View Full Version : LT1 Based Engine Tech
- Camshaft uproar! I'm playing with fire here.
- What the best Smog Legal Headers?
- alternator only putting out 2v at 2Krpms, please help!!
- Advice for the Track
- Need Help Pleasee Read!!!!!!!!!!!
- Coolant in oil but nowhere else
- Odd cooling system problem...
- o2 sensors
- Air foil
- opti install???
- which opti?? ASAP
- Bad intake leak?
- rocker lash setting poll
- Exhaust mani bolts...impact or ratchet off? Reinstall torque specs?
- hard start B#@#!
- Best sounding cat-back for money?
- Recalibrate TPS???
- Single Cat y-pipe fits dual cat camaro?
- MAF not working
- Best aftermarket ignition box mounting locations
- Dangers of the LT4 KM
- hooker headers
- Having major problems with voltage and A/C.
- Plese Need Help Cc305 Prob
- valve springs
- ses light comes on, jerking stumbling backfiring
- where is the air pump located?
- headers
- PCM Programming Question
- air pump fuse?
- Engine problem (loud ticking)
- Oil Spray or Power Steering Spray?
- "You've gotta weak #5 cylinder"...?
- Is this a good deal on GM 1.6 RR?
- Whats the quietest, least restrictive muffler I cna replace my Flowmaster with?
- Why Does This Happen
- Difference between AFR 1100 &1101 series 210cc heads??
- Ex. Manifold Gasket Change Advice
- o2 sensor voltage readings
- Good header/cutout combo?
- Security Light
- attn: madwolf
- Where can I see a '95 Z28 LT1 power curve?
- **Getting my car back from the shop!!**
- STILL intermittent lack of power??
- Is there an alternative to cleaning a K&N filter?
- header tuning?
- How much does your 60' time affect your 1/4 ET?
- What times should I be running in the 1/4
- Its like I'm hitting a wall at 3K RPMS and not wanting to climb any higher!!!
- Cooling
- what kind of gains should I see from 1.6 RR's, LT4 Valve springs, Comp Push Rods?
- OTVC Kit installation??
- Starts Sluggish - Old starter?
- Question about stock manifolds
- "Charcoal" Canister PN and cost?
- Purpose of Heater Valve ASM #10188036
- My car is now stripped what to mod
- Flowmaster Exception?
- Shoebox, Can you help me with a couple of part #'s please ??
- need some help! ignition issues.... grrr!!!
- Best place for 02 extentions.....?
- Buddy's Car Running Bad Code 36 & 42
- Start it up or be cautious
- will 93 V6 springs work on 97
- Heater core by-pass
- temp gauge ?
- Oil Pressure Sensor Loose
- Help with plug and wire change needed
- Need alt part number
- JET HOT Long TUbeds. INstall!!!!
- Glasspack muffler?
- Where to get Racetronics Plug N Play fuel pump?
- car dies after tb install
- What kind of HP should I expect
- exhaust leak
- Where can I buy this rubber tubing or sleeve?
- hitting rev limiter
- Shoebox, Injuneer PLEASE HELP!
- cam
- major engine check up...tune up and???
- HELP!!! Where do I start?
- Cooling Problems
- MAC Header Buffs in here. Help with leak.
- Crank Seal Leaking...already replaced three times!!!
- Compression testing
- Still ne check engine lights from air removal and egr disable.
- advice?
- Now I know how it feels when you cant stop grinning
- Roller rocker install -- need help!
- can i get just 1 wire?
- Hypertech underdrive pulley questions..??
- best place to get a bellow/elbow?
- knock retard question
- High rpm miss
- thunder racing oversized crank sprocket?
- what size pushrods?
- fuel pump kits?
- LLoyd Elliot
- Dont know what else to do...
- alternator?
- Should I upgrade injectors with my mods??
- wtf? new parts = no start
- Could i do True duals with Mac headers???
- 94 z28 fuel system problem..
- DOING REAR SWAP 10 bolt for 10 bolt, few ?s
- what do you guys think of this
- adj fuel pressure regulator
- Car wont crank
- highway
- R & R Fuel Filter
- What Should Your Car Idle At???
- where to put the o2 bungs
- 1:6 roller rockers hit my valve covers???
- jet-hot lt's with 20tl
- tune up
- Wheres the cheapest place to buy OE replacement parts?
- 1.6RR and stud question
- I souldnt be scared right??
- Short Block Rebuilt Kit
- SHOEBOX: need your help with programming
- good deal?
- Best Sounding Exhaust
- Opti failure (again)
- trouble code
- Opinions on the AUTO XRAY scantool
- Pcm....???
- dyno numbers 224/230 112
- Catylitic Converters
- Wet opti
- What are the symptoms of a bad knock sensor?
- MSD Digital 6 Ignition
- quick question
- Grinding noise just off of idle
- Valve suggestions...
- exhaust leak
- transmission problem?
- Universal O2 simulator
- knock sesor...
- Should I be able to VERY easily move my two fan blades...
- Will a SLP LM catback froma 96 Z fit on my 95 TA?
- Plug wires other than OTVC w/LT's??
- pulley help
- Major issues with friends 95 Trans Am
- Radiator Leak
- loudmouth with long tubes
- Jet-hot install problem
- cone filter on stock inlet
- Will these mods get me 300 hp at the wheels?
- weird question
- If you have a LT-1 on a engine stand please read...
- LT1 Corvette engine differences
- Poly motor mounts... Q
- More EVAP system help
- LT1 timing retard and a/f question
- Help 94 O2 Sensor wiring!!!
- fuel pressure probs
- Water Pump Dripping
- Trouble code
- Don't know whats wrong with my car...
- most power limited budget
- Scan readings- please help diagnose
- 1/4 mile LT1 traction
- O2 sensors
- Hesitation above 3 grand help please !!!
- Mu gas gauge is off, can anyone help???
- porting intake for 58mm
- Order of the rockers/valves?
- Finally Dynoed My Car
- Why are there two holes for the outter header bolts?
- Whats up with the 02's?
- Help! Electrical problems!!
- What gears should i go with?
- Building my Lt1 powered Benz ???'s
- Dyno'd my car over the weekend
- Lt1 run on 7 cyl?
- starting trouble?
- Anyone have pics of their engine bay with Pacesetter LT's installed??
- Agree or Disagree with my Cam choice?
- Is a Flowmaster 40 series hurting my performance?
- motor rebuild, what to replace?
- Are u suppose to reuse Flywheel bolts once taken off?
- Driver Side Power Window Switch
- Putting engine and trans back into car, Best way.
- Strange Backfiring between shifts?
- LT1 Scanmaster
- Persistant SES light & idle issue
- code 36 possible causes
- egr removal
- Lloyd Elliott head options
- Can I use my stock lifters with 1.7RR's?
- Old Engine?
- What header gaskets to use with my new Pacesetter LT's?
- engine pullout w/o hoist
- exhaust flow = performance???
- Oil dipstick tube problems!!!
- Starter nose broke off and fell into dust sheild!!
- "Security" Light...
- Car Wont Start!! HELP!?!?!
- water pump install
- Best head/cam combo for maximum torque?
- Guage help
- first 1/4 run tonight for me
- drill holes in TB blades?
- temp gauge
- CC306 in a stock936speed
- TPS Question....
- A F-body drivers nightmare materialized (long)
- headers
- Console Question
- How much of a tune will i need if any?
- Now it smokes
- Wiring diagram
- Header Install Update / questions!!!
- engine modifications
- LT4 Knock Module?
- question about valve springs
- Best Headers for the $
- New Engine
- Car getting hot
- does the LT1 have a "safe mode"
- Clearing codes?
- Header leak...?
- Not using the back alternator bracket? Is that ok?
- cruise control bracket
- oil pressure sending unit?
- Bad fuel pump..replacing with Granatelli
- $2600 for LT1 swap 70K on used motor? sound about right? advice?ASAP!!!?
- Does GM make a Altenator relocation bracket?
- Starter Advise
- Oil pressure...whats normal?
- Need a codebreaker...
- lt4 knock modual
- whats the best adjustrable fuel presure regulator?
- Electrical short somewhere draining battery.
- Madz28 tune on mostly stock car = WOW
- Need advice for replacing my Rotors with aftermarket ones
- Thinking about a cam...
- How to test fuel pressure ???
- Put the 1le pulley in
- water pump?
- 450 rwhp out of a 383
- LS1 swap
- Your input on running the 1/4
- Help me buy this Z...
- left bank O2 wont swing..
- seafoam through brake booster line on LT1 .... best way to use it or no?
- help!! quick speed question
- What is fuel pressure supposed to be ???
- Idle is too high..
