View Full Version : LT1 Based Engine Tech
- cam question( Crane 210/224)
- moser 12 bolt now grinding over bumps??
- mounting unbolted exhaust
- Removing injectors from fuel rail
- Solved the opti-spark conspiracy
- Emergency...cmon Guys I Need Help Like Yesterday!!!!!
- Finding exhaust leak.....Midas????
- Help w/ Removing PS Pump
- help me with my tranny pleaseeeeeeeeeeeee
- Firewall seal
- Wiper Motor gone bad?
- $5000 to spend- mods or upgrade?
- HELP! Need Reply Fast
- What the He!! is the problem?
- Recommendations?
- 4.10 gears
- How do yoy remove the air pump with out throwind codes?
- Compression ratio and 91 octane fuel
- Is there any advantage of blocking the egr?
- Huge Problem....please Look....fan Trouble
- Mysterious oil leaking problem
- 1995 Camaro Z28 Maintanence HELP
- Evaporative Emission Control System Malfunction
- Best Clutch package on the Market
- Removing ASR and keeping ABS... did a search, no info
- extending o2 sensors
- Squealing brake... what are brake shims?
- What size bolts for tranny brace?
- 2.73 to 3.73?
- adj. FPR with xe cams
- installing headers soon, any tips?
- manual cutout
- headers
- Car broke down 200 miles away, need wheel base measurements
- Would this be my pulleys making noise?
- Tire Opinions / Advice
- Goin for the dynomouth... what size bullet muffler do I need?
- Did you say yes or no the the power tuning on your hpp3?
- Which rockers to adjust when?
- Ignition won't turn over????
- Opinions on Collector Inserts
- 115 speedo??
- Best Heads
- obd check
- SLP Loudmouth vs Hooker Cat Back
- Is my tranny going bad?
- Thunder Racing Complete Gear Package??
- fuel pressure?
- Only when its hot
- How hard to R&R Slave Cylinder/MC
- G2 sway bars...Worth it?
- Can I use a Autometer Oil Pressure guage and keep my stock gague too.
- All guys with Headers....
- abs inop, no idea???
- Does anybody have a pic. of the speed sensor rotor installed in a TH400?
- Fixing to order exhaust
- 4.10 question...please help
- Will 4th Gen PHR fit 3rd Gen?
- Please!! help with oil leak..Im at my wits end.
- engine coolant light goes on and off!
- Where to get rebuild kit for Eaton Posi?
- SES light on. Code 32- EGR recirculation?
- 58mm TB or not?
- Engine Sensor Fuse Keeps Blowing???
- Ram clutch info/ Novel inside
- Vaccuum Line Problem? (Please Help)
- Long tubes vs Mid lenths
- Power steering problems
- TB bypass- barbed connector from Pep Boys?
- What size AN hose for fuel pressure guage?
- Installing a Tach
- T-56 output shaft bushing
- Stage II Clutch, pedal grabbing ?
- 4L60E Rebuild
- Who makes DS safety loops for our cars
- Daytime running lamps for 95TA
- Longtube or Shorties
- Cam rusting?
- Ugh! MY Headlights Again!
- Stalling problem
- free mods?
- Dynomouth exhaust questions
- Off the line troubles
- So I'm removing the opti and....
- water pump gear replacement
- Can rear diff be rebuilt?
- brake line fittings: standard NPT or metric threads?
- low coolant
- has anyone heard of or using "cartech" clutch?
- Tire pressure for michelin pilot sports
- New shocks.....any suggestions (looking for ride comfort)
- Caliper Question
- Anyone replace the oil pressure unit on their car??
- Car just turned off
- Fan Switch question
- Rear Main Seal Install-help Needed
- Could me and my buddy convert my car to a 6speed?
- Will an M6 tranny from a '93 fit my '94 M6 swap plan?
- Dead Clutch --> Puking Fluid ??
- should brake pads touch rotors when brakes not applied?
- What wheel/slick combo can I run
- Can I put a TH400 tranny in my Z?
- New Tailshaft Housing Bushing ... Problems now!
- A4 guys with ET streets & 10bolts??
- Is ceramic coating necessary?
- My ignition keeps getting stuck???
- Too much porting on LT1 heads.
- What Rev limit with Hot Cam kit? Shoebox?
- coil wire question
- Buyin an LT1. PLEASE HELP
- fish tailing car
- Wheel Base
- Transpak
- Hooker LT Custom Y Pipe Pics?
- ? about wheels
- 383 Stroker kits
- Holes in block above oil filter...
- best place to buy or get a 4l60e built?
- Need help quick with tranny mount
- If I get EGR block off plates...
- Fan problem (shoebox?)
- Scanmaster Code
- Doing clutch swap soon, any special tools/parts needed?
- Anouncement
- Time for U-joints. Should I upgrade to an aluminum driveshaft?
- K-Members
- Anyone make a bolt on radiator that's better than stock?
- Identify this part and earn yourself a cookie
- Really bad miss throughout RPM range
- 2 series carrier?????????
- Engine shop
- Car Chemistry's CCinserts?
- Compression Calc.
- Oil pan plug stripped
- Fastest 1/8 mile times with Hotcam?
- PCV Valve question?
- WOT oil pressure only at 40 ?!?!?! is that right?
- New to LT1s is what I am hearing piston slap?
- my new supercharger
- Front tires change 1/4 mile
- Transmission Noise
- Need instructions: LCA's and Relocation Brackets
- eliminating ABS
- Incorrect tire height on hpp+
- couple of Ram-Air questions
- LTCC users... any long term road test results?
- Fenco/Dnyapak clutch?
- Carbon build-up in TB
- PLEASE HURRY!!! - in the middle of TB BYPASS
- coolant problem
- Torque conveter Qs
- Rear wheel clearence!!!!
- Help Shoe Box or anyone who knows about vacuum Lines!
- Question on Exhaust System I Just Found
- Where to buy the LT4 Starter?
- Where to get TB airfoil?
- Dyno Tune?
- how long are platinums lasting?
- Tranny
- help me out guys - a4 tranny
- Valve Cover Breather worth it?
- changing gauge cluster
- 3 core brass or 1 core aluminum, which is better?
- After AC delete, can I mount the alternator low?
- Hooker Aerochamber Muffler, do I get a 3" ?
- Which headers
- How to spend $450
- Aliging the Rolloer ROcker
- a real quick gear question!!!
- Tranny said "BOOOOM!" WTF!!!!!!!!!
- What all do i need for over the valve cover wires?
- 94-95 headers on a 97. Please help!
- Quick question about my MAF
- Quick question about door glass...
- Fastest CC305 Car?? 350 CI???
- Advise for M6 removal???
- Shift kit or not?
- Just got PCMFORLESS tuning done...very happy.
- is the cc306 a good daily driver cam?
- Why is this giving me such a hassle
- witch tire
- What size, thread bolts for tranny mount?
- A4 question
- park brake light stays on!!!
- Cutout vibration
- Bad plugs?
- Will my intake bolt right up? Heads milled .030, .029 head gasket...
- trouble starting car after a good rain
- Installing Airbag in Rear spring?
- CC306 vs GM847 vs XE230/236
- Factory Engine Balancing
- Mech. fuel pressure gauge
- anyone running hot before pcmforless
- Price on install
- Need help locating where this emmisions stuff goes?
- First time at the strip!
- tire question
- if i put a cutout a bit before the bend is it gonna be too much vibration?????
- My car won't rev past 5600 in any gear other than 1st!! Please help
- brownish red coolant
- Fuel pressure regulator maybe no good...
- Can i just change the cam?
- iron heads
- tranny problems
- LT4 hotcam or NX kit?
- why does my low coolant light keep going off.
- Could this be solution to my Overheating?
- Pics of some buddy's LT1's @ my house!
- T-stat removal?
- Need this ASAP. Can anyone helP?
- Dyno Results and catback! compare vs. flowmaster
- ? for all the lt1 guys about loudness
- will ceramic brake pads chew up brake rotors?
- TORQUE, where art thou
- Brakes work poorly, vacuum related?
- What size exhaust cut-out?? HELP QUICK
- Can I use a remote from a 2000 firebird?
- pop up light noise
- Signs of bad injectors???
- DCR and Fuel Injection/Carburetor
- AS&M Headers question??
- Ok, 1-2 Shift Is Good Now, But What About My 2-3?
- which exhaust???
- How hard is it to install headers?
- Airconditioning woes
- TurboLink 4.0 OBDI Scan Tool Now Available
- Weld Draglite recommendations for the rear?
- How to remove my PCM?
- How much NOS can a stock LT1 take?
- Power stearing pump install??
- Head/Cam swap info
- Crossmember / ds loop question
- What mufflex? 3.5 or 4"
- long tube install
- y not turbo charge?
- hesitation after injector install... why?
- Pilot Bushing....take a look***PICS***
- 02 simulator "do it yourself" version ?
- Signs your running rich...
- A4-M6 guys, reverse lockout not working..
- 2.73's to 4.10's... what gains should I expect?
- Knock module question
- Bypass heater core?
- What Engine Mods Next?
- Theorhetically
- Jacking Points???
- Anyone have any pics of over the valve cover wires installed?
- Thunder Racing
- Loose header bolts
