Throttle Position Sensor Wires
Old Jul 19, 2003 | 03:16 PM
All4Chevy's Avatar
I need to splice into my throttle position sensor out put wire for my zex wet kit...there is 3 wires in the TPS. One is black and obvisously ground, but is the green or yellow the out put one?
Bill
Old Jul 19, 2003 | 03:28 PM
TPS should have
black = ground
drk blu = TP sensor signal
gry = 5v reference from pcm
Old Jul 23, 2003 | 01:57 PM
All4Chevy's Avatar
Using this picture http://csce.uark.edu/~jgbertr/rb/tps.jpg to see my TPS, when i look at mine in my car, the wires are differenct colors. Mine are black green and yellow. Did GM just run out of wires to use?? I need to hook into my out put signal so zex calls it, should i just splice it to the yellow wire?
Bill
Old Jul 23, 2003 | 02:26 PM
Don't worry about the wire colors... look at the "position" on the plug. On Rob/Shoebox's photo, the black and gray wires are postioned on the "flat" of the connector, against the clip. The blue (variable output) signal wire is alone on the other side of the triangle. That is the wire you want.
Old Jul 23, 2003 | 02:34 PM
All4Chevy's Avatar
OK thanks, ill try that.
Bill
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
