Cleaning Coated headers
Old Jul 21, 2003 | 10:52 AM
unTAmedLS1's Avatar
How can you can clean them up. I think tar got on mine and its kind of alot and I want to get it off but it of course is pretty stuck on there from the heat
Old Jul 21, 2003 | 11:27 AM
Not easy to do.... My old JBA's were coated ny Air Born, and the instructions that came with the headers from Air Born said to clean the headers with a Scotchbrite pad. I tried a "medium" pad, and it worked fine... did not scratch the coating, but removed residue from a nylon tie that had melted on a primary tube.
Before you start rubbing away with the Scotchbrite, test it somewhere not too obvious. It worked on my Air Born coating, and that coating was extremely high quality, based on what the headers looked like when I took them off after nearly 3 years. But some other brand might not be as hard... so PROCEED WITH CAUTION.
Old Jul 21, 2003 | 02:06 PM
unTAmedLS1's Avatar
Cool thanks for the reply mine are the sterling silver jet hot coating.
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 5, 2015 09:56 PM
drptop70ss
May 4, 2015 08:22 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
