View Full Version : LT1 Based Engine Tech
- bad motor mounts?
- Wheel Fitment ?
- WTF!!! car dies when put into gear!!!
- Tire Question!..
- Easy newbie ?
- Hei
- Is there a valvespring kit compatible with 1.7rr's??
- Permanent Cooling System Sealer?
- Second thoughts
- how much?
- Fan relays
- Does this seem heavy to you guys?
- Tie rod end dust covers???
- IAT Resistor Mod....
- Are new BFG TRACTION T/A's any good?
- con rod's
- Wierd Bogging problem after heads/cam
- Routing MSD8.5 wires with headers
- are stock Lt1 heads cast iron or aluminum?
- SPark plugs platinum ripoff?
- Pulling balancer and crankshaft hub
- busted sensor what is it? (PIC)
- Temp. Sensor
- aluminum driveshaft
- What size bolt is the alternator-to-battery nut?
- lt1 balancer
- Help!! Installed Fuel Pressure Gauge/white Faced Gauges...have Problem
- What is at the top/rear of engine that would cause a loud squeal?
- Wester's computer programming
- What did I do???!!!??? HELP!
- fuel-tank level gauge
- Cone inserts for loud exhaust....Anyone got any opinions??
- lost all my tranny fluid tonight, I hope I'm not screwed - 700R4 problem
- Eagle H beam vs. Scat I beam for a 383 rebuild
- new maf madwolf or tuning experts..
- Car won't idle
- What headers should I get?
- Scanner, worth the dough?
- Question about borla
- SCAT 3.75 crank ver forged
- Free mods
- Urgent!! Stranded Need Your Help!
- replacing brake clapiers
- BMR K-Member
- LT1 in a S10
- The Wait Is Finaly Over!!!
- Help Please-CAI on ASR equipped LT1...
- lt1 motor
- solenoid testing???
- Code scanner
- Fuel pressure revisited....let's try to clear this up
- T-tops. How do you take them apart??
- MAC and AS&M Headers: Which are better for a XE 224/230 Cammed Z/28 w/GMMG?
- Changing cams, same duration, is programming necessary?
- LT4 Valvespring questions
- Engine swap tips needed
- New B
- cc306 help
- Hotcam or Nitrous???
- 1993 Injector Replacement
- rear main
- cam swap - are new cam and crank gears necessary?
- When disconnecting brake lines...how much fluid loss?
- Keyless Entry Problem
- How to contact jason cromer???
- need help pulleys
- header install question
- Factory Exhuast Question
- Had a fire have wiring issues
- Check Valve screws into MAC Header, but loose ?
- 383 block prep
- Drag Launch Springs Install
- Clicking in front right wheel
- Need help with 383 tune...
- Under the intake fogger?
- re & re valve springs
- Can someone explain the leaky primary thing about long tubes to me
- AC problem....
- open Long tubes ?
- CC306 and no tune.. How will it run? Mines going nuts!
- Most commen size for shifer knobs?
- 3.73s or 4.10s with T56???
- Changing valve springs on the car
- newbie question (check engine light)
- Reverse lockout not working
- Anyone tried out the pacesetter long tubes?
- LT1 Tech Stickies
- Scanned car & got the following readings...
- LT1 V8 conversion for daily use
- Codes 48, 64 & 34......
- What to do about a Y pipe?
- Helllppp!!!
- Where to go to get 400 HP????????
- Those with SLP pressure plate over Mcleod...why?
- hotcam and compression ratio?
- When You Torqued Down Your Heads
- heater problem
- how much?
- Stereo install question
- How to connect brake line to caliper
- Quick question about Posi.. help..
- removing air tubes at headers and plumbing
- drive shaft
- Good TC for a 218/224 cam?
- exhaust leak
- another problem!!!!
- new lifters or no?
- Console Rattling
- Gonna get the Jet Hot LT's, what about the rest of the exhaust ?
- Will these drag wheels fit ok?
- Question about transmission and fluid capacity
- Need Help
- Combo Rocks!
- what/where head gaskets
- i ha ve a stupid question...
- Web page
- 4 bolt splayed caps ? wich ones to use?
- A/F ratio Gauge
- quick cam install ? .. do you have to take the intake manifold off even if
- Gas mileage dropping, loss of power under 3500rpm???
- Extra Wires??
- NSA rocker help!!
- help with vats +key won't come out of igition
- Easy ? what kind of tool for harmonic
- Hesitation when warm
- Heads and cam (how to's.....)
- Slp Cai
- Oil Leak
- Opinions on this valvetrain combo?
- Brake Problem
- Which alternator?
- How do you test vacuum?
- Spark Plug wires..order in lenght
- windshield wipers
- Anyone familiar with this LT4 kit?
- LT4 hotcam kit + LT's soundclips
- Girdle For the Rear? Going with Et Streets!
- installed a/f ratio gauge and now im stummped
- Does this look like white smoke to you?
- 3 relay cooling system question
- Injector Question
- Oil Question???
- what haplpened to my car?
- Correct backspacing for 16x8 draglite XP
- Best Cold Induction/Choose One
- Anyone running PaceSetters Long Tube Headers??
- premium or unleaded?
- Side exit true duals
- Strange sound
- good place to find a complete forged 355 bottom end.
- IDT heads?? Iduction Dynamics Technology?
- Windshield washer fluid squirters..
- question about downshift
- Aftermarket Suspension
- LT1 timing chain choices
- Help!! Speedo Problem!!
- Best place for slotted rotors and pads???
- anybody in the oklahoma city area
- Passed SMOG Today!! Still Rich Though...
- Oil Leak
- Aluminum Driveshaft
- The LEAST I can do ...
- electrical term question
- What car did the LT4 come stock in?
- Need help from those with dyno simulator
- lt1 woas
- Quick question...
- O2 sims function
- Cam Question
- 160 Thermostat or i just take out the stock one??????
- Something thats not talked about very much.....
- Removing Crank Hub
- Coil or Opti??
- 227/233 vs 233/239
- pulling the engine out,,questions
- Where is the switch for the brake lights?
- 2-3 Shift Solenoid Problem. Help Needed.
- Need help identifying AFR 195cc heads
- Rough idle not smoothing out...
- Oil cooler question
- Long Tube Emissions.
- hub
- High Idle with or without MAF
- Best route to go for heads??
- Gear drive setup
- Comp Cams Dual Coil valve springs
- Hydra-Rev kit?
- a series of issues
- ses light is on
- Question on cloyes double roller
- What would cause my motor to run rich
- put dash back in...SES light ON....connector with no place to go
- which borla
- Transmission Is Very Bad
- Rearend problems
- AC Delco rack and pinion
- EGR AIR block off plates
- Poly Motor Mounts... Install questions ???
- Installing NEW C-Clips in the rear end (Axle Shaft Locks)... ???'s
- 2bolt or 4 bolt
- Valve spring questions
- whats this and where can i get one
- roller rocker ?
- Trans wiring help needed M6 to 4L60E
- centerline telstars
- 1994 trans am..well hypertech work on her??.
- Milodon Maincaps?
- Can't get a break.... any ideas guys???
- Cam Project List, please give feedback :)
- A battery a month!!WTF
- Can injectors go bad.....
- Wheel Studs
- LT1 block only good til 500 fhp?
- Anyone have TNT f1 kit
- removing door speakers
- power antenna??
- tire size on 15x10 rim
- need a guesstimate on MPG with CC306
- which 02 sensor extensions?
- Fuel Pressure TOO HIGH!!
- Throwout bearing
- Alright my friends.....feel my pain.
- what do they weigh
- how much would I benefit from a 3.73 gear??
- opti
- 52mm, 54mm, or 58mm TB?
- LT1 heads and springs
- bottom end questions
- Strange vibration when decelerating in an auto
- Crankshaft position sensor code broke?
- Header to cat gasket
- SES light?.....tried everything to rid it!
- replacing optispark and water pump
- from what year to what year>cluster<
- 10-Spoke SS Wheels Just Bolt-On???
- Changing Spark Plugs With a Lift? Easier?
- Roughly how much current does a 2057 bulb draw?
- rockers
- cross over parts, what to get
- where is the pcm fuse??
- bushing kits...
- the great 209.00 opti
- Clunking sound when making slow turns
- 1.6 RR questions
- Need some easy code help!
- low RPM miss.... fixed
- heads and cam package for LT1?
- question about wheels
- best way to lower compresion??
- vacuum system effecting performance?
