?
- Need Battery/electrical help
- Lloyd Elliots LE3 on 350 w/ stock bottom end?
- 96/97 Flange Gasket Options
- which valves?
- HELP! Heat wont work
- Inciting a Riot: Who has the BEST LT1 Long Tubes???
- What are your Hotcam times???
- Times?
- 100k - cc306 good idea? ::need opinions quick::
- need help
- Scanmaster IAC count question
- Stage 8 locking Bolts? ?
- How close to coil-bind can you run Beehives?
- how to test guage cluster
- MAF reading with cam
- If you had $10K and an empty engine bay... How would you fill it??
- LT's with cutouts
- Changing Water Pump.
- long tubes pain in the butt
- Turn signal switch question
- Guys, why the heck do LT1's pop so bad when you rev them up???
- 8.5mm MSD wires
- Anyone have the part number for the optical part of the optispark?
- changing plugs and wires?????
- Power Steering Pump....
- LT1 purchase source
- TDC ? or BDC ?
- can i do this??
- Looking for Valvetrain Kit..
- Replacing the Starter - LT4
- EGR Blockoff Plate Needed - Anyone have one?
- Borla XR-1
- No start!! HELP - Sounds like its seized?
- at vs m6 tranny mount question
- Car is not starting & throwing codes?????
- i guess flowmasters and shorty headers arent that bad
- How to beat...
- Car died!
- Car does start?? (Was running Rich)
- will i run 12s with these mods
- Where is the best place to get a 306 cam
- Bolt on and N2O dyno numbers inside!
- My goal is to beat 11.9 in the 1/4 so help me!
- what exhaust is this?
- MAC header Q?
- car wont start after heads and cam install
- how to install bottom timing chain gear and hub?
- Question about ORY and Cats...
- cam selection
- 60' on stock stall
- Do new cam bearings come standard with 383 assembly?
- Syclone/Typhoon injectors
- Temperature Gauge quit...whats up?
- Need help with a oil gauge problem
- Oil Pressure
- Backfiring?
- Quick Cloyes Double Roller Question.
- Engine Doesn't Start...Click Click
- What should i do with swaybar?
- 3 warm header tubes Vs 5 hot tubes, Whats up?
- are valves this big possible on an lt1 heads...
- No more K&N air filter for me.
- Freakin' head studs are leaking! Should I switch back to bolts?
- Car cuts out at 5.2k+ rpms, has Delteq, need advice.
- fuel injector clip/harness, broke need replacement
- where can i get a rubber connector hose for my CAI
- wiring trouble still, really need help.
- how to check vacuum?
- Need piston and rod help
- What will fit flat or squared 02 extension for my 96 T/A?
- Just installed PS LT's...w/in
- LT1 lifters
- Anyone running the lingenfelter lt1 supercharged cam in na application?
- Would internally balanced 383 rot. assem. need additional balancing by shop?
- ignition problem?
- Wierd intake question, please help.
- Dyno Numbers
- Alright, need some help guys, she won't start.
- Unstoppable oil leak.
- S-Pipe Constraint?
- Mallory 685 Users
- csi waterpump overheating!!!
- does shoebox have a header install guide
- how can you tell if a crank is forged?(eagle)
- Cloyes Gear Driven timing set...
- Ways to improve our ram-air setup, care to comment on my ideas?
- Could a Fram oil filter cause the oil pressure to go backwards under big load?
- Underdrive Pulley
- Big Injectors and passing smog ?
- Pacesetter Mids/shortie guys in here.
- How much is it to get custom bearings?
- Question about oil pressure
- A few simple questions
- supporting mods for LE2 package??
- TB Bypass
- Fuel Injector tick?
- OBD1 w/OBD2 Plug
- What would cause......
- What is wrong w/ the bolts PS sends..
- golen engines for stroker motors
- whats the min safe oil pres.
- Be Cool Radiators: fitment and installation?
- Oil Cooler seal?
- How to replace a starter on 96, lt1
- Catalytic Converter Question
- where can i get a high pres oil pump and pickup
- What damage can a collapsed lifter do??
- tell me what to do bout my engine rebuild problem...
- Is there anyway to fit ls1 heads on a lt1???
- how much lift can the hotcam springs take?
- O2 Extension Help
- Did my Comp R lifter die?
- Where to get 52mm butterflies for ported TB
- To CAI or Not to CAI ?
- exhaust manifold question
- How to hook up adjustable shift light with the Delteq setup?
- I need a stock LT1 Dyno graph
- 383 questions....how much power??
- Spark plug and o2 sensor ?s
- PACESETTERS REVIEW (so far)
- LE1 heads/cam+install
- Installed my Loudmouth/FIPK
- Gaske dressing question
- Autozone opti # 301833 info, where to get E4 female torx?
- stumped low rpm miss
- how long has your head and cam package lasted
- Intake/heads removal tools required???
- Holy Horriffic Hacked Exhaust Jobs Billy Bob!!! Need Help with Dual Cat LT1 Exhaust!
- Hooker catback vs Edelbrock...
- Ground clearence with Pace Setter LT's on my lowered car... (pics)
- !cags
- Knock
- Will a 355 LT4 setup work?
- 350 hp a4 lt1 or 350 hp ls1 m6 wich is faster ?take a look!
- Future EGR and AIR removal
- highest rpm on stock bottom end.
- car wont start sometimes so I searched and was wondering....
- Econo-Port LT1 Cylinder Head Package
- Wild cam need HELP
- Tach is bouncing and car missing
- Belt Squeeking....
- rocker arm install help
- Accessory Drive Belt Snapped?
- Wierd SES light issue...
- How Strong are LT1 Connecting Rods??
- bad miss after engine is warm! 93 z28
- how many miles on your LT1
- catalytic converter with pacesetter LT
- Timeing
- Torque specs for banjo bolts to back of head?
- carbon buildup on TB and in intake
- Fuel pump install
- Instalation of lifters question asap
- *sigh* Push rod fell in the intake....
- hooker lt people....
- Fuel injector/gas mileage
- gtp
- Intank pump, what to brand? why is racetronix better?
- Anyone Have the New Kooks LTs?
- part numbers needed.
- "Oil Pressure Low at Idle"
- Need Help Asap With Motor Jacking!!!
- Anyone ever heard of Patriot heads?
- Cold Air Brace
- Do i have too much or too little trans fluid?
- A Few Questions
- Computer wont accept scans, among other things
- Why do my spark plugs keep getting loose?
- How much?
- compression ratio ?'s
- aluminum vs my iron heads
- C.a.r.b # For Headers In Ct./ma.
- Running rich, need help!
- Part Number Question
- Racetronix Q...
- Need springs to match this cam
- Pacesetter anyone use them???
- Water pump install???
- Power Steering Delete
- PLEASE READ IF YOU'VE INSTALLED HEADERS - especially from above
- change knock sensor now car throws code?
- fuel problems, any advice?
