hesitation? turns off? PLEASE HELP
Old Jul 21, 2003 | 07:33 AM
Green G0blin's Avatar
Unhappy hesitation? turns off? PLEASE HELP
I turn on the car and idles fine, but once i put it in gear, i can drive about 2 mins and it hesistates, wants to turn off, and does. i turn it on, and drive, and it turns off again. SES light dont come on neither.
what do you guys think it could be? spark plugs?
and..the computer is programmed to the specified mods in it.
1996 Black DropTop Firebird Formula Jet-Hot Hooker Long Tube headers, X Pipe, True Duals, Dynomax Bullet Mufflers, Jet Air Foil, TBB, Throttle Body ported to 52MM, ported/descreed MAF, Taylor 8mm OTVC Wire Kit, NGK Iridium Plugs, Vortech Elbow, K & N FIPK, Nitto 555r drag radials, Honeycomb taillights, taillight covers, LT4 Hot Cam Kit, Tranny Cooler, Aluminum Differential Cover,3.73 gears, 2400 stall, 1LE Aluminum Driveshaft,BMR STB, BMR LCAs, BMR Torque Arm, Port/Polished LT1 heads (done by COMPTA), LT4 KM, !EGR, !Front Sway Bar,!AIR, OBD1 Conversion, with custom PCM Programming from Ion (www.madz28.com)
Old Jul 21, 2003 | 07:44 AM
predator's Avatar
i would make sure all the sensors are plugged in or in right position maybe the maf is reversed i ahev seen that happen
Old Jul 21, 2003 | 07:53 AM
hehe..sup civic owner?!
anyways...i looked on a site about symtoms of the optispark and i meet these qualifications
* Extended cranking to start
* Rough idle
* Sputtering
* Trouble reaching higher rpm
* Poor performance with car warmed up
so....i guess im calling jason cromer?
any alternate ideas?
Old Jul 21, 2003 | 07:55 AM
is there a way to test the optiCRAP!?
Old Jul 21, 2003 | 08:00 AM
predator's Avatar
yes but you have to be really technically inclined and have a test light multimeter and a reapair manual
Old Jul 21, 2003 | 09:11 AM
can it just be my plugs that is causing this?!
jocamino
May 14, 2015 07:37 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
CaRParts102
Dec 6, 2014 08:45 AM
IRABuss
Sep 7, 2011 09:08 PM
formula79
26
Aug 5, 2002 12:21 PM
