View Full Version : LT1 Based Engine Tech
- Dent in the oil pan
- Would this be a better way, compared to going to a Tuner?
- Best rings for turbo daily summer driver?
- Buying TR6 Plugs
- Anybody tried this: ACCEL 94-97 LT-1 OPTI SPARK DISTRIBUTOR #59125
- 355 Engine Build Advise??
- limits of the LT1?
- Car wont start...
- the 383 runs!
- Is a 3000 stall too much
- Just Removed Waterpump What Hoses Can I Bypass And Eliminate??
- What are the chances to suck water through a CAI?! ---
- auto eprom in a 6 speed car????
- Those who have had the random misfire issue inside please..
- Crankshaft hub install
- Leaving a clowd...
- Busted, host my pic
- So I found a nice little problem with my car today.....
- Plug Gap
- Getting rid of the Opti?
- What tool can I use?
- 97 LT1 coolant dripping.
- 93 Knock sensor?
- LE2 Tune and complimentary parts???
- ignition switch replacement
- Distributor problems
- pacesetter knock question
- O2 sims ?
- LT1 Impala head gasket part numbers
- Corvette/Camaro Hi-performance 96' LT1 LT4 Knock Sensor Module?
- Minimum recommended DCR??
- LT1 Head to Block help!!
- A/C compressor question & help needed
- Gear swap effect on shifts?
- Bronze Distributor Gear Life?
- new 355 won't idle!?
- Best Way To Remove Balancer Without Impact Gun When You Have This Style
- missing bolt in driver side exhaust manifold
- Eratic IAC at idle with 58mm TB?
- Ring end gap and oil control
- Video/sound of my 383 engine
- Le3 heads on factory shortblock, what cam?
- If Brass Plug From Ewp Is Leaking Can It Cause Any Damage To Whats Inside The Timing
- air pump and egr?
- Fuel Leak?
- need help asap
- oil pressure gauge
- accel opti
- VATS Fuel Bypass options?
- Something is draining my new battery
- Stock piston/rod weight??
- Are these lifters any good?
- LE2 dynoed today results
- H/C LT1 results
- clearance issues?
- Tune Up Questions on Z28 I just bought !!!
- NSA or Self Aligning RR's
- '95 z not starting
- Starting issue
- convert from opti to coil pack?
- 94 timing chain
- idle problems...please help
- head removal, looking for tips and tricks
- Stroker vs H/C set up.
- DYNO results are in !! I'm happy :)
- Please someone help me no start
- Accel vs SVO
- False Low Coolant Light
- I can't take it anymore! (surging!!!)
- Another starting problem
- 1993 camaro starter wires
- Benifits of Coating Internal Engine Parts?
- I think I've pinned down my miss/ surge
- 383 lt4 Eating plugs!
- Speed (or other) pro crank and rod bearing part number?
- true duals
- New track times
- Car is coming close to overheating
- What to use for an AIR line to CAT?
- Starting problem - '97 LT1
- Installing High-Flow cats. What do I need to pass inspection?
- Cam dilemma: LE1, cc502, or save for LE-E
- Mysterious oil leak.
- HPPIII Power setting...(reality or not)
- Scary Day...Oil Pressure Sensor Broke
- misfire like crazy over a month in the shop! help plz!
- need help w/ headers and exhaust...
- How to flash replacement PCM?
- LT's hitting heat shield!!!
- Has anyone dynoed an LT1 with long tubes, y pipe, and catback?
- Anyone in the middle of pulling thier pan? I need clearance measurements...
- What kind of E.T.s???
- Black Smoke
- let me hear the milage of LT1's on spray
- car stumbles, idles rough
- fuel problems
- o2 wiring diagram
- 96 LT1 Prob. please help me diagnose.
- Oil pan thread size at sensor
- fitment issues with air on pacsetter lt
- Any Ideas????
- LT1 Rebuild
- Loss of power; bogging?
- 96 LT1 sluggish throttle, and ks count 3000+
- Stock LT1 pistons: ring thickness?
- recommend me a good LT1 smog legal (CA) cam
- IAT resistor mod help
- 1st run at the Track...not what I hoped & some Performance issues. Ideas?
- Cc306
- Different Scanning Tools - Which is Best?
- What is my exhaust?
- New member:Got valve spring question
- Code 33 High Map Still Remainss
- Broke a lobe on crank pulley flange!!!!
- LT1? intake casting 12551238
- How would I... !EGR !AIR !A/C, !PCV
- Timing chain question
- Summit Opti spark sucks
- Will this fire a SES light
- ac compressor bolt size?
- Quick question...Oil Pan!
- Head torquing technique
- 190k LT1 ticking on startup, adjust valves or leave alone?
- Do these readings look like a new engine to you?
- Water/Oil coming out of Exhaust
- grinding off the newer optispark snout for older cam fitment
- Failed Emissions again!
- Stock LT4 - What Mods would you do?
- what mods can i do for free on a 94 lt1?
- GM Part Number for Coolant Overflow Hose
- Muffler in I Pipe?
- Optispark, coils?
- I take it pushrods aren't supposed to spin freely
- Burned Spark Plugs
- Lost header bolt leaving an exhaust leak/what effect will it have on car performance?
- what should i do??
- which autometer guages..water temp/oil temp-mech or elec
- help, car turned off for no reason while driving?
- pacesetter long tubes
- Accel cap and rotor, any concensous on them yet?
- need help 02s work when they want to
- vibration at high speeds Z28 lt1
- Some questions on EGR
- 180 amp alt.
- Wires Pulled out of PCM harness
- cam/tuning question
- pushrod length with le1 heads
- valve cover clearance on rr's
- Got to thinking, how reliable IS the deltec system, really??
- Aftermarket Opti choices for a 93 LT1
- Running rich in closed loop
- Taylor OTVC..
- Will someone guestimate my horsepower output?
- does a stock LT1 need backpressure?
- LE3 383 dyno #s
- new wires?
- repalcing head gaskets soon, need random info
- KEYED CRANKSHAFT HUB for 95 Z28
- LT1 to LT4?
- Pretty sure I found knocking noise - pics inside
- Loss of power
- Scratched my cam?!?
- ticking noise
- Help please - Lights on dash,radiator, ABS, Security
- which Hub?
- Blue smoke at first starts
- 42lb inj on stock motor?
- Burning smell under hood?
- puchrod and rockerarm
- PCMforless tune
- need some info on guideplates
- Rods and pistons for 7000 rpms
- valve spring question!!!!!
- Power steering trouble.... only at slow speeds though
- radiator acting weird.. spits coolant back
- quietest muffler
- 94 LT1 OBD I Bogging
- LT1 bogs under light load
- LT1 backfires
- Et and mph estimates for my 96z28.
- Need some help in California Ontario area.
- Will this handle a 150 shot?
- cutting out at hi RPM
- Code ?'
- Lt1 Injection on pre 86
- Need help - Enging popping and sputtering bad when warm/hot ??
- What intake elbow for 58mm BBK TB
- Just finished motor rebuild..Few question??
- No low RPM power
- ARP-134-3701 ARP LT1/SBC Head Bolt Kit 12 Point???
- Ok..about to bring my block and parts to golen..need some suggestions.
- !Friend in need of some help!
- Why does my Trans Am die in 3rd gear?
- LS1 Headers Going on an LT1?
- rocker adj ques/prob
- alternator problems
- maf question
- Car cutting off
- Car Wont Stay Running
- Fuel injector problems?
- Will a 94 z28 transmission work with a 93 z28
- Convince me I need long tube headers....
- Smoke at WOT ONLY
- 1997 T/A LT1 has me stumped!!!
- All sealed up
- What size Injectors?
- who makes the best opti for the money?
- Anyone ever dyno before and after 58MM on a bolt on car?
- True Duals on Stock Manifolds
- What cat convertor to buy to pass emmisions?
- starting trouble
- Are you all proud of me???? lol
- did i mess up my optispark timing
- Ported heads need work?
- Best brand RR's? Trickflow any good?
- Questions before I Dynotune my 388 ci 96 M6
- So Then What Do I Need???
- stock valve cover clearance?
- Datalog Questions?
- did some mods
- Left bank runs lil' richer than right.
- heads/BRE cam not right??
- Gm847 springs
- Gen 7 DFI/Innovate LM-1 wide band/Accel DFI dual sync distributor
- Runs Rich Exhaust
- '95 LT1 PCM (kinda long)...HELP!
- 1994 z28
- So how does it sound guys? 4"Mufflex
- what springs with le3 cam
- Degreed XFI 218 Cam
- mods. help mileage
- question on block casting #s
- 1.6rr/lt4 springs
- Slight Pop Out of the Exhaust and Idle Issues
- need some help please
- engine cradle
- tunercat tunercat tunercat
- LT1 reconditioning and paint job...
- Darn Car!!!!
- How can it happen without warning like this?
- Need tips for Pacesetter mids install
- good boostable headgasket bigger than .039?
- Car wont start
- 93 z28 headers???
- My 383 Dyno Numbers
- Wireing Headache
- LT1 Oil pan?
- Canton Oil pans....?
- where can I get a NON TCS throttle cable for a 96 LT1
- Horsepower?
