CAM, can i do it or should i pay
Old Jul 21, 2003 | 07:42 PM
ZR1 camaro's Avatar
Question CAM, can i do it or should i pay
is there any other cam kits then the lt4 hot cam, i want somthing a little bigger and im running stock heads. Can i do it myself or is it worth it to just pay a shop. what is a good price for the install. any feed back will help, thanks
Old Jul 21, 2003 | 08:18 PM
gb95zconv's Avatar
Youll pay $600-$900 for a cam install plus the price of the parts.
Old Jul 21, 2003 | 08:21 PM
drewstealth's Avatar
Well i don't mean to be mean or unhelpfull but you should really use the search button. You will find hundreds of post about different cams and such. But the good ones for a daily driver with stock heads would probably be. Hotcam, cc305, xe 224/230, their are a lot others but thats all i could think of at the time. As for installation i can't help you there.
Old Jul 21, 2003 | 08:23 PM
ZR1 camaro's Avatar
thanks guys
Old Jul 21, 2003 | 08:46 PM
FTC's Avatar
FTC
if you got a good set of tools, good mechanical aptitude, some cash to get extra tools/parts needed, and patience you can do it. there are a few step by step manuals out there!
Old Jul 22, 2003 | 12:35 AM
Van5150's Avatar
I have not done a cam change, but, I did just change my water pump and opti. After you remove the opti, the cam, is sitting right there. I know I thought to myself the only thing I have to do is remove the intake and radiator out and I could remove this thingie. In looks like a all weekend event for the 1st timer like myself, but I tell you what, it does look do-able, very do-able.
Old Jul 22, 2003 | 02:09 AM
D James's Avatar
you can do it, but as the others said you might need to buy more tools, although this is only a fraction of the cost of labor if yo pay someone else. Its really not hard only time consuming, you must remember where wires hook up and bolts go, but its not bad if you mark them and put them in bags. The install looks more intimidating than what it is. You must be careful not to get dirt and junk inside the engine, and be careful about parts you remove and the steps in which you do them. This isn't bad considering all the guides and books out there, plus you can always post a quick question if you get stuck somewhere. I was qouted a price of 900 dollars plus parts, which for me was 600 bucks. So had someone installed them I wuld have been out lots of money. By the way combination motorsports in the vendor index can put together a cam package for you for about hundred bucks more than the hotcam kit, this way you have better parts with a more stout cam all in a kit that will work well. As for selection, it depends on how much power you want and how streetable you want the car to be, the bigger cams will make gobs of power, but will suck on the street, and you will hate their bad qualites, a nice street cam is the ex224/230 I wouldn't go bigger than a 230/236 for the street
Old Jul 22, 2003 | 02:52 AM
atljar's Avatar
I did it myself, and it went pretty well. I am however pretty mechanically inclined and had a set of tools handed down to me to die for.
Autozone also rents out tools for free that you will need like spring compressors.
Old Jul 22, 2003 | 03:25 AM
CamaroRob97's Avatar
"You con do it" Meng!!!!!!!!
cc 305 cam Only "streetable" way to go...just remeber to get new valve springs!!!!! Comp recomends their 986-16 springs for that cam. Also while u got her apart u might wanna consider an Electric W/P. I did mine all at the same time, the only bad thing about doing a cam is that u gotta get the AC system vacummed/flushed out and and recharge it. other than that its a great way to "wake" that LT1!!!!
Old Jul 22, 2003 | 07:29 AM
NVetro's Avatar
Why do you have to empty and flush the ac system? I could have sworn my friend didn't do that and he did an lt4 cam package on his 96 ws6 formula.
Old Jul 22, 2003 | 06:05 PM
gb95zconv's Avatar
Ive heard a few people say they did it without removing the AC core coil but I really dont see how you could pull the cam without removing the core.....I suppose you could try it though.
Old Jul 22, 2003 | 08:21 PM
Slayn's Avatar
You can, just roll the condensor on it's side just enough to get it out of the way of the cam as your pulling it out, you can do it without removing any hoses from it, some people say they had to remove the hood latch also but I didn't end up having to.
Old Jul 22, 2003 | 08:36 PM
AsianSensation's Avatar
I had to remove the hood latch.
Old Jul 22, 2003 | 08:57 PM
FastZinTennessee's Avatar
I rotated the condensor out of the way with no problems. I didn't have to remove the hoodlatch though.
You can do the cam swap, just make sure you have a way to get around. Cam isn't too bad, heads and cam is pretty rough though.
John
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
