serpentine trick
Old Jul 20, 2003 | 07:45 PM
ImaginerStudios's Avatar
serpentine trick
Just wondering if there was a trick to getting the serpentine belt on easy. I have been working at it for an hour, and can't get it on the alternator.
Old Jul 20, 2003 | 07:48 PM
AsianSensation's Avatar
The last place you want the belt to go around is the tensioner. If it helps, have somebody to hold the belt in place around the alternator. I am able to do it myself though.
Old Jul 20, 2003 | 07:53 PM
that would be the pulley to the lower right of the alternator right?
Old Jul 20, 2003 | 08:04 PM
Right here
Old Jul 20, 2003 | 08:08 PM
Timberwolf's Avatar
make sure you are taking the tension off the tensioner pulley, that will give you the extra room to slip the belt on
Old Jul 20, 2003 | 08:22 PM
I thread it around all the pullies and leave the crank pulley last. Pull on the tensioner for some slack and slip it over the crank pulley. I do this from under the car.
walt355
Mar 16, 2016 09:35 AM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
Cam's maro
Aug 11, 2015 07:45 AM
alphaauto
Jul 26, 2015 04:40 PM
