View Full Version : LT1 Based Engine Tech
- Any have dyno numbers for Combination Motorsports 227/233 cam?
- Fuel pressure regulator go bad???
- msd 6a question
- Removing intake Manifold how hard?
- Quieting down the exhaust...
- top end rebuild problem
- Lets see your true dual setups.....
- should i buy a crate motor
- Delteq and Opti
- time for a Buick.....LoL
- What differance with cruise control delete?
- Looking for pic's of 383 bottom ends
- fuel pressure help!
- Pro's & Con's of the AFR 227
- Injector Sizing/Duty Cycle for high HP Solid Roller 383
- headlight motors
- best place to buy a built 700r4?
- Edelbrock Headers
- Tp airfoil good for?
- murray ac compressure
- no key on crank hub???? HELP
- LTCC Installed on 94 Vette, tach problems Please Help!
- Good thing I was bored....
- ATTN Shoebox 96 TA Fan Prob
- delete 2 injectors to pass emissions???
- 1LE bushings (Shoebox?)
- Car wont start, Good Fuel
- spark plug gapping
- Got car back from head/cam swap....now wont stay running
- Cam on stock airbox/Filter
- Which cam would you run out of these 3?
- Anyone know how to get CAM dyno tuning in SoCal?
- How do you get the Yellow plug off the top of the fuel pump.
- Help needed after engine swap please!!!
- Runs good until open loop
- after jacking up motor, oil pressure guage?
- Help i want cam and RR
- Altjar inside plz
- 3600 Stall And Stock Cam And Gears?
- really strange problems are driving me crazy
- How do i tell what Series Flowmaster i have?
- Low Rpm miss, vaccum leak?
- what would you do (bottom end rebuild)
- Racetronix Vs. Casper fuel pump harness?
- new NGK iridium plugs(1 range colder), good for juice??
- I Swear
- Attention: Anyone having a problem with an unsteady idle
- Ignition/Electrical Problems
- cam swap
- Hows this sound
- Hey Ion (madwolf)
- lt4 knock
- Low coolant sensor
- Bad Misfire/sputtering!! Need Help!!
- Flowmaster NEW SPECS!
- Mix and match SFC's, Exhaust, Torque arm and rear end
- Please help me with pulling balancer and hub!
- Center Console ?
- Quick questions about RR's and such
- intake elbow
- 5 grand idle ??
- What to do with this wire? also a burning question?
- The police don't like my exhaust
- How screwed am I? Piston Catches on Block...
- AFR Hydra Rev on CC R Lifters
- New Rings for Stock Pistons
- headers glowing and getting spark out of a few wires
- hollow out cat or high flow?
- Need help with running rich
- car wont crank i got codes please help.....
- 93 z28 won't start...
- lt4 km or lt1 km
- New Opti. New Sputter??
- Oil pressure gauge is not working properly...any help?
- High 11's to mid 12's w/ Midlength headers?
- Starting trouble
- Jesel shaft mount rockers?
- LT1 Accessory mount brackets
- Using Stock Push Rods And Lifters On Cam Swap?
- xe224/236 with 4.56s in over my head???
- anyone running 1.7 rockers with 227/233 cam?
- HELP...ASAP RR Adjusting on a SR
- SES Light, help!
- Anyone port their own intake?
- how to get the underdrive pulley off
- Can o2 go bad from sitting and can you clean 02s..??
- difference between stock replacement and comp "r" lifters with cam
- SBC true double roller on LT1
- speedo error?
- oil pressure at redline....need some advice
- Waterpump shaft removal
- Rocker arm preload?
- K&n long filter part number?
- Lloyd Elliot heads
- GM847 owners inside
- Best Cam/Rod/Main bearings for cammed LT1?
- Wal-Mart cost me an LT1 today....
- V8 Swap done, few questions??
- Question Concerning LPE Cold-Air Intake
- Anyone else have this leak?
- 1.7 roller rockers on my stockish trans am
- need help with leak
- Vaccum Question
- Upgrading to a Hotcam, need to know about RRs and Springs
- Problems after LT install...
- Timing ?
- MAF Problems
- Starter Relay Location
- MTI Heads - Valve Spring Question
- LT1/LS1 upper radiator support
- O2's causing hesitation. Couple ?'s....
- a few questions about about long tubes
- At what age did your opti crap out?
- Pulled motor out from the bottom, did I screw myself?
- need help with ticking
- Umm code 16? Low resolution something... Help...
- Uh Oh...need ideas! Sounds like im outta gas!
- EGR Feed Pipe with headers, and the AIR system
- Spark plug condition decoding.
- Narrow Body or Not
- Progress on plug change. need some help
- All Bosch O2 sensors junk??
- Cam Install
- How fast are the 383's
- Huge leak after oil change.....
- adjusting rockers with big cam
- XE 224/230 112 LSA Installed Pretty Lopey!
- New CC306/stock heads times
- I need a little help diagnosing a problem
- corsa and LTs on an LT1?
- Lowest price for dash top panel ???
- losing fan relay fuse when starting
- All Hooker guys... in here
- PRICE on Fixing blown head gasket on 96 TA LT1
- How much n20?
- T56 Conversion or Hotcam?
- TPS Sensor
- wow, i feel like an idiot. figured out the high RPM miss problem
- Flush radiator
- roller rockers and poly locks!!!
- What next??
- whats these hoses for
- Help me. Name this so I can replace it.
- coolant leak mystery please help me!
- Motor mount?
- Secondary Air Injection Check Valve
- GRRR Please help car wont crank!!!!!!
- Anybody cracked an LT1 block before?
- what psi for ET streets
- Overheating help
- Mac header leaks...
- 2nd cat
- Valve Spring Lift
- Oil Pressure Concerns
- Overheating problems with 96' T/A
- Starting to notice some trouble starting my car.
- How do i use dielectric grease, and should i?
- lt1 head research
- What are the odds of..
- need idle opinions
- 383 No start
- Dynatech header ?'s
- 350 buildup questions
- can i do anything to the starter from the top
- heater core
- Air Bag light on after engine swap
- What is this?`
- Hard start after heat soak.
- picture of waterpump anyone?
- Pacesetter Headers vs. Steering Linkage
- fuel pressure numbers- please help
- Where to buy coupling from TB to trick flow/vortec elbow....
- LE2 H/C dyno results.
- Thinking of using MSD universal plug wires instead of Taylor
- idle in gear, rpms climb.
- Got Smoke?
- Should I dyno today a 1pm...LE2 H/C package?
- How To Install Headers On Lt1
- Safe use of Nitrous?
- P0101 - MAF System Performance
- WTB: Moroso Air Intake and air foil
- No power running rich very rich.
- Going for 385CI with CC306, What is expected HP/TQ?
- car won't go into 3rd on my a-4
- yet another LT1 miss at high rpm thread
- Getting a Magnaflow Exhaust
- What kind of mileage do you actually get?
- Track times - cutout experimentation
- True Duals Vs. Y-pipe to muffler exhaust
- Throttle Body application
- 94 z28- problem with msd btm unit??
- Thermostat hypertech or other?
- Anyway to program existing BCM (1996 car) to pellet on key?
- Headers (which?)
- Broke My timing Chain
- What Valves?
- synthic oil
- please help
- Do I have a catback or muffler only exhaust system (pics inside)
- good fuel pressure still wont run
- stock fuel pressure?
- WTF.....no clue whats goin on, help asap please
- Dumb throttle cable question..
- installed cc306 now brakes suck
- can header coating foul O2?
- Just fired up the new setup..
- Newbie!!
- Early SBC headers on 94' LT1?
- Clutches???
- Should I Buy?
- FIPK won't work on cars with traction control?
- Egr question. Need HELP
- How can I get my 58mm BBK TB to work right
- dual cutouts
- Just got back from the track.....some problems
- Where does the oil come out of in a rear main seal leak?
- Feels Like Car Runs Better When It Hot Outside Than At Night When It Is Alot Cooler
- Cyl head HELP
- Flywheel grinding?
- What does a Bare LT1 block weigh?
- disconnect exhuast after cats? help or hurt 1/4
- high rpm stumble (jerk)
- Cam upgrade--Do i need to change---
- Poly Busyhings Bad? Opinions wanted :)
- OBD2 plug in emissions test, and a 396.....
- Powdercoating block after assembly?
- Any secrets i should know when installing valve spring locks?
- Upper RPM hesitation
- How the hell do you bend a cam
- Scanmaster: DTC Codes 18, 36, 46, 51
- What happens when the PCM goes into "limp mode"?
- Summit Sells LT1/LT4 Connecting Rods Now...
- engine is missing need help.
- These Fans Work?
- Ready for Cam...
- Hopefully my final VATS question. :)
- Royal Purple?
- Walbro 255 install Q
- Water leak
- Help! Got wronf Flywheel! What Flywheel does this go to? PN 14088671
- 94 Cam in a 95 LT1 opti issue..suggestions
- Did Some 1997 Camaros Come With The Ls1?
- Getting No Power at all
- O2 problems?
- Flowmaster won't Fit!!!!!!
- Stock bottom end & intake on CC306 setup... lots of ?'s
- lt4 standard cam question
- Changin Plugs tomorrow
- headers way to hot,, glowing,, help
- IS anyone else hear searching for that MYSTERY coolant smell ???? I FOUND IT !
