View Full Version : LT1 Based Engine Tech
- dyno graph have fun
- A really asinine question
- how to get crank pulley off?
- will cam 2 help me?
- locked keys in car. help?!?
- guys with ASM headers
- Calling Joe Overton!!
- Fuel Injector install
- Dtc P0300
- Steering wheel part #?
- i thought K&N didnt make this
- why's it doing this..?
- 3rd gen subframe connectors on lt1?
- Need some electrical help
- msd 6-btm ?
- True Dual Time
- Ebc Rear Pads Wont Fit Over New Autozone Rotors!!!
- I might of ported exhaust ports too big
- Over valve cover wires NOT over the net?
- Crate Engine
- Pcm
- To those of you considering a header install
- Where to buy opti and over the valve cover wires?
- LT1 Comp Wire harness
- does it matter which studs the rocker arms go on?
- Putting Long Tubes on a 93 LT1, Quick ?.
- miss when warm after cam install?
- 2 short video clips of the Z28 --- SLP Loudmouth
- MAC Truefit ????
- How many miles on your cam?
- Xe 224/230 114 Lsa
- need electrical help please!!!!!!!!!!!
- quick T/A question...
- If my O2 mV's are 70, that means? + other fuel trim ?s
- Opti-spark
- Can I rig the SLP ASR/TCS switch to work?
- Got the car back, now ?'s
- Quad Driver Failure
- Lt1-ls1 Steering Racks
- Accel 300 + ignition system wiring
- Spark plug socket?
- flushing coolant and moving opti vent line
- Question about installing head gasket
- WTF??? LOL's
- Which Ignition box, best for nitrous???
- Piston slap when cold? Anyone else?
- two quick questions
- Tested coil with shoebox's coil test
- Headers
- Complete exhaust system
- sometimes it starts, sometimes it doesn't
- Shoebox or anyone else please ~~~~>
- After Installing a Cat, how long...
- Hp and Tq #'s for LT4
- Adjustable fan switch on a 96 up fbody?
- Did search, Car starts, Car does not start, Car Starts,
- Trying To Make The Belts Stop Making Nosie
- OBDI to OBDII swap
- Welding oil pickup/screen to pump?!
- people with jethot headers please
- Stock 93 LT1 rocker arm ratio?
- Couple of rebuild questions
- Car won't start when it rains!
- crankshaft sensor failure
- What plugs to use with my current setup?
- Possible head gasket :(
- Making My own Sub Frame connectors?? Bad Idea??
- Will the ZZ4 forged steel crank work in the lt1
- HELP! rear calipers have locked up!
- Running in speed density?
- Stroker kit from Ebay ....
- why are trans am's worth more?
- Brake Failure
- Everyday Stall Driving
- Hotcam w/1.7rr's
- LT1 cam question
- Headers
- question about stock rocker studs
- LT4 springs for 1.7 rr's?
- Stability/Aligment
- camaro V6--->LT1 swap
- Attn. cz28 lt1 members
- comp cams
- Console Light (Shoebox?)
- IS this Possible??
- Is it True???
- Easiest way to adjust rocker arms?
- power brakes no workie
- 1994 Z28 wont start
- Are Coated Headers Worth it?
- wire size
- AFR Heads
- door hinge adapter
- Crane PS91 coil + Optispark
- Stall????
- DTC: Error 26 QDM3: Electrical Fault, Please Explain
- LT-1 Cam specs
- new seat help
- FI>carb
- can you see a bent push rod by removing the valve cover
- car won't start, need help!
- catalytic converter
- valve cover question
- Changing my hotcam for ??
- Fireworks from coil area!
- oil leak from dip stick
- CSI Water Pump
- ses light
- Ported Oil Pump?
- y-pipe?
- HELP!! Car shakes when letting off clutch
- Need help on a simple problem
- What valves should I install????
- High Compression / stock starter
- Consequences?
- bolt broke off in head...need advice
- How much??
- Do I have the right length pushrods?
- Changing window motors
- vortex xenon kit for 97
- MAF problems....please help!
- Descision Time
- Help!what is a stall ?
- Getting it rebuilt Monday, what do i need to make sure i get?
- MAF sensor design?
- TPI block/400 SB heads would LT1 intake work
- Getting oil in rearend???
- SVO 24# injectors
- o2 sensor removal
- Will these valve covers fit an LT1?
- SLP Loudmouth Exhaust system question
- little help on a T56 install
- What automatic transmission do I have in my '95 Z28?
- Need Mechanical help!
- LT4 intake on LT1 heads??
- best brake pads?
- Loss of horsepower,Not shifting right
- BMR subframes, quick question.
- gear question?
- Moisture in my exhaust?
- Electronic brake control module
- Anyone added cats after longtube install?
- Take offs, A.K.A. launching
- Harmonic Balancer Questions?
- Part number help...
- A few quick 383 rebuild questions...
- Difficulty of changing coil?
- bad compression?
- Shocks
- Is this a problem with the Opti-spark or the tranny?
- Emergency HELP PLEASE
- how much did you pay to ship true duals?
- Ebtcm
- 233/239 cam & AFR heads.
- Simple Question
- Converting Rearwheel to crank HP
- Looking for splice/repair kit for stock plastic fuel lines..>>
- HRC pistons?
- Fog light Burnt Out...A Few Questions...
- Want an estimate for this setup...
- Chronic waterpump failure (long)
- Hedman a 1 7/8 LT1 headers fit?
- CSI Pump Install
- Water pump prob's....
- Tire question--M/T Sportsmans
- Straight pipe or new cat?
- upper/lower control arms pics
- SA rockers w/guideplates
- no oil pressure, prime pump?
- delete steam pipe?
- lt1 into a third gen how hard is it?
- Elec WP power connection
- HP estimate for two cars here!!
- Comp Cams 943 springs with CC306
- Power steering btpass
- Cheapest 383 Buildup. Penny Pinchers Enter
- Will my 4L60E survive??
- I really need a SLP Loudmouth exhaust sound clip..please!!!
- Standard SBC cam in LT-1 Block
- lt4 knock sensor?
- new opti car starts up and revs irratic and dies?
- proven .600 lift springs
- 3/4 past 0 lash for comp R's?
- Car Died, Ignition? need help ASAP
- egr block off plates?
- LOW TRAC light
- Cast Cranks????
- When you can smell your tranny fluid after a few hard runs, is it gone?(please read)
- my upgrades ?
- lt4's with a solid roller
- HELP!! Dyno Run: This cant be normal!
- GM 847 questions
- 355 Vs. 383
- bottom end build up help
- Question about MSD 6 series ignition Install...
- How bad is it to not use thread sealant on head bolts?
- Braking Problem
- need help with pushrod length quick
- Exhaust
- exhaust
- OTVC Wires
- struttower brace loose?
- what is harder on the timing chaing...
- She Wont Start!!!
- $300 good price for 383 bare block w/ 2bolt mains?
- Help sealing primary #1 slip-fit
- Custom Cam Info - Numbers, Times, AND Driveability
- Passenger side rear wheel
- Some input needed please
- Bad Iac symptons
- Eibach Drag Launch Kit
- Valve Spring Install Difficulty
- Engine front cover removal
- Hawk HP Plus Pad Install Question
- i need an opinon
- Installing new Eaton posi with gears....
- Header Install Toledo,OH area WHERE 2 GO??
- Suspension Questions
- Could two huge vaccume leaks cause this weird problem?
- Exactly how hard is it to change out the seals on the timing cover?
- Diamond Pistons, and feedback on them??
- Any one is S.F. Bay Area ?
- Are forged pistons overkill on a steert n/a 383
- I plan on making my first mod. Which CAI I should buy?
- Chugging at WOT?
- zo6 magnesium wheels what is the weight
- Cigarette Lighter Question???
- Cutting my stock springs: Good, Bad, or Horrible idea?
- ASP pulley?
- k&n replacement or CAI?
- Where are all the possible vacuum leaks
- how much better is the LS1 suspension
- baer brake question
- Callies Dragon Slayer Rods????
- I know you guys get this a lot, but....
- ? about 93 style slp headers
- buying a 96 WS-6 86K problems?
- 3.5% Increase in HP for only $7.99!!!! WOW
- Cc306
- correct springs with this cam...
- How hard is it to replace the slave cylinder???
- are there any advantages to an lt1 over an ls1?
- Block color
- WS6 air filter p/n?
- how long will my tranny/rear hold?
- what a good price for this car?
- Aluminum Drive shaft
- Relocation brackets
- Motor not running right, please help!
