View Full Version : LT1 Based Engine Tech
- Is there anyway to fit ls1 heads on a lt1???
- how much lift can the hotcam springs take?
- O2 Extension Help
- Did my Comp R lifter die?
- Where to get 52mm butterflies for ported TB
- To CAI or Not to CAI ?
- exhaust manifold question
- How to hook up adjustable shift light with the Delteq setup?
- I need a stock LT1 Dyno graph
- 383 questions....how much power??
- Spark plug and o2 sensor ?s
- PACESETTERS REVIEW (so far)
- LE1 heads/cam+install
- Installed my Loudmouth/FIPK
- Gaske dressing question
- Autozone opti # 301833 info, where to get E4 female torx?
- stumped low rpm miss
- how long has your head and cam package lasted
- Intake/heads removal tools required???
- Holy Horriffic Hacked Exhaust Jobs Billy Bob!!! Need Help with Dual Cat LT1 Exhaust!
- Hooker catback vs Edelbrock...
- Ground clearence with Pace Setter LT's on my lowered car... (pics)
- !cags
- Knock
- Will a 355 LT4 setup work?
- 350 hp a4 lt1 or 350 hp ls1 m6 wich is faster ?take a look!
- Future EGR and AIR removal
- highest rpm on stock bottom end.
- car wont start sometimes so I searched and was wondering....
- Econo-Port LT1 Cylinder Head Package
- Wild cam need HELP
- Tach is bouncing and car missing
- Belt Squeeking....
- rocker arm install help
- Accessory Drive Belt Snapped?
- Wierd SES light issue...
- How Strong are LT1 Connecting Rods??
- bad miss after engine is warm! 93 z28
- how many miles on your LT1
- catalytic converter with pacesetter LT
- Timeing
- Torque specs for banjo bolts to back of head?
- carbon buildup on TB and in intake
- Fuel pump install
- Instalation of lifters question asap
- *sigh* Push rod fell in the intake....
- hooker lt people....
- Fuel injector/gas mileage
- gtp
- Intank pump, what to brand? why is racetronix better?
- Anyone Have the New Kooks LTs?
- part numbers needed.
- "Oil Pressure Low at Idle"
- Need Help Asap With Motor Jacking!!!
- Anyone ever heard of Patriot heads?
- Cold Air Brace
- Do i have too much or too little trans fluid?
- A Few Questions
- Computer wont accept scans, among other things
- Why do my spark plugs keep getting loose?
- How much?
- compression ratio ?'s
- aluminum vs my iron heads
- C.a.r.b # For Headers In Ct./ma.
- Running rich, need help!
- Part Number Question
- Racetronix Q...
- Need springs to match this cam
- Pacesetter anyone use them???
- Water pump install???
- Power Steering Delete
- PLEASE READ IF YOU'VE INSTALLED HEADERS - especially from above
- change knock sensor now car throws code?
- fuel problems, any advice?
- current mods vs. stroker
- lt1 lifters
- Car lurches when driving slow
- Does anyone make a REV kit for an LT1 other than AFR?
- help! Driveshaft ?'s
- Dilema.
- installing a bigger fuel pump??
- Camaro with Z rated tires
- Tips on cleaning out fuel tank (out of car)
- Wont stay started
- 93 Camaro Z28
- Stock 10-bolt w/ cam?
- New Era Performance Parts
- SES 420 what to do now?
- 93 Camaro Z28 engine jerking!
- Injector Problems
- suppose you had...
- What is the valve angle on LT1 heads??
- HELP!!! BROKE SOMETHING DURING INSTALL OF LTs - need part #
- Stock replacement lifter part#?
- Cam needed to run low 12's?
- limit on the lt1 crank?
- New to Camaros and LT1s -mods advice???
- Beginning my 383 project.
- pushrod question
- pulling motor
- FYI about traction Control
- Moving Knock Sensor
- HEADER install in PROGRESS
- Changing muffler to bullet
- Another Comp Cams XE 236/242 question
- Maintenance ideas @ 100k
- need quick thoughts. german castrol 0w-30 on a 4.3 V6??
- 94 motor help supercharged
- Those running COMP 941 springs inside!
- 93 LT1 exhaust maniflod question
- 52,58 and brand of tb questions..
- those of you with 32# inj. i need info please
- Camaro ram air ???
- Would oil pres. going down under acceleration mean cavitaion or drain back issues.
- Gaskets for Pacesetter LT's
- denatured alcohol in gas tank
- SA? NSA? Help.
- Question about reading oil pressure from a 93-95 camaro dash
- Does any one actually have ported Trickflows?
- Help, very bad steering problems.
- Tan DLC wire question
- Installing aftermarket pan/pump, any advice (do I have to pull the motor?)
- Car wont start after warm up.
- Some one Tell me whats going on Here!!
- cam question...
- Cold Air
- Installing oil temp and coolant temp senders, please help!
- 97 1le car question
- difference in plug wires???
- LT-1 dimensions & glossary of terms?????
- Cooling "?"
- What are the chances...
- WP Drive spline chewed up
- CAI SLP or KN
- What Spark Plug Wires?
- Metal strength question
- SS conversion question
- Tuning questions????
- Carb setup on a FI LT1?
- Is it time for a Bigger amp alternator
- Throwing P0172 Code
- Which size of injectors to use for my bottle feed-383ci?
- need some opinions on what to do next???
- changed wp and csi and now car will barely start.help!
- Really Really bad miss!
- Need GM part number
- Stock Chain
- 1/4 Est.
- I found a couple cams for cheap...
- Lost!!!
- GM847 camshaft
- ????Cleaning Stock Rubber Intake Parts
- LT4 starter difference
- Daily Driver: head/cam or turbo?
- Oil pressure and engine temperature...do I need an oil cooler?
- ACDelco or Bosch
- Where can I get an adjustable master cylinder?
- Hypertech Powerscan and PC-link
- Bullet muffler to replace resonator???Help
- 846 dyno graph or #'s ????
- Kooks, Jet Hot, Pacesetters?
- Ceramic or Stainless?
- Head ideas
- Ignition Switch or the key lock and tumble??
- harmonic balancer with underdrive pulley removal
- Need help with part #s and prices
- No Spark!?!?
- lifters for cam install
- Strange noise
- bosch fuel injector part numbers????
- need wiring experts badly
- rebuilding t-56 transmission parts ?
- Odd oil pressure on new rebuild, come inside everyone.
- Cutting out water trap in Ram-Air hood. Is it safe to run a straight through ram air?
- RPM surge + check engine light
- lash question
- Wiring the New Fans tommarrow!
- Beehive 26918 vs. 26915 = no change
- Gettin a tune
- Please Help Code 42,car Dies At Wot!!
- oil pum and pan questions for a 383
- f/i to carb questions
- opti spark question
- Pic request . Over the axle tailpipes on a true dual car .
- Fuel injector size selection
- How much for 383 upgrade if done right?
- z28 will start then stop
- What heads for 450+rwhp?
- Roll bar going in..........
- fuel line retainer clip help (broken clip)
- Knock Module replacement
- Stock casting heads how big can you go on valves?
- How do I know if this car has a new shifter?
- Another happy Madwolf customer
- Fan Relay and a stripped sparkplug
- Camaro is dead again
- Should I put in a cam in it?
- LTCC install pics (FINALLY FINISHED)
- heating up
- does someone make a strut tower brace for the 97 SS Camaro??
- help quick!just cracked wp replacing sensor what to do??
- long tubes i searched and couldnt find nothing
- belt question
- So I just finished my T56 conversion and
- Hard starting and bad idle
- 4 speed auto fit check
- Will these heads work?
- 1.7"s vs 1.6"s
- SES Light Flashing Intermitantly...
- 3/4 or5/8 inlet for oil pickup screen tube for '95 Formula
- last header bolt on passenger side
- Car acting weird!!!!HELP!
- what would happen?
- What happened?
- Car Won't Start After Air Bag Removal
- I think my starter is going:(
- need help with driverside header install
- 2 Piece rear main seal crank in LT-1
- Z06 injectors in a LT1??
- quick question What size of tool to adjust the Throttle Body Plates?
- Would wrapping your plug wires in aluminum foil help keep them from burning?
- My first logged WOT after installed Scorpion RRs
- What's the problem with my starter?
- *PICS* CSI waterpump question HELP ASAP !!!!!
- intake elbow
- Throttle body won't close
- Rod bolt sizes.....
- 100K to disable OBDII knock sensor??
- Cost to Rebuild Solid Roller Lifters?
- steam pipe???
- 93 Lt1 Firebird Update To 94 And Newer
- Basic LT1 Q's
- Firebird Headlamp problem..
- Best Fuel Prump
- Black Box over driver side valve cover
- Finally Found the Valve Cover Modification Link
- pcm bad?
- V6 Springs?
- Problem w/ 700R4 rebuild, 250psi all the time
- .:: engine rebuild in spring - what to rebuild with
- CC 306 QUESTIONS From people who have done them
- Venom 400 Performance Control Module !
- hotcam question
- Do LT1's and LS1's have the same pedal assemblys?
- Blower 93 Firebird Detonation
- Please help me find my oil leak.......
- pulling motor soon, q's on buildup order
- Delteq/LTCC Cost Analysis
- Change Valve Springs??
- What kind of numbers will I see?
