View Full Version : LT1 Based Engine Tech
- scanning tool-worth the money
- n/a no longer- turbo or centrifugal?
- Which CAI?
- Lower Oil Pressure since Synthetic switch...
- Milling heads and compression
- Are these headers/exhaust good?
- please! please, help me pick a gear!
- T56 swap done... but the starter won't work... dash lights come on... please help
- Where to start Diagnosing Missing Power? (Recently dyno'd Solid Roller 392).
- I need Knock Sensor part# for 95 Z
- Please help me pick the right gear!
- Solid Roller Stroker Peaking Too Early?
- new turbo motor break-in?
- Piston to valve clearance
- Ok, did a search, still confused...
- need help quick!
- HP with CC306 cam ???
- Installed my Spohn rear LCA's yesterday
- Question about cam install!
- Torque Converter Shims
- Which motor oil weight to use?
- maf gasket??
- Intermitten start problem. Help.
- Electronic Spark Control, Anyone ever use it?
- Which RTv is best for all?
- BMR Boxed SFCs'
- PCM tuning
- Accel Shortie Plugs Anyone have a part #?
- Best spark plugs for LT1????
- Mechanical or electric Autometer, which do you prefer?
- How easy it is to change the tranny's 5th gear?
- any good launching tips for a4 lt1 Z??
- what are some indicators of a bad opti?
- Ha another cut out question
- Alternator wire/plug
- Jumping in and out of closed loop, split BLMs, and more fun stuff
- TPS Question
- WANTED - mjcent922
- Knock count and PCM learning
- Poll: 245/50-16's or 255/50-16's?
- Oiling problem
- 302 camaro??
- Longer length valves will result in what?
- What exhaust.. Post all Exhaust Clips here plzz
- I need an EGR solenoid....
- Bigges diameter valves that I can use on 190 LT1 AFR Heads?
- Pound rating for stock springs?
- SS Ram air intake VS Cold air intake
- 97 z rims on a 92 jimmy 4x4 ?
- Exhaust Question. Catback vs Muffler?
- Granatelli? or just port the maf?
- rewiring help!!!!
- Were to buy a 383 short block?
- anyone else have a rattling clutch?
- Fuel Line leaking ?
- I need part Number.......
- speed limiter
- Occasional SES light and code 34
- What do you use to add tranny oil to M6?
- Tried to install headers today and it couldnt have went worse!!!!
- ***urgent*** need help with this clutch please help
- Gtech Pro .... Good or garbage?
- Trans shot
- Edelbrock CHs again
- My plans, what kinda numbers?
- Camshaft Questions
- Need opinions with the "hidden" shift kit
- oil primeing question
- tire size
- 450RWHP LT1... How much?
- Dielectric grease
- T56 w/ problems... fork or syncros?
- LT1 swap problem
- LT shopping list. Anything I'm forgetting
- fuel pump?
- heads and cams help decipher
- help with hooking up manual fan switch
- Problem Codes 100 and 103
- Time to play, Name that Part ...again (got pics)
- cooling problems, please help!
- Finished the Goodyear "High-Miler" Hoses install
- NHRA kill switch ?
- Budget strokers, can it be done?
- Question???
- will this throw-out bearing work,pics inside
- Drags at Steele, AL
- T-56 Swap in a 93
- A/C what should the high and low pressures be?
- Solved my oil pressure problem
- cc305?
- What aftermarket valvecovers do you have?
- jegs torque arm kit
- 93 throttle valve cable preventing WOT
- A4 to M6 flashing computer
- broke a ball off the pushrod last night. need advise where it could have gone???
- Please help, Tranny Problems
- AutoTap EFILive work with LT1?
- Heads and Cam or NOS???
- Possible Lifter Tick??
- quick swaybar install question!
- lost oil pressure!
- Loudmouth and no cat, anyone
- LT4 heads w/ cc305
- flushing coolant from block
- good deal or bad
- Cam dowel length from cam gear?
- standard sbc heads on a lt1
- Mcleod adj. master cylinder ?
- LT1 w/ Hooker Cat-Back sound clip
- Well since motor is almost together, what do you think it will put down? *Reward*
- Cars dead! In somebodys yard Need HELP
- Tranmission overheating?!?!!!!! (shoebox and others that know about this stuff)
- Hesitation Problem..Happens right at start up
- stumble with open LT's.....HELP
- bad brake booster ?
- Handling questions
- Could I have bent a pushrod?
- Just installed Crane Cams HI-6S and LX-91, 1/4 ?
- Check Gauges, then car dies......Opti? ALternator? Battery? HELP PLEASE!
- opti/plugs and plug wire?
- Man i ran with open manifolds today details inside!
- Anybody with the new MSD 96-97 Coil?
- pics of GM Perf. aluminum valve covers
- help me choose SA vs Non SA rockers
- which splayed main caps for lt1
- Well, my tranny went out on my tonight
- AutoZone Opti Parts? More than one Model?
- help Best plate or wide open
- hooker with borla cat back
- Anxious headlights
- Stubborn Valve Lock
- What headgaskets and injectors w/ new heads/cam ?
- opti differences. help needed
- 93 z axles
- Combination Motorsports Stage 1 Head/Cam Combo
- How much knock does it take...
- Can't get fuel rail out, need help?
- Is there anything I can spray on the weatherstripping so my window goes up faster???
- OEM Coil or aftermarket ign coil?
- cam on stock LT1?
- How To Build A '95 Camaro/transam Right
- HELP! T56 still 1/2" away from bellhousing
- Want to show the car I'm buying
- Lunati Timing Chain
- newbie here
- Found this box under dash.. alarm?
- A4-M6 swap questions
- Where does these vacuum lines go ?
- A4 guys with 3.73's......
- wheels?
- rocker arm / valve problem ...
- Stock gear options???
- need advice on fuel pump
- please tell I didnt break something
- So what do you guys think?
- need help real quick - LCA stock bolt sizes
- Underhood Temperature
- Brents headlight fix
- Mufflex Y-pipe?
- th350 kickdown cable
- Case of beer to who gets my car to start
- can i run dual-cats on AS&M headers?
- help what gears do i go with
- Doing header install tomorrow any words of wisdom or a simple good luck.
- dyno graph
- Anyone running LT's and a cat inside please.
- Gas milage...
- what gauge cluster years will work with my 94z?
- tranny temp
- Driveshaft Vibration Problem Solved - Fast, Quick and Cheap!!!
- cars with duals and x pipe inside, g load brace?
- Still cannot decide on which cam for stroker/nitrous PLEASE HELP!
- another complaint with my pacesetter shorties
- Shoebox I need your help one last time!!
- dealership doesnt know what there talking about?
- backspacing and bolt pattern for stock wheels?
- ls1and lt1
- Gains with 4.10s?
- Tranny Cooler
- 1993 f-body kick down cable
- Need KM after only headers?
- When your 10 bolt goes...?
- Once again,many thanks Shoebox
- axle swap
- trans cooler location
- Great. car doesn't start now
- Blower & 42# inj, what else will this car need?
- How do I adjust the throttle cable
- 93 A4 Servo
- finally, some track results
- Car is slower.
- Possible to swap keyless.........
- Where is the BCM on a 94 car?
- Got my afr 220's flowed, what do you think?
- power steering pump replacement...best option?
- SLP Loudmouth
- rear end or shocks
- did anyone cut out splash guard after cai install?
- anybody running a cam with 111lsa or lower
- has anyone went from dino to synthetic in rear end??
- Best Performance Non-lowering Spings
- ram air hood question????
- Just Got 95z...Need Engine Help!!!!
- Need to change EGR valve quick question?
- check out this deal >>>
- Valvetrain Advice needed
- Somebody please help! Shoebox?
- My car passed emissions! lol! finally got to debut my new custom plate!
- abnormal shifts on my A4 tranny
- What Is The Best Aftermarket Clutch For A T56 Trans?
- anybody replaced the brake line that runs from the abs cylinder to the rear brakes?
- low cooling fans is not enough
- What to do?!?!?!?!
- Worried about getting bolts out of manifolds the ones that go to the heads.
- Low water light?
- Another what would you do...
- Ignition Switch Question (Need Clarification)
- 93 vs. 94-95 AS&M headers
- how to delete air and egr systems totally?
- things needed for slp dual cat shorty install?
- Oil Pan gasket question
- Help with AFR rev kit!
- Big Problems, new to Lt1, need some help
- Simple Question:
- 12's possible with
- where's PWR door lock Relay on a 93?
- Cop prob w/ exhaust
- What is the combustion chamber size on the stock lt1 head?
- Anyone have a spare intake that they trashed and need to get rid of?
- What exactly is cam surge???
- Wiring scematics on line??
- I need pictures and suggestions on suspension set ups
- how to tell what gears thses are?
- LT4 valve cover gasket stretched a full inch !!
- New Shocks?
- Has anyone ever had problems with justin sutton sending them their parts?
- LT4 Clutch
- installing long tubes
- throttle body blades???
- Whats Faster Trans Am, FireBird or Camaro??
- Oil pump
- BIG PROBLEM, car is sitting in drive way, need to get fixed
- Ignition problem?! (Kinda long.)
- 600" lift valve springs with cc305?
- How do you know if the rockers need adjusted?
- Coolant fans not working
- Who has solved the Low RPM Stumble?
- Soon to be LT1 owner
- How do I disconnect fuel line from fuel rail?
- Oil leak from EGR tube...
