View Full Version : LT1 Based Engine Tech
- OBD I Fastchip users inside.....
- Clutch Pedal Shakes
- Torque Converter question
- When do you lockup your TC?
- How do I make a 12 second car?
- Go steeper than 4.10's?
- I NEED shoeboxs coolant flushing website asap
- Muffler Suggestions to go w/ cutout?
- Griffin radiators for Lt1......
- Important ? (like aren't they all lol)
- Anyone running the Qwik Stick?
- Why does everyone ask.....
- Can My '95 model lt1 beat a 98+ mustang GT?
- lt1 flexplate? Please help!!!
- new rear end cause traction and abs lights to come on?
- HOW to drain/flush cooling system...
- cutout installation question
- Will Z28 ever come back??
- Problem installing injectors?!?!
- Camaro VS Iroc
- Please tell me about a 95 trans am?
- Removing my trans
- Recommended break in period for 4.10 gears?
- Hood question
- Oil Cooler Suggestions
- Which heads are better?
- Honest exhaust question......
- 94 Z service engine soon light
- aftermarket wire looms from thunder racing
- K&N FIPK Instalation
- finally home...now what?
- Formula surges at red lights, HELP
- Maybe you guy's can help me with my little ford ranger ?
- GREAT service from MAC!!!
- Anyone got an IAT module mod?
- is this worth it?
- Air Pump Fuse Blown
- Can My LT1 Beat a '98 Cobra?
- rear brake problem. caliper needed?
- Trans stick rubber grommet(s)???
- Elcheapo Cutout? Suggestions..
- Mechanic says LT1's have slight acceptable valve tap?
- computer chip
- How do you know if your Opti is bad?
- QUICK: need help installing shift light
- What to use to get the pilot bushing out. ( I have grease, but what object fits)
- Nitrous or S/C?
- No PSI Gains After Oil Cooler Removal
- What differential fluid?
- Found Great Deal on Z-28 Rear, worth a swap?
- Clutch problems!!!!! Help fast.
- valve sping locators in the way of head bolt
- compression
- Who has adapted an LS1 T56 to fit an LT1?
- MSD Crank Trigger kit?
- Size of stock crank balancer?
- Boxed oem lca's
- Question on LSA and using N20
- Any one else notice the new parts in summit?
- are the slp oil coolers better than the ...
- would a loose timing chain, cause pinging ??
- droped a lifter in the oil pan.
- help me out with some alarm info?? (i'm clueless when it comes to alarms)
- Opti Spark
- installing catback
- 17 by 9 1/2in rims could i fit 315s on them
- Headlight Control Mudile???
- header gasket install tip
- Rocker Stud Diameter for RR's on stock LT1 heads
- Gas gauge
- o2 extension length
- Anyone Have experience with prothane motor mounts?
- B&M holeshot converters
- water pump gear
- im stumped.......someone figure this out for me
- Can heads be ported without having valves and springs present?
- Changing T56 rear seal?
- Help identify mystery box...
- How did I make out?
- I just want an alt. overdrive pulley??????
- GMPP 1.6RR questions
- Trans rebuild part list
- What exactly is the optispark?
- optispark problems (car died)
- 275/40/R17 tires for under $140 a tire?
- How do you change out the short dialpin for long?
- could this be my opti
- Ignition coil
- '98 Rims won't fit on the rear of my '95 without slight grinding??
- Where to get iridium spark plugs?
- parts numbers needed please
- z28 newbie with a couple of questions
- Which "stage" port job for hotcam?
- New Best
- Is my car working right??
- Will Muffler improve Cutout sound?
- MSD Wires
- LT1 Misfire problem...help please
- What clutch?
- How and where do i get a door wiring harness?
- weird noise when starting car
- AS&M Cold Air Induction?
- I Need 30 More Hp...any Ideas???????
- How do I take the caliper slide pins out????
- Blown Head Gasket? But no water in the oil
- Anybody have a write up on taylor ovc's?
- Am I going to need an off road pipe?
- DS Vibration or What?
- Datamaster
- Is this a part number 10216948 ?
- Fuel Pump Prime ?
- Jt595ta/ Alum. DS?
- ABS Problems, Someone Please Help
- Plugs and Plug wires
- car is quiter after Mac header install?
- Jet Hot Longtubes
- Upgrade ideas while i'm there....
- pros and cons of SVO injectors
- Zo6 Maf Conversion on Lt1?
- ? Replacing headlight panel assembly on 93 formula
- AC Delco plugs - difference?
- anyone have exp with KVR cabon-metallic pads?
- Replacement Front Brake Rotors
- Optispark, intake and waterpump leak. Am I getting ripped?
- Knock Sensor replacement?
- 245-45-18 tires on 91/2 rim
- How hard is a cam swap?
- someone tell me if i have the correct Stage8 bolts
- Where to get touch ^paint
- Tire sizing question....Injuneer?
- 383 stroker?
- HELP!!!!! weird shat happenin o2 question
- I need your guys help ASAP!
- th350+3600 stall=10mpg?
- Where is the best place to buy AFR heads? Which ones?
- Accel 300+
- Speed limiter, and any way to change it?
- Anybody elses flowmaster catback not fit right?
- Aftermarket Wire Looms
- think i can break into 12's with 100 shot??
- which exhaust??????
- Ripper Shifter??
- Overtighten Pro5.0 Bolts ?
- best cam 383 for daily driver
- Dash popping? Steakes rattles? Subframe connectors?
- Question on airfoil installation? gasket?
- Who sells the pro 5.0 with lou's short stick?
- Need high speed suspension. What to get?
- Okay lets try to diagnose this.
- What were your symptoms when the power steering pump went out?
- Vented gas cap
- Best place to WINCH a T/A From
- Any way to delete VIN from LT1 edit, so it can be used on other car?
- 1st time
- Would it be worth it for me to switch to the R lifters?
- 85 mph vibration????
- Subframe Connector size
- how short can i cut it
- Dustless/ceramic brake pads??
- HELP questions on cam change, part replacement? yes or no?
- Converter Questions? 4L60E-700R4
- Oil Cooler Help ~ Big Mess
- double roller timing set on 96-97
- Dynoed the Car today, want 20 more HP!
- How to remove a T-mission
- bad vibrations when turning at low speed
- What does rod damage do to the engine?
- Cloye's double-timing?
- Starter Options
- cam on a v6
- these fit???
- Which heads to lower compression ratio
- making OVC wires BLOWS A**!!!!
- Hooking up a switch to bypass Knock Sensor
- Broken header bolt
- Anyone have a Good Fuel Pump install guide?
- dumb cam/heads install question????
- egr! cause really minor stumble?
- hotcam ?
- GOLEN engines
- cags & resistor done...just a few ?'s
- in reguards to 1.6 rr's and pushrod length
- RPM gauge and shift light
- Question about gear install kit and rear end cover/girdle...
- Whats wrong?
- Don't let people fool you, CC306 can pass emissions easily.
- foil tape on spark plug wires
- How bad will my handling be?
- doors shut with a SLAM!
- SFC's
- Roller Rockers, is this the normal sound?
- is a adjustable torque arm needed?
- how many people have broken stock main caps?
- autolite 104, is it one heat range colder than stock??
- What sensors differ from a 94Lt1 and a 97LT1?
- GTP body control module Problem
- how to test MAF sensor?
- MAC header owners, please help!
- how could i tell if my opti is dead?
- Need Help!
- idle problems after roller rockers?
- Need 12 bolt purchase feedback ASAP!!!
- Vented Opti Problem
- Fuel related problem Need HELP FAST!
- car not cooling right, STILL!!!
- Is Motive the best brand of 4.10 gears to buy?
- Question about my needle bearing?
- Just got my flow #'s
- grill
- headlight relay
- whats best to use on battery to keep from corroding
- How many O2 Sensors does a '94 Z28 have and where are they located?
- Which fluid for my new tranny and TQ?
- who has used honda atf in M6
- Idels rough
- stuttering after lock-up
- can i force car to run in open loop without O2's
- Engine Re-build (2nd thread)
- Engine Re-build
- Passed Emissions with a 230/236 Cam
- DTC PO1441 on 96 T/A
- what valve covers will clear 1.6rr's?
- M6 Stuck In 4th Gear At 105mph?
- Burning Smell
- Doing rear brake pads, have ?'s
- installing a double roller timing chain....
- Something is wrong, either I have a blown head gasket or i need a new opti
- $400, sound about right for.......
- Wiper Blades same as 98-02??
- How do you make an FFI SS hood functional?
- quick head ?
- Will vert. mount looms work with existing wires?
- Stumped (long thread)
- Battery wont charge HELP!!
- Why not just use Nitrious?
- M6 disassembly question
- Idles rough
- weird grinding/growling noise from trans
- Pro 5.0 Shifter and B&M Ripper, which has the shortest throw?
- 95 Y pipe in place of 97 y pipe
- LT1 "Hot Cam"
- Blown Head Gasket
- FLP LT's. What Gaskets?
- How do you delete the ASR?
- I need a new opti, where to get it and how much?
- What shift points? Stock 125k bottom end, HOTcam, heads, bolt ons..
- Should I just cam it?
- Power Steering flush..question about the "4th gen tech articles" web page...
- Transmission problem
- Car is misfiring pretty badly...
