better fuel pump and bigger injectors?
Old Jul 19, 2003 | 09:03 PM
97WRAITH's Avatar
Finished my cam swap and fully ported stock heads. I am sending my pcm to bryan monday but my car sputters at above 5500 rpm is that just because I need it tuned or am I going to need a fuel pump and bigger injectors?
Thanks!
Rob.
Old Jul 19, 2003 | 09:12 PM
funina91ss's Avatar
After you get it tuned I would put a fuel pressure gauge on it to make sure the fuel pressure is fine. The stock pump would problally be fine but it will be working it hard to keep up. And run data master on it to see what duty cycle the inj. are running.
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
