View Full Version : LT1 Based Engine Tech
- Waterpump shot? (Shoebox?)
- Error code while trying to flash...help
- Having Engine knock or noise......
- Trans Fluid. How many Qts.
- Help! Friends new (1997) z28 won't start.
- ?'s on testing TPS and coolant temp sensor w/a multimeter
- Brake questions
- Pulled the distributer without marking anything on my 95 S10 TBI!!! HELP...
- having problems finding front seals...help
- help! how to remove lock from nut, on roller rocker poly locks?
- Pace setter headers???
- SLP Clutch with Honda ATF!!awesome
- LT4 Valve Springs
- lt4 HC with ported heads
- AC prob need help!
- New or user opti???
- widest et street on telstar
- Mufflex didn't line up right with Jethot LT's
- Headers
- What are your 1/8 mile times
- Will regular SBC headers fit on an LT1/LT4?
- Fuel Pump Question! Car won't start! ASAP
- LS1 Brake upgrade...now car cannot be aligned? Experts inside(this is a hard one)
- big cam help
- anyone who has removed their opti- completely..inside PLEASE
- How to take off borla plates
- Help bad mis
- Fuel line questions
- Favorite spark plugs? :) Tired of NGK's
- LT's+Mufflex Y-pipe+Cats???
- How do you get caliper off??? QUICK!!!
- Where to Mount my MSD box???
- huge problem...please HELP asap, EVERYONE
- HELP! Quick Q: How To Adjust TPS?????
- Devcon block repair
- MAC Torque Arm w/ LT's
- Big problems!
- What RR to use if I run an LT4 Hotcam or something equivelant?
- wouldnt a misfire show on vac gauge?
- Low coolant light....
- LT1 vs. LS1
- Engine Noise (Need Help)
- Fluidyne Rads. Good or bad?
- Tranny vibration
- Get Your T-56 Manual Here
- Changing Transmission Fluid.......
- Fuel Pressure seems low?
- Power antenna instal question...
- Jet hot LT with cats or no cats on GMMG
- What gears for M6 with heads/cam???
- Low Mount Alternator Bracket...
- AC Problems...
- help me Decide, quick!
- What could cause a backfire!! See inside
- INT. or EXT crank? Which one is the right one?
- SeaFoam Trans Tune
- Where to get and hook up Vacumm Modulator
- Engine vibrates (balancing problem), please take a look...
- If you were going to run 28*10.5*15 slicks on the rear, what width rim would you use?
- Who HASN'T had the OBDI + 2800 plus stall problem?
- Burning wires on me headers...
- CODE 45 Again!!!!!!!!
- Short and long Cam Dowel Pin help needed.
- How long do aftermarket headers last?
- MoTek vs. Accel / DFI Engine Management
- LT-5 vs. LT-4 Engine?
- hard starting after sitting, why?
- Exhaust question...
- Fuel pump....Whats purpose of extra hose inside tank?
- msd ignition
- Popped Head Gasket, Lost Oil Pressure on a LT1.
- Exhaust Question
- What turns on the cooling fans during normal operation?
- 315/35/17's ......need help choosing....
- cranks but no start - need help diagnosing
- 400ci SBC LT4
- Heads didn't make me any faster! Advice please!
- oxygen sensor
- I have a problem and i need some help..
- Head Help
- rebuilt motor - white smoke
- Turn signal
- edge torque converters
- Ti retainters on my GTP stage 3 heads... questions inside
- quick question...starting problems
- lingenfelter turbos
- SHE LIVES...but only briefly
- balancer ?
- Elbow Boot is Ripped around TB, will a New one make any difference???
- Spark plug gag...need help quick please!!!
- Cant downshift to second
- Going to Milan Dragway Tomorrow!!!!
- stock panhard bar vs aftermarket NON-adjustable bar??
- Anyone use 1.6 ROLLER TIPED rockers, not full rollers??
- How much would it cost to install a new intake manifold?
- Interior Gas Smell How it was fixed poll
- Different Regulators?
- solved my swap question, but........
- is this the right cat back for our cars?
- Head/coolant steam line
- LS1 Brakes-No differece between old lt1 brakes
- Yippie...just bought a STB!!
- How to weld SFC's ???
- LT1 steam vent bolts P/N 12552974
- opiions please
- What are the hp gains from true duals?
- PCMforless tuning?
- what kind of bulb for fog light?
- Will part#1284 Felpro intake gasket, work on a Lt4 intake?
- Anyone have a sound clip of Loudmouth, LT's and dynomax?
- Line Loc problem
- New Problem! Can drive but not shift (very hard)
- New Guy and ?
- High 12's possible with exhaust manifolds??
- Black Puff
- LT1 heads that flow???
- Mounting tires on wheels.
- Valvebody?
- Bad vibes while slipping clutch
- Is it possible for a bad flasher to cause the right side to work but not the left?
- 93 z28
- Vats system
- Got my LT1 block today..one question!!
- Has anyone kept there intank pump with a lt1 carb conversion?
- Does anyone make a single plane carb intake for an LT1?
- 58mm tb on a4 without programming?
- Shorty Headers
- whats the biggest traction gainer
- GM Part Numbers PLEASE!!!
- what is different between LT1 cam & 87 up cam
- what are your 60ft times???? Help others with thiers!!!
- replacing fuel line...
- Thinking of ordering skinnies & slicks for my 95 Camaro, what sizes do I need?
- can minor oil leak damage clutch
- best vert suspension mod
- Door Handles
- Clutch wear
- Who is using a roll control device on their camaro, 6spd with ABS?
- Anybody want to guess what my car will dyno...
- Replacing oil pan
- newbie here
- Flange nut going in fuel filter. What size ?
- Fixing SES light - MALF11 (MIL Lamp failure)
- Ls1 brakes: Clips for pads?
- ???'s for guys with Street twins!
- Can the starter go bad and still test good?
- Pdd PCM question..........
- Opinions on a hi-flow cat vs stock cat?
- MAF Questions
- What kind of Intake SS or CAI
- Anyone put a cat on mufflex y? I'm backfiring
- Engine overheating
- Help! Coolant leak
- Drag?? '97 Camaro z28 or 2000 Mustang GT
- Is the price of an LT1-->LT4 Conversion really worth 45 HP?
- LT4 valve spring help
- converter lock up switch
- Few ?'s for the tranny speciallists (especially converter)!
- HELP! blown fuse, again and again!
- skip shift
- Cam Dowel Pin Length?? CC306
- What size exhaust?
- What kind of paint for 12 bolt?
- lets try taking a look at my scenario...
- Old Stock Cam ?
- ? for anybody who has done a clutch job
- Fuel filter
- I'm new to bow ties
- is my fuel pump going?
- How to replace o2 sensors?
- LCA install questions
- Part #'s Please!
- Can someone PLEASEEEEE help me with this knocking under my car?
- N.I.B. Lt1 timing set seems loose!!!??? what the!
- Taylor Wires?
- Couple Of Qs From N2O Backfire This Weekend!!! Car Broke, PLEASE Help.....
- Correct way to install starter..
- cam selection
- SES light need help
- Fuel pump question
- *USED*LT4 hotcam, lifters, can they be used in a different engine?
- Maintence Schedule question
- Passing Emissons
- Opti vacuum lines
- Proper new valvetrain break-in....
- Jet Hot Install question???
- High RPM vibration after clutch install
- how much do bigger wheels slow you down?
- best way to change oil pan gasket?
- 3.73 gear upgrade performance?
- MAF sensor ???
- couple ?'s after 305 install.
- cancel the skip shift with LT1 edit?
- 17*11 in front
- alright need advice on next mod a little confused??
- 24lb injectors max hp?
- Rear making noise when turning.....
- Header bolts, Gakets etc...???
- whats this sound??
- Exhaust Question
- Question: Why is the more $$ BMR strut brace thinner?
- tranny shifts hard
- Video of me at the track
- ram air z28
- open header idle
- Rod Question 5.7 or 6.0 and WHY?? Bushed?
- Salad shooter rims can you...
- Idle Problems...
- pcm for less?
- converting from 94 instrument cluster to 97 cluster
- ASM Headers and dipstick location
- heads/cam guys: gas mileage?
- Setting Clock?
- dipstick tube
- pulling engine through top
- Rear axel seems to have a lot of inward outward play.
- Hesitation at high revs and high speed
- What is a T56 and everything needed for a swap worth?
- Cam Specs
- do i have an obd1 or 2 computer
- Trick Flow LT1 elbow (great product!)
- lt1 edit
- radiator leak?
- good deal?
- Pulling Engine thru top: What did you do with POWER STEERING & A/C ? Alt Brkt stuck
- Need Help Asap
- 97 motor in 95...need quick help
- very frustrating blinker turn signal problem
- Do Flowmaster exhausts come with chrome tips now?
- who has boared their block .060 over?
- single or dual cat Y Pipe?
- Who runs a XE 224/230 with stock heads?
- Front susp. rattles after shock/spring install
- Pcm?
- Installing a Pete Jackson gear drive on an LT1
- !cags lockout question
- What plug wires should i get??
- schrader valve thread size
- need TB help!!!!
- How hard to change wheel studs?
- Does the hooker catback come with the muffler??
- Anybody else having problem with their flps longtubes?
- Can't get my new vortech elbow to fit correctly.
- Puff of black smoke when getting on it? Running rich?
- Maf
- Car wont start again
- Driveshaft help!!!!!
- Starter - Stock or Aftermarket replacement?
- How much would I benefit going from single exhaust to dual exhaust?
- What cfm would you need, to make 450-500hp NA 396 Stoker!
