View Full Version : LT1 Based Engine Tech
- how 2 remove injectors?
- kind a cam for my LT1 94 camaro
- Great!! p300 on 96 camaro lt1
- Crane 10308-1 Valve spring kit w/ stock cam?
- what year is this lt1
- waterpump going out after cam & heads swap!
- Need some help, don't know what else to do..
- cam selection...rpm range help
- Need header bolts and gaskets and O2 sensor extention for Jethot long tubes.
- Need a double roller? Everyone still using Cloyes?
- i need heater hose help plz! cheap fix?
- Help Relpacing a Lifter
- Cam Decision 94 z28 and 95 z28
- 1993 z28 running horribly help?
- Slower ET Without Air Filter????
- Which of these would go with pacesetter headers ?
- Motor knock!!
- Fuse #3 15A PCM BATT fuse blowing
- Really need help with buying injectors please!
- Help I need a stock LT1 engine rebuild kit
- Engine ping
- slp lightweight flywheel cracked..cause?
- Arching at coil??? 93 Z28
- Anything else I'd need? (cam install)
- bottom end for boost
- Stumped. Please help
- 1996 z28 problems
- 93 lt1 throttle body question
- 93 lt1 undedrive pulley system!
- Vacuum leakage?
- Strange Problem
- Help 383 stroker or 396 stroker
- COMP Cams Ultra Pro Magnum Rocker Arms
- 1996 Z28 A4 into 1997 Z28 M6
- CR too high for stock block that's been sitting for 10 years?
- Catalytic Converter?
- Pop, sputter, shake, etc.
- White smoke out of my breather? help!
- spark plug wires for headers
- Car threw a code help
- New engine
- spun bearing
- This is replacement or add on?
- Budget cam ideas
- I had a spare pushrod....
- Help me choose a cam for a truck
- Pop/backfire from pass side exhaust
- what are the new numbers
- these headers here..
- Shorted battery to ground, now no power w/new battery??
- V6 to v8 conversion
- air cleaner
- Some clarification on roller rockers..
- Engine Stalling...
- LT1 Serpertine belt removal
- What to change when putting 93 engine in 95 chassis
- Slight shake at idle and slight poping out exhaust
- Lt4 rockers, factory covers
- Brakes suck. The camshaft is robbing my vacuum.
- Car won't stay running
- Steam Pipe.
- This Part
- Someone with a stock cammed LT1 and a Scanmaster
- O2 bungs question
- Shoes Schematic
- AC delete pulley
- Cranks but won't always start
- What are the largest heads you can have while retaining the LT1 intake?
- Car has miss and split blm's
- LT1 Lifters
- Another question about TPS.
- Speed Density High-Flow Intake Setup
- A/C Inop and Cooling Fans Inop
- Here's one for ya !
- Valve boss - retainer clearance
- PlugWires
- Super sluggish off the line - 94Z
- Flexplate Question
- Anyone have a part number for this?
- Ferrea 6161/6165
- 94 z-28 wont start after de-grease
- where to buy o2s, extensions, header gaskets?
- Stripped a throttle bracket hole on intake manifold....
- Coolant bubbling out the overflow???
- another opti thred???
- No Idle, Low Vacuum, Missing on 6-8, WHERE to look now?
- rocker adjustment
- dose a 93 lt1 have a mass air flow sensor???
- stutter, possible miss
- 383 tuning
- LSx coilpacks VS MSD 6AL/Optispark combo
- dynomax lt1 longtubes
- Mr. Gasket 5716 head gaskets seem to be in short supply
- thoughts on build and hp estimate?
- Valvetrain help
- water pump problem
- loud squel under the hood
- Im a Newbie, HELP!!!
- 93 Z28 LT1 Stutters & Stalls at Operating Temp
- 1996 camaro Z28 for $1300
- what is the oil pressure for a 93 lt1
- I may have found the perfect spark plug tool
- EGR Valve Disconnected but not removed?
- Belt Tensioner Problem
- 383 Stroker question
- Stock LT4 Cam
- Help i have a leak....
- Cutting fender well..
- Guestion about balancing my engine
- Hesitation, Bogging, Stalling -- only during the first 10 minutes
- what is this part and how do you repair it
- Running LPPs, of course fitment issues
- Anyone elses ceramic headers rusting?
- Swap PCM?
- 96-97 z28 starter removal
- Help: Missing w/ Delteq p1351,p1361 codes, just started randomly
- heat issue...please help
- Brazing Pickup to oil pump(pictures)....
- Problem hooking up datamaster
- Decent Cam to Get Something Mild
- Can the opti timing cover gasket be replaced W/O removing cover?
- HELP!!!!!!! Car won't start
- Lt4 swap problem
- oil pump
- where to install O2 bungs on Y pipe
- need help
- Alternator
- 94 LT1 water pump installation question
- Heat Ate Throug Spark Plug Wire
- O2 Sensor Wiring
- Rod bolts...
- lt1 swap to a v6 no spark????
- Dynotuner
- *** 94 z28 leaking from exhaust this morning ****
- looking for a certain post/build
- Not going into closed loop?
- Exhaust Leak?
- Starter help (A4)
- Fel Pro Bolts
- Cooling fans stopped ?
- Oil comming from the throthle body blades?
- Need help reading datalog
- Starting problems
- Gas/oil/clnt snsr/fprl
- Engine oil priming problem.
- lt1 motor mount issues..
- LT1 Rockcrawler Won't Start
- New top end, "minor" detail questions
- new and need help!
- O2 sensor bad?
- cleaned up my MAF
- New rods
- 94 z28 Chokes/hesitates at 1-2 rpms??
- General Throttle Body Cleaning..
- LT1 engine upgrade any performance suggestions?
- Knocking with Vid
- Cam specs?
- Dyno #'s are in.
- 52mm TB and MAC mids
- running rough after cam swap???
- Bigger injectors?
- Exhaust HELP! haha
- Cold misfire under 2500 rpm, 94 LT1
- does this sound like a fair price for this job?
- 96 Camaro radiator design question
- passing mass emissions without air/egr
- Engine hesitation/buck/misfire?
- 1993 Z28 Hard cold starting
- Need help with PE mode
- SLP Intake
- LT1 to LS1 Swap need info
- 93 intake manifold options.
- Car wont rev over 2500
- ASM monoblade idle screw and sticking?
- Another Bad Day At The Track! Help Please!!!
- Induction Question
- looking for more power
- Where to buy 17/8 Stainless Headers
- Crank hub removal/installation
- Anyone have any ideas?
- Please help... electrical problem...
- LT1 Manifold question, bear with me please.
- lt4 hot cam questions
- Question on this engine set up seems to lack hp...
- Any difference between the two?
- Bad IAC, or another adjustment needed?
- Top pf throttle body function, LT1
- LT1 Radiator Question
- why are pushrod ends popping off?
- heater hose question....
- Need help asap! 96 LT1 AC line, I need a pic of the passenger side or something!
- motor mount ?
- flywheel/driveplate
- zo6 maf
- Need Help With Reading Log Files
- engine trouble
- Another rear main leak on fresh 383 build, possible causes and fixes?
- anyone ever heard anything good about these?
- How compatible is the LT1 to a SBC?
- steam pipe relocation for griffin
- Guess my dyno #'s
- Need valve spring compressor that will fit 918s
- 96 camaro wont start
- elec. waterpump
- HP estiamte?
- Is Balancing Necessary??
- Valvetrain ticking and oil pouring out of a few rockers
- Tach signal
- Help me out a bit.
- Tunner LT1
- Fuel pressure regulator hose
- can I use the stock pushrods?
- Low RPM slight surge
- Another ticking sound confusion
- how much did it cost you to rebuild your shortblock ?
- LTCC Setup
- LT1 Intake gaskets questions
- ??? adding SS Ram air to a '96 LT1 ??
- Which Fuel Injectors
- 93 z28 PLEASE HELP!!!!
- 93LT1 Stumbles on light accel
- Transplanting my motor from '94 to '97
- BeCool Radiator fitment problem
- What cam is good for stock LT1
- Why is my Z28 still running hot?
- Intake bolt tapped larger?
- dtc 64?
- Camshaft Question
- car died in the middle of a turn..
- ltl 94 z28 camaro
- Help Please - Runs Rough
- What hose is this
- vacuum leak
- Air Pump Removal w/o tuning
- Burning some wires
- AcDelco distributor w/ msd cap and rotor or AcDelco cap and rotor
- have a little problem hopefully
- Any Recommendations for a Top Notch Diagnostician in East Bay, CA?
- LT1 in a 2000 v6
- portmatching heads and intake???
- Icm
- new lifters installed in 94z28, no oil coming out of rockers/pushrods???
- Car Got A Bit Warm Again Today!!!!!!!
- Fuel System
- Felpro 1074s how much power did you throw at them
- which tb
- Engine going out?
- opti dist.
- Engine doesn't get above 165*
- EGR question
