View Full Version : LT1 Based Engine Tech
- Is this a good deal for Crane 1.6 Roller rockers???
- Opti or other issue?
- cat converter question
- Is this an ignition problem?
- car wont start
- Which would be better?
- How bad is it to install Mac Midlength's
- Can I drop motor out the bottom of car in my garage? I have jack/stands/hoist...
- Do I need retainer for my new valvetrain?
- 15w50 motor oil
- Here's a new one for you guys
- Quieter than a LoudMouth, but just quiet enough to not have to worry much about cops
- Fram filter and oil pressure
- Almost time for the install
- Stock manifolds off---new plugs/wires before/after headers mounted?
- I don't think this is normal...
- 93 z28 owners
- where do i get a t-56 swap from?
- Heistation/stumble solved
- Sub-frame connectors and a smoother ride?
- Solid Roller , What do you lash to?
- torque arm trouble
- please respond!!!!!
- Hot Cam people
- Voltage drops when car warms up, alternator?
- optispark help
- Finally Got A Good 1/4 Time
- RPMS jump around at WOT!?
- OVC Ignition wire question
- RPM Issues - Spark related? Datamaster file available
- Side View Mirrors (Camaro vs. T/A)
- Head Porting Problem - Weld Repair?
- Grinding noise
- Quickest LT1 F-body?
- Ah, this sucks a little.
- Headers
- proform 1.6 rockers any good?
- Car feels rough, Freescan log inside
- Install K member with motor in car?
- Anyone Good with datamaster?
- What's needed for 440+ rwhp 383 na?
- OTVC Wire pics?
- Bad problem...I think
- Head selection need detailed advice
- rotor keeps blowing apart
- Undercar rattle when coming out of 1st?
- Noisy T/A Headlight Motors!?
- LT1 trans am vs ls1 Z28
- First Time on Dyno
- computer
- First time dyno, Got to be the lowerst head cam numbers EVER!
- The 1/4 mile woes....13.3, BUT--@ 112mph! what gives??
- water pump drive
- stock alternator amperage? (help: lowww voltage)
- water pump bolt
- First baseline dyno, A/F rich?
- speedometer program
- Fuel Pressure?
- !EGR emissions
- Educate me on Hydraulic Roller Lifters
- need some sending unit help quick!
- MAC Header Spark Plug Access Pics
- SES light is on....and dunno why
- Hotcam kit does it again.
- More Coolant Problems
- help! tranny gauge wiring question
- Cai
- Throttle Body Air Foil
- Jethot LT's + Spark Plugs= Fowl??
- Faulty FPR ->Fuel Pump Failure?
- 224/230 or 218/224 cam with stock heads?
- Running like crap, need help please!
- Stuck on plug change!
- on MAFS and a K/N CAI whats the inches for the rubber coupling.
- lt1 dip stick?
- Delteq
- Hooker Cat-back Q's
- Can i pass emissions?
- experienced engine guys, cam swap advice...
- Doing the T56 conversion, have some questions
- just installed my jethot longtubes
- o2 sensor replacement question
- Anyone ever had this problem?
- Granattelli MAS
- Price check
- Anyone With Jet Hot Lt's Get In Here
- tubing
- Idle from HELL!!!!!!
- Serpentine belt tension? (plug change)
- Idle problem - IAC?
- Started car after pacesetter install without O2's hooked up....
- Changing plugs with JetHot long tubes
- Weird Noise??
- Abs Light coming on
- PCMforless or Madz28 Programming?
- Please let me know what you think
- cam quotes
- Racetronix Pump & Harness Install Instructions
- anyone know gm847 spec's
- SES Light Question
- changed o2's, got check gauges light HELP!
- Electric Water Pump Schematic Question.
- WAIT!! '95 LT1 has peak torque, 325 pounds, at what RPM?
- BMR K members worth the $$
- Need some advice
- coil - replace? or no?
- I want to hear everyone's opinon on whether or not to degree in a cam for the LT1.
- Help Sevice Engine Light!!!
- anyone lost there only set of keys?
- Asap!!! Need Help!!!
- How to tell if you have a B4C camaro
- cams and headers
- Want to make 300rwhp, and am ordering headers need your help!!!!
- EGR flange on MAC headers
- ses light, dtc p0125, any suggestions?
- Internally balancing a 383 LT1
- someone take a stab at this
- Whats the difference between the comp lifters?
- Anyone running non-heated o2s with LTs? (93)
- 96 ss lt1 into a 92 olds wagon
- FANS wont come on AFTER NEW MOTOR install?
- Jet-Hot slip fit Leak
- horse power
- new cam installed
- 93 obdI coversion
- Weird rear axle issue
- Felpro gaskets at Discount Auto? Are they .039's?
- Single cat true dual possible?
- Ready to buy a Ford
- Car is sorta running....
- ECT Sensor
- Major Rattle Sound
- Chose my Fate....Mac's or Pacesetters!?!?
- What mufflers sound good with duals?
- LT1 rods and crank
- Brakes are mushy and dont stop very well... at all!
- Expected HP
- jethot header problem**please help**
- Does 14MPG seem good for city traffic driving?
- Possible Future 383 set-up Need Opinions!
- 1.6 rockers=intake and 1.5 rockers on exaust?
- What will my custom cam sound/behave like?
- Degreeing in new cam
- Need More Help With Egr Asap
- Functional Hood Scoops
- chaning manual tranny and rear end fluid ?'s
- Dyno in NY?
- Roller rocker advisory!! Please read.
- 94+ injectors in a 93 LT1
- Need Help Asap On Headers!!!
- Strange noise
- o2 or injector?
- Code 82
- New here...stupid oil pressure related question...
- question about new sound from dry engine
- HVAC check valve cracked
- Carbed SBC Conversion Info NEEDED!!!
- can i remove the guide plates and just run self alligning rockers
- Lunati cam specs
- Air in Cooling System
- Coolant crossover tube part number??
- Frustrating problem with spark plugs HELP
- Car wont start....!!!HELP!!!
- POst header install problems...
- CC305=12.0 (N/A)=passed emissions
- delphi OEM 02's?
- Bearings/Rings right part number??
- Clamps for the intake?
- need some help with a erratic runnin h/c car
- what is everyone running with these mods
- header soundclips?
- Possible Reasons for studdering
- Opti Spark
- 383 performance numbers
- tips for removing my SLP cat-back exhaust???
- Bigger(lower hanging) Air Damn
- Problem Need Help with vibration
- CAN I eliminate my EGR this way??????
- AutoTap Users?
- Dynoed The Car, Have The Dyno Graph On
- Non-functional SS Hood - Affect Engine Cooling Temps?
- Corvette Fuel Rails
- Overheatinf because of air pockets in cooling sys. Blown Head?
- why does my car have a split personality?
- Painting block, heads, intake
- How do you check for a collapsed lifter? (comp r's)
- Wouldn't 0psi oil pressure cause serious tapping?
- h/c install underway
- Lingenfelter or Moroso CAI ?
- Just got to thinking about VSS and my dyno run....
- 300 rwhp
- What do u scan ur cars with?
- lt1 cam ?
- How does Autotap figure AFR off the PCM
- exhaust system
- Pulling pistons
- True dual exhaust or Y pipe
- Im looking for a cam.......
- How does a WS6 intake attach to the maf?
- stock crank pulley
- LT1 kit for SLP loudmouth?
- beehive springs
- What kind of exhaust should I get?
- LE heads
- coolant flush went wrong...need help quick
- 94ta
- What Motor Mounts to get?
- Best Octane for Aluminum heads/intake
- How to run low 13's
- How much HP gain
- choppy accel at part throttle
- black smoke! car won't run! help!
- Am I missing my pcv valve???
- will 94 caprice ecm work in obd1 coversion camaro m6?
- 1LE A/C Delete Pulley
- Need help ASAP!
- Buying 1.6 RR's and LT4 springs. Have quick ???
- Pacesetter exhaust....
- Feels like im loosing power?
- Cooling woes
- Timing chain
- Anyone not happy with the hooker catback?
- Help me pick a new clutch
- Problems...
- Car Won't Start!!
- 3" cutout installation
- ASAP Did some work, car stalls out when you engage the clutch to began braking ASAP
- HP Estimate
- Elec. H20 Pump Wiring Problems
- vats question
- Will this oil level sensor work?
- Cant find power steering fluid leak...
- oxygen sensor pics
- Starter Wiring
- Cheapest place to buy hooker catback?
- has anyone seen this before
- List of causes for no start
- electric water pump, regular or heavy duty?
- Chop off the Catback?
- 93 transam wheel stud length
- coolant crossover lines plugged in the back of heads?
- gm847 users
- LT4 Knock Module
- What temp does your LT1 run at
- head swap
- Could this be caused from a optispark?????
- 1:6 roller rockers are they supposed to be loud
- ARP thread sealant *URGENT*
- CC306 Spec
- Speedo stuck at 160mph
