View Full Version : LT1 Based Engine Tech
- anyone tried heat tape on headers to stop arcing
- oil leak...
- Car backfires when reving
- what is a erg?
- Will this block need to be okay without honing?
- shoe box here what you wanted to see.
- SSBrake Calipers
- 1LE Owners
- 440 rwhp N/A on stock bottomend
- tapping/knocking sound
- e brake adjustment
- how can you tell if your icm is goneing bad
- What went wrong with your Electric WP?
- Will bullet muffler remove the rasp??
- Magnaflow Catback
- Amount of coolant/water needed when flushing ONLY radiator?
- window alignment problems?? any1 else?
- how much are LT4 heads?
- what pound are stock injectors
- Anyone loose weight by taking off front Bumper support?
- Doing lowering springs tommorow?
- 847 and cc 306 guys
- Just finished my 1.7 RR install
- Oil Filter Adaptor
- Unknown connector
- Oil leak from Opti or Main Gasket Seal?
- Wierd problem with the Z PLEASE HELP!!
- 93 Oil life question...
- okay I give up>>>
- okay probs with the Z
- Inline Fule Pump for LT1 Engine Swap
- GM 847 stock heads dyno was today
- First time at track, SLP day times, what do you think?
- Blow-by?
- It's over
- Hypertech programmer
- New Track Numbers
- This is the coil right?
- Buyer's Guide?
- 58mm TB
- Another vote for Magnaflow
- Where did you buy your Long tube headers?
- Magnecore wires
- What plugs with these mods?
- Mess with the MAF plug and the car will die!!!
- difference in lt1 blocks? 92-97 for 383 build
- Thoughts on modifying EXISTING SHORT TUBE headers.
- Electrical Problem.. Maybe you guys can help
- running rich: I did a search and have more questions
- Reading SES Codes on a 94 Z
- 3rd gen and 4th gen rear ends...
- Will the Stock fuel pump handle head/cam 30lbs injectors?
- Shoebox, need some electrical advice
- Quick Cat-Back Question
- Rear Differential Work
- MAP sensor .,., I see carbon inside, can I clean it ?
- What exactly does 245/50/ZR16 mean??
- CSI water pump from Summit says
- this sound like rack or pump?
- How long did your ignition box last? Accel MSD, etc.
- Has the LT4 intake manifold yielded any hp gains over the LT1?
- part # for front bumper cover screws??
- Good rods??
- Stock stats?
- abs inop and popping sound?
- Scanning car on a "SNAP ON" Scanner today....
- Super Vs Turbo
- ****! Looks like a rebuild?
- cam in right, what to expect?
- subframe connectors take away creaks and rattles???
- i melted my battery
- going to dyno tomorrow!!!! anyone care to guess #'s?
- will 97 hypertech work on a 96?
- Magnaflow catback install gone bad, need help!
- Stock GM coil vs Accel coil
- 93 Year Model LTCC Owners
- Edelbrock Shorties and EGR
- What to do?
- any thing over 180 degress car stalls and sputters
- identify this light
- LT1 block
- Need Driver Door!
- LS1 brake install question spendle removal?
- will octane booster help?
- An opti begining to fail? symptoms plz
- cylinder head
- windows scratched
- Po300???
- What did the 1le driveshaft come on?
- Security light wont go out while the car is running
- aftermarket ported MAF ends
- how to know i'm picking false knock?
- Piecing my full exhaust together?
- how to replace TPS
- getting off the line
- Quick ? the stud is 3/8 for our rockers right?
- EGR SES code
- Spark Plug Install
- What codes dont set a SES?
- No back seats?
- Knock sensor desensitization! need help!
- My Dyno Results + Some Questions
- car wont do anything
- crank hub re-installation question
- Opine this please.
- TH350 tailshaft question
- Pulling SLP shorties?
- Throttle Bypass Mod, does it really do anything?
- Question about roller rockers?
- will relocating the maf help performance?
- Help... Car won't start (distributor???)
- Cruise Control Module
- oil pressure off the charts!!!
- What switch won't let the car start when in gear? (A4)
- How to convert a 1993 LT1 to 94-95 PCM?
- difference in lt1 ls1 rear brakes
- LT1 Flywheel...153 or 168-tooth?
- Suspension advice please
- need you help check this out
- Noise in rear when braking PLZ help
- Need your advice
- Does anyone have their 4th gen with no intake on it or no heads/intake right now?
- 97z28 dash in a 95 z28
- increase in temp w/ trans cooler
- Horrible gas mileage and smell???
- vacuum hoses
- tail lights off of 98 going on 95
- Where can I get blockoff plates for my E.G.R.?
- carbon build up question?
- What gears do I have?
- overheating, HELP!!!
- The Gas Tank Canister in the Rear Left 1/4 panel, can it be removed?
- Plastice HVAC "T" keeps cracking!
- How much HP to "NEED" a aftermarket TB
- whats the difference between '94 and '95 heads?
- Tilt steering wheel lever?
- Who reused their intake bolts?
- spec clutch t 56 problem
- Passenger Axel leaking. Help
- Could a bad EGR
- Cleaned my MAF, did I do it right?
- Torque Converter Change
- Running wires from pod gauges....
- Piston to Valve Clearance Question
- Serious Idle Issues!
- Screaching when shifting?
- Stock car-alarm question on a 97Z28
- My Guage's FLICKER Back and Forth?
- OBD1/high stall problem...New Times
- high flow cat and cutout
- Clunking noise from under car when turning while braking
- New member and I need help
- Cam selection help
- b&m or transpact
- Are Taylor wires worth buying? What is the difference from OEM?
- Need help with keyless entry (shoebox)
- Smart guys only 95 Z28 Camaro(AutoXRay)
- Will springs from an '89 GTA work on a 95Z?
- Hot Cam 1.7RR vs 1.6RR
- Is It Smart To Cam Now!!
- Insulation on O2 sensor harness is open
- how to change o2s
- fired "new" motor and now a MASSIVE oil leak
- 94 died and won't restart
- The "Security" light is on on my dash...
- How hard to launch car with a street twin?
- Should i switch to vented opti or not ?
- SES On and Off
- Ive never changed my O2 sensors.
- Bad OPTI?
- Valve Spring removal
- 80% of hesitation gone!!!
- How can i adjust my AF
- Increase timing
- Jet Hot vs FLP headers.. all thrown off now!
- how much hp with this
- Will i have heat with 160* stat?
- transmission knocking...what do i say hello with?
- Symptoms of a vaccum leak??
- Can someone help me!?!?!?!
- What happened to my lights?
- god i hate asking this...
- good wheels for slicks? 8 x 5 not wide enough.. 3rd gen wheels?
- Still have hard starting, more like slow turning over
- Part # needed...
- BRAKE! Light
- Arching with MSD 8.5's
- Tubular front end question...
- HOW MUCH RWHP SHOULD I EXPECT!! "please reply"
- idle stays high temporaly,
- Break in on Solid Roller?
- parts catalog
- Checking Fuel Pressure?
- Greasing bushings on 97???
- sounds like loose or broken shocks when i hit bumps after replacing with slp takeoffs
- better price on a power steering pump?
- How often should I grease BMR suspension fittings?
- please help me...fuel pump?
- car always runs under 160*........is that bad?
- What is the best and CHEAPEST Head&Cam Package???
- type of metal are 93 lt1 rods?
- OK to "hoist" car up by bumper support?
- broke another tranny mount?
- Is it time for a new clutch???
- Doughnut gasket question
- replace with bose speakers or something else?
- Help with mods
- Coated vs. Uncoated LTs
- Ticking noise when motor is cold
- AC DELCO O2's vs. BOSCH O2's
- Unsure of what to upgrade
- Can anyone give me a sound clip of a dynomax muffler
- Need major help guys...
- that stuff thats supposed to clean ur engine, u put it in ur gas? does it work?
- whats the stock tc stall?
- new tires
- Where to get new intake bolts???
- Street twin OK for daily driving?
- 9" guys, in here
- dumb question. whats the difference between short and long blocks
- Car won't start untill second crank?!?!?
- vibrating shift knob
- More intake woes....
- AS&M header guys.NEED HELP
- found a vacum leak?!
- How many heat cycles do you need to go through when you change a exhaust gasket?
- I need LT1 head comparison chart
- MAF cleaning? just the screen what parts do u clean?
- ECM, tuning, programming guys in here...
- why am i running like ****?
- Any gasket sealant on intake/WP/timing cover gaskets?
- sound clips of a cc306?
- What do stock heads flow????
- 1.7 rockers?
- ? bad start today?
- Vacuum hoses, heater hoses..part numbers
- Low RPM Hesitation Problem SOLVED
- My window buttons dont work!
- OEM Parts for Camaro Z28
- Fixed my exhaust leak and WOW
- Where to get turn signal cover
- LT1 edit/tuner cat questions
- Voltage Flicker Help!
- shift kit??tranny rebuild
- where to get cheapest acdelco o2s
- HPP reprogram for different tire size
- Funny shifting
- Hesitations at full throttle?
- lingenfelter throttle body
- What gaskets DON't need RTV????
