View Full Version : LT1 Based Engine Tech
- Failed emissions
- Overdrive solenoid?
- Noise from rear end over bumps
- Stock oil pan question
- RPM Question, My thoughts, long post.
- crank pullie off [ help ]
- Race-Prep 383 almost ready, some details inside
- Throtle body cleaning - cold start
- Water Pump Seal
- head gaskets
- Car throwing yet another code...please help
- Datamaster file for you guys, check it out, anything seem wrong?
- Question for everyone not running a cat.
- Transmission fluid suggestions.
- putting pullies on
- Stupid question but what's the difference in 2 bolt and 4 bolt main?
- Taking car to dyno next week....Take your best guess!
- small number under TB on Intake....
- Cam Only Dyno Numbers??????
- Battery hold down part #?
- Pulsing Noise Coming From The Engine???***
- Need Mezierie waterpump wiring help
- Is my trans going out?
- 94 air injection tube nut...
- opti
- High rpm vibration
- looking for some cam swap and heads characteristics...
- Hard to start, everyone once in a while, won't start?
- which scanmaster?
- Need some advice on doing a duel setup
- PA k-member install... any pointers?
- i think i'll hit 300rhp...
- Ponykillerz28,philcam01,1 bad 6 Please someone who has done a Lt1 swap
- NEed help with my header/ collector gaskets.
- I cant believe i was missing out on this........
- Any tuning needed for 1.6 rocker swap???
- Pre-cut over the valve cover wires and loom kit???......
- BIG PROBLEM.... gass in oil and no start.. and no concert
- 58mm TB problems
- Post your dyno graphs!
- Automotive Calculations on CamaroZ28.Com
- Something must be wrong :(
- new racing k-member
- Cam ?'s
- Fuel Pump Prime Connector?
- 1/4 mile times inside ?
- pro 5.0 base with stock stick?
- Buying a Trans Am by december, any tips?
- suspension questions
- running engine without tranny
- Door Sags, help please
- LT 4 knock module?
- edelbrocs new lt1 heads
- Any1 know this guy?
- Where to check clutch fluid level at??
- Update on cam problem!!!
- Leaky water pump
- M6 guys, my reverse lockout doesn't work!
- Low Coolant Light 3 months after Coolant change
- How many hours and $ to R & R the engine??
- EGR Fault, Bank 2 Oxygen sensor lean exhaust! Please help
- SLP pressure plate come with alignment tool?
- CC306 and 1.6rr's too much ?????/
- Removing Fuel Rails
- Free mods???
- Advice on new rotors, calipers & pads
- Removed the cat!
- I need some help
- Shifter hangs?
- What's up with this?
- You have to see this. I'm buying two!!!!!
- Will a 3.4 auto tranny work with an LT1?
- cooling fans on all the time.
- Replacing Starter
- slp parts best prices
- Rebuild questions
- relatively quiet exhaust
- CC305 Ca Smog results
- Anybody use 20w 50 in their LT1
- Exhaust Manifold Bolts...
- Need power door lock help.... (wiring)
- How many quarts of oil do you put in you canton pan?
- electric exhaust cut out
- Random Tech Only Option For Y pipe?
- face guagues install
- Finally installed my long tubes....couple questions
- more GTP Stage 2 flow numbers
- Anyone tried Kuhmo tires?
- BFG-DRs with stock 10-bolt
- !ABS: Is it possible???
- TA stranded me on the side of road...
- first time removing heads..help
- SLP 94-95 Headers plug access and other questions?
- Can a bad opti cause bad track times???
- Can I throw in a 406 smallblock?
- Cold Air Induction Help
- Replacing Sparks
- Hate to post this. But how much HP am i making.
- Major problems past 4000rpms. HELP!
- What bolt ons am I missing.
- Anyone using the Autozone clutch kit?
- Looking for LT1 camaro with no motor..
- 9:1 or 11:1 better?
- What do I need to know for rebuild to get 500hp?
- my plugs and wires experience
- 12-bolt swap
- seems I fixed hesitation prob...for now-94Z
- Help with Cooling Fans
- New Keyless remotes work on 94s?
- Where can I find the cheapest waterpump
- Anyone every had a stock rocker arm break?
- rebuild my motor with 383 or get a new car... bc i have 87k on my car
- SES light but no code??!!!!!
- What kind of Oil is best for LT1's
- Best Exhaust for 300-400$
- Can the low coolant sensor be cleaned? With what?
- 93 engine building question
- windedge tray: broken where oil pump bolts in
- Bmr tunnel brace question
- opti question
- 94 ta stock hp?
- what cam for a 383 stroker?
- Difference in '93 vs '94-'95 SLP headers?
- Keep high fuel pressure and tune accordingly, or get AFPR and lower it down?
- Polylocks for stock rocker arms?
- Need Fenders!
- Any One Know ????
- what kinda power would these make together?
- will fuel rail covers work with on a ss?
- Whats a good but CHEAP stall converter?
- lt1 custom intake
- 315's or 285's
- Ran slower with PCM For Less tune...help with tune (madwolf?)
- Single cat 'Y' pipe for manifolds?
- Need help! Getting desparate car wont run!
- oil pressure sensor
- fuel line tool?
- If you suspect your IAT.... read inside
- What needs to be done to put a 3.875 crank in?
- Drag Tires
- 1st to 2nd backfire...then liquid..
- I'm getting sick of breaking things...
- vacuum hose from t.b. to valve cover
- help to find exhaust shop near Illinois
- Quick Evap ??
- Rebuilding HAL adjustable shocks
- Car running hot after LT4 KM install
- Need to disable A/C.
- AC Delco #PT289 Cross Reference
- Ill be doing my RR's and valvesprings tonight..any pointers?
- If anyone has anyone soundclips, please post here
- What would cause my car to be hard to start after it sits overnight or 5 or six hours
- car dies at stoplights!
- Wierd Screech
- ?'s about Chevy BB oil filter on LT1
- Service Engine Light Stays On
- where do i find this type of compressor ???
- what springs to use with CC306 and 1.5RR's ???
- 1993 Z with 26K Need Help!
- Tranny mount question
- Best springs for XE 230/236
- hotcam vs cc305
- Installing 1.6 roller tip RR's with stock springs?
- Size of Exhust Maniflod bolt...
- Proper way to put Car on Jackstands...
- Are those SFC any good..Look inside!!!
- Cold air induction?
- Need polylocks ASAP!
- Help! MY Car doesn't start
- Where can I get a gasket set for my LT1?
- ran scan and got code
- LT1 4-bolt & 2-bolt main engines
- Rpm surging... why?
- a little too much oil
- vette fuel rail covers
- Cam Removal handle
- Engine Block ID
- 97 ws6 times
- Torx size for TB plate....
- car heat up
- LT1 A/C Problem Codes
- Battery Fitment
- 110LSA on 230/236?
- Whats the highest lift cam you can have in a 96 LT1
- Hooker LT headers
- Single Cat Conversion Completed
- Whats the potential damage to this car?
- 100 octane?
- What's your favorite windshield wiper blade?
- Idle's up to 1,000 RPM intermittent
- Electrical Issues
- How do you remove the Winshield Wiper Fluid Reservoir????
- No Tuna Can times.
- Radiator Hoses??
- Sonsor on head???
- How much does 94 camaro z28 or 94 firebird formula weight?
- trans wont shift at redline and i dont know why!!
- why does my body's formula motor,say 327???
- LT4 Knock Sensor
- what do I need for my new shocks
- Clogged Cat???
- Anyone have a picture of the cruise control cable routing?
- Low coolant light = Low coolant but no leaks?????
- Electric Cutouts are the best EVER
- Ignition box kill a coil and or opti??
- T56/aluminum driveshaft noise
- Porting AFR 195's
- New times on the 75 shot tonight (9/17/03).
- Rear Brake options?
- Got a dash light that came on today
- LOUD noise when starting
- Is my clutch shot
- Do i really need the SLP Header install kit?
- gas fumes
- SCAN MASTER vs OTHER HANDHELD SCANNERS
- AFR heads question
- Another 1/4 mile question....
- LT1 intake manifold tolerances?
- Wiring for manual converter lock up switch?
- Anyone know Eagle's website?
- Anybody use a muffler instead of a converter test pipe?
- Whos done the rocker arm adjustment
- Anyone whose had a bad lifter(or knows about them), please come in.
- louder w/ dual pipes?
- 1/4 Times With A/C ON.. Results Inside!!
- metal bracket on passenger side of oil pan
- 4L65E anyone?
- Could a loose header bolt cause exesive oil use?
- hypertech chip?
- Wheres the best place? 4L60E ?'s
- Roller Rocker success
- Tire/rim question
- First Gear WOT - Hard knocking sound ~3.5k rpm
- Flood Prep
- Clear corner light install...please help FAST
- Friend thinking of buying 30th An. LT4
- *PICTURE* Is this a polylock rockerarm?
- How to set valve spring height?
- errr umm... so what happens if you run without an air filter?
- What am I doing wrong? Finding Zero lash(rocker arm keeps coming loose)
- A horrible, horrible thing has happened, and im afraid its as bad as it sounds
- Quesion about a 87 IROC
- A/C issue..need help quick
- do turndowns quiet down a true dual setup that dumps under the car ?
- How to test the spark plug wires?
- Code reader
- Spohn LCA relocation brackets...
- higher oil pressure, higher octane gas
- clogged pvc valve?
- Finally brok into the 13's
