View Full Version : LT1 Based Engine Tech
- 94 LT1 OBD I Bogging
- LT1 bogs under light load
- LT1 backfires
- Et and mph estimates for my 96z28.
- Need some help in California Ontario area.
- Will this handle a 150 shot?
- cutting out at hi RPM
- Code ?'
- Lt1 Injection on pre 86
- Need help - Enging popping and sputtering bad when warm/hot ??
- What intake elbow for 58mm BBK TB
- Just finished motor rebuild..Few question??
- No low RPM power
- ARP-134-3701 ARP LT1/SBC Head Bolt Kit 12 Point???
- Ok..about to bring my block and parts to golen..need some suggestions.
- !Friend in need of some help!
- Why does my Trans Am die in 3rd gear?
- LS1 Headers Going on an LT1?
- rocker adj ques/prob
- alternator problems
- maf question
- Car cutting off
- Car Wont Stay Running
- Fuel injector problems?
- Will a 94 z28 transmission work with a 93 z28
- Convince me I need long tube headers....
- Smoke at WOT ONLY
- 1997 T/A LT1 has me stumped!!!
- All sealed up
- What size Injectors?
- who makes the best opti for the money?
- Anyone ever dyno before and after 58MM on a bolt on car?
- True Duals on Stock Manifolds
- What cat convertor to buy to pass emmisions?
- starting trouble
- Are you all proud of me???? lol
- did i mess up my optispark timing
- Ported heads need work?
- Best brand RR's? Trickflow any good?
- Questions before I Dynotune my 388 ci 96 M6
- So Then What Do I Need???
- stock valve cover clearance?
- Datalog Questions?
- did some mods
- Left bank runs lil' richer than right.
- heads/BRE cam not right??
- Gm847 springs
- Gen 7 DFI/Innovate LM-1 wide band/Accel DFI dual sync distributor
- Runs Rich Exhaust
- '95 LT1 PCM (kinda long)...HELP!
- 1994 z28
- So how does it sound guys? 4"Mufflex
- what springs with le3 cam
- Degreed XFI 218 Cam
- mods. help mileage
- question on block casting #s
- 1.6rr/lt4 springs
- Slight Pop Out of the Exhaust and Idle Issues
- need some help please
- engine cradle
- tunercat tunercat tunercat
- LT1 reconditioning and paint job...
- Darn Car!!!!
- How can it happen without warning like this?
- Need tips for Pacesetter mids install
- good boostable headgasket bigger than .039?
- Car wont start
- 93 z28 headers???
- My 383 Dyno Numbers
- Wireing Headache
- LT1 Oil pan?
- Canton Oil pans....?
- where can I get a NON TCS throttle cable for a 96 LT1
- Horsepower?
- quick question regarding K member and motor
- trans./shift kit help.. PLEASE
- where did my hp go???
- Is this a bad opti??
- Will !cats lower gas mpg?
- 17% L Trim loss
- ARP studs stock windage , My fix
- need opinions
- What are those two vertical tubes on each side of the engine block?
- Benefits of a 1LE Elbow? HP gain?
- plate on front of crank...
- 93 Trans Am Gargling noise?
- buick roadmaster lt1
- 355 build need nitrous pistons
- Anyone ever get a LS1 engine stuffed under a LT1 hood, sucsessfully?
- What size to get?
- chevy hardened pushrods or not?
- Engine Swap
- exhaust, question?
- Lt1 injectors fire in pairs or sequential?
- Pacesetter LT fitment problem
- Ignition switch
- strange squeeling sound coming from engine
- push rod length
- New wish list for my LT1
- ok.. piston dish which side?
- full bolt ons
- Is Accell Opti Good ? Cause Its The Cheapest
- non self aligning RR and pushrods on 95 lt1
- dropping rpm under wot
- Advice or opinions.
- srp 396 pistons
- Long Tubes how hard to put in?
- obd2..how can I pass emmissions with egr/air deleted?
- Just got my heads back!
- LT1 intake manifold clutter..what Can i get rid of?
- Removing the Muffler
- 383 not running right, datalog inside
- Hvac controls..do they need to be in?
- Summit OptisparkII update
- re
- After market raidator options?
- "overheating"
- Unbelievable.....
- need help fast
- Delteq low on power?
- I needCalifornia legal Catalytic converters
- Problem with Ign. Module
- pcv valve-rubber elbow keeps melting/ripping
- Autolite 106 or 104?
- sorry guys
- slp ultra z box
- vaccuum question!!!
- ewp questions
- Help! I need valve covers for my LE2!
- head bolts...
- Want to hit 500+HP/TQ need setup ideas
- Is the 95/96 ICM interchangeable for testing purposes?
- fuel rail covers and ram air/valve covers
- Just got a T/A
- Ughhh...a lil confused
- Coil resistance 10.5K
- help building a lt-1 383 stroker
- guess what it blew again
- Anybody know the thickness of a Felpro LT1 head gasket
- exhaust. what do these word mean?
- part number on head gasket
- help with friends car/no start
- engine noise
- The Causes of Knock Retard? (Still getting retard)
- Underdrive Pully ????
- Will these fit LT1 heads ???
- A/C Question
- Lucas fuel injectors (42lb)
- My Car Will Not Run Right, Please HELP!
- Leaks 2 quarts every 1K miles.
- ? on replacing cap and rotor
- need help with leak
- Do Not Buy.........
- Help me find a pic of that low mount alt bracket for driv side.
- what is this for?
- GM O2 part number?
- Hey All Newbie Here!
- Right O2 sensor lean?
- Well it was bound to happen, colapsed lifter, bent pushrod
- Engine Build
- I'm giving myself a budget of 10K for mods... what can I do?
- Electric water pump help!!
- Test for 96-97 coils?
- starting problem, need help
- LT1 383 Questions??
- How would you judge the quality of a home porting job?
- Guzzling anti-freeze
- Any suggestions?
- cam kit on ebay
- Lt1 Camaro A4 times
- Cam Question for 383
- intake elbow silencer?
- MSD 8.5's OVC??
- Bad injector ruin spark plug and cat?
- Fan on/off temp setting with 160 thermostat?
- LT4 and LT1 oil dip stick different?
- LE2 dyno graph link
- Fuel econ
- Newbie here...
- why does it pop?
- Those who have tuned 224/230's in here.
- 383 stroker install no idle
- Need help fast please
- LT1 problem
- plug in?
- rpm drop while driving
- Anyone with a GM service manual?
- Fuel Pump Wiring Question
- Mac Mids...why not?
- Length of oil dipstick?
- lost lt1
- lost lt1
- 2 bolt vs. 4 bolt main
- carbing my lt1
- Electrical problem Need help ASAP
- Car off by 3-4 MPH in the 1/4
- Big Problems, Need Help, Any Advice Appreciated
- My upgrade wish list on my 1995 z28
- Wierd problem
- Oh dear... yet another cam thread =/
- where to put an ignition box
- What to gap spark plugs for best fuel economy?
- Latest and greatest miss/surge........idea?
- Critique my upgrade list
- Detonation resistance with Mahle PowerPack dishtops?
- more electrical
- Super victor or Stealth Ram
- Exhaust ?'s, simple
- Tell me what I am missing......
- Car not starting question...
- Need help with bad spark knock issues
- Mahle pistons and n20.
- Car missing, took the plugs out, check out these pics
- Mac mids vs. RKSport mids
- Fuel injectors...Quick easy questions.
- Snow Performance water / methanol injection
- Mail in Tune
- 1.7 Rockers...To Big??
- Bad Icm???
- victor EFI intake ... try or pass?
- s/a 1.6 rockers 306 cam, stock pushrods good?
- Ever so slight miss at idle and lower rpms
- LT1 mods
- The journey to HP has started. Need some opinions on track times.
- explain how a cammed car sounds
- MadZ/28 Tune: For those Running it...
- Manual fan switch
- Tool to take off z28 Calipers?
- Installed Danatech silencer cones. What a difference!
- Changed coolant and now my Fans don't work??
- heads / cam on LT1 = ?
- Dyno time
- Pacesetter Y-Pipe to Cat Back
- Update: new 28" vacuum flow bench scan for home ported LT1 heads
- Optispark Testing
- spark plug question?
- o2 sensor issue...
- Electrical problems Please Help
- optispark question
- exhaust/headers question
- People that have gone from mail order tune to dyno tune
- Wrist pin knock? Pulling motor - need to verify noise
- Odd Grinding sound? Clutch??
- Whats First
- Startup Problems
- Heater hose R & R help needed
- Its finally over
- destroking and boring questions LT1
- Fans not coming on
