View Full Version : LT1 Based Engine Tech
- 93 z rpm jump untill warm ?
- What do I need for posi?
- Why does my fog light fuse keep blowing?
- rear end is making a griding noise
- I need advise
- I need a part number for the PCM Temp. Sensor in the Water Pump...
- Gtech real simple question
- Opti and balancer install
- cold start internal motor noise help
- 383 vs. 355 (need some info here)
- new chrome wheel bent after only 1 day?
- throttle body bypass
- Dumb Wheel Combo. Question!
- PCMforless yourself tuning problem
- M29 guys running 12 bolts?
- Fuel Systems
- removing air pump , egr
- egr questions!!!!
- Opti write up
- NEW -- programming services for camaroz28.com users...
- Testing the market. What is this LT1 engine worth?
- 52mm Vs 58mm???
- Flowmaster catback exhaust 2.5"?or3"?
- Strange power steering leak
- After running at SLP day yesterday I have decided that I need more than bolt-ons..
- Can you buy JUST a SPEC clutch disk???
- Converter
- Wiper motors are going?
- piston to valve clearance with LT-4 hot cam?
- Heads off, T56 tranny, Hooker longtubes from the top, WONT GO IN!
- 2 ques. pulling the balancer and engine block drain plug.
- big problem!!!!
- transmission question
- lt1 rebuild
- Boxed VS Tubular
- Street Slicks
- Alternatives to Jet Hot??
- Valve part numbers
- Hot cam and spark plugs?
- Intake Manifold ?
- What happened to my t56?
- AfterMkt Muffler: Do I want this?
- anybody with a Hooker Aerochamber sound clip---->
- Condensation in valve cover cap?
- Wheels...
- dist. cap change please reply!!!
- Possible screwup. I think. Info needed.
- New Muffler installed
- What is the highest compression ratio you can go while still running on pump gas?
- Pinging - stumble on part acceleration and idle.
- lg motorsport cai
- Where to get 9" for $1700-$1800
- How to bypass vats? (fuel pump)
- 1.5 or 1.6 RR for my setup?
- Long Tubes with 1 inch drop will it work?
- Electrical Problems?
- cheapest header supplier
- stock hood vent...functional??
- quick question about installing gauges(dash)
- The new Vigilante 3200 is in!
- after warm up the engine sputters when i hit the gas??
- new seats?
- pics of fogger setup?
- MAF problem
- lost power to the fuel pump
- Can my mechanic do this?
- bare header question!
- $250 to spend on heads for clean up/port is it worth my time
- Nitrous + JE ultra-lites = BOOM?
- header gasket question
- egr!
- Whats it gonna cost to have my wipers fixed?
- Breaking in new engine
- A.I.R. pump quick question
- Suspenion Rebuild
- Automatic Headlight sensor problem
- Where does the pipe plugged passage in the intake lead to?
- MAC headers
- Squeeking noice from rear LCA's after Boxed BMR Install
- Troubleshooting help needed.
- Transmissin I/D question...
- TH350..Which Dealer makes the best tranny ??
- changing plug wire your self...any instructions??
- Best Ignition Upgrade?
- Coolant Loss, Possible Head Gasket Blown?
- What would be easier, long tubes from the top or bottom?
- HELP! steering linkage hits headers after BMR k-member install!!!
- Need PN External Clutch Slave cyl
- resetting the pcm
- LT1 Tech
- What size front rims??? What tire choice???
- TPS% runs smothly to 100%,then hits 4% w/last 5% throttle travel,/??????
- What is the cheapest adjustable fuel pressure regulator?
- 94-95 headers on a 97???
- Lt-1 heads
- The dreaded "Service engine soon" light
- Specs for LT1
- 94 Firehawk exhaust/emissions questions
- EGR and AIR block off plates?
- !!!Please help me with this!!!
- UPGRADE fuel injectors????
- what hp should i be at?
- The free mods you can do to your car yourself
- Checkin transmission fluid
- Fuel tank removal and Evap Emisions line Q
- why do the stock pistons have a nipple
- Detonation!
- Where did you buy your hotcam kit????
- G Force KDW Tires
- All down hill from 80K?
- Best fuel injector cleaner
- Too many problems
- Pinion Angle ?
- What size valves can you safely fit in the stock LT1? Who makes them?
- ? on removing Air pump
- Fastener Tightening Specifications 1997 LT1
- Engine Mechanical Specifications LT1
- Make my friends 30th aniversary beat me
- Hitting rev limiter with 2800 stall!!!
- Bosh 02's
- shock
- anyone ever put a STOCK MUFFLER on a Heads/Cam/Longtube car? (video clip inside)
- fuel gage reads incorrectly
- Has anyone ever seen a WS7
- weight deductions
- LS1 top end vs. LT1
- Firehawk and ws6
- Borla XR-1 and LM Exhaust?????
- possible short? check guages
- power locks
- got a video of my car tell me how it sounds
- What do your bolton LT1s Trap???
- Passenger side plug removal
- Driving Me INSANE!!!
- HELP, Header question - steering linkages removal!
- calling all STRANGE owners, how do i know what series carrier i got?
- 4.10's installed yesterday!
- track times
- Rear Lug Bolts Loose???
- McCleod Clutch
- Need M6 stuff part numbers..
- That Damned Slip-fit Primary!!
- installed first mods today
- Best Frame-ties
- motor quit no mil lamp?
- Why does my new clutch setup engage at top of pedal throw?
- favorite suppliers?
- Engine running warmer after TB bypass??
- Pulling engine questions
- 96 SS and gear question
- Do these calipers look right?
- valve covers to fit 1.6 rr's?
- 17x9.5 ZR1 rims spacers? lowering springs?
- Is Bryan awol?
- What gears?
- those resistors people are selling on ebay as performance chips
- Pushrods
- SLP PP with a SPEC Disk?
- can sloted rotors be turned?
- Need analysis of repair/sell/part-out situtaion
- OBD1 diagnostic tools sold at what stores?
- 1993 EGR and Airpump intergrated question.
- Valve Seals
- OptiSpark Seals
- Think I Lost Alot Of Power With Exhaust!!!
- Cruise Control + DR's + Rain = A Change Of Skivies!
- Headers from dual cat to single cat
- What kinda hp am i making...
- Pushrods
- Cat clogged, need exhaust options inside...
- How do you clean injectors? Do I need new ones?
- Pushrod Guideplate
- piece of copper pipe glued in bbk tb?
- Symptoms of bad Opti?
- headlights
- What should I set the Fuel Pressure to on the 355??
- fuel rail covers
- 17x9.5 zr1 rims..spacers? lowering springs?
- Removing air pump what to do with empty holes in headers
- Flow Numbers and pics of home ported heads!!!
- best cold air intake slp?moroso?k&n?
- removing traction control
- a4 trans problem HELP!!
- Spintech muffler ?
- Tubular front k-member
- What do you guys think of this
- Difference between 95 & 96 sensors, ect
- Where to get Opti Sensor?
- Knock Retard
- Oil temp gauge....Where to tap?
- What Flywheel and Clutch are u using on your T-56?
- Axle and differential problems
- Any one have any tips for removing my $#@%^$&$%^ oxygen sensor? (edit by moderator)
- MSD Ignition, what spark plugs to run??
- best suspension mod to stop wheel hop?
- Attn: Fred
- 12-13mpg on a bolt on car wtf. Fuel effciency question within?
- new exhaust set up needed
- Nitto's!!! What PSI at the track??
- DAMN Timing Cover!!!!
- How many miles do stock springs last?
- Is it Worth it to Swap in A LS1 Gas Tank?
- A4L60E aftermarket Stage 3+ Transmissions. 383 Stroked LT1
- EGR Valve
- TH400 Crossmember?
- after new opti install
- heater core
- Help Needed
- adjusting R series lifters
- Best Sway bar for Moser 12 bolt?
- need soundclips of your "gear whine"
- what the heck??? someone go try this....
- avg. MPG lost with !CAT
- How bad does 100% humidity effect performance.
- where can i look for camaros w/o engine?
- T/A Adjustable Headrests....fix?
- Mufflex y-pipe install...MAJOR RATTLE!
- Exhuast Thought
- welding in SFC...remove interior?
- Retard timing related to gear possible?
- firehawk emblems
- i was readin from the rear wheel 383 page and have a ?
- Will I pass emissions?
- any 1 know where u can get a warbird hood for kinda cheap? throttle bod ? also
- Help with Clutch/shifting problem!!!!
- Should be in the 12's, right??
- XE grinds and the need for new lifters.
- Any Aftermarket LT1 Intakes?
- Engine knocks
- Good flow numbers?
- "Pushing" the powerband down
- Just finished cam install! XE 230/236
- Which rear end assembly should I choose?
- Pulley
- OBDII Diagnostic Tester
- random multi cylinder missfire? help
- Intake Elbow
- question about little hole on lifters??
- Pinging.
- recalibrate spedo?????
- Fuel Injectors
- Any hints on re-installig the timing chain??
- chromoly rust?
- HELP!! LPE’s cold air induction Issues....
- part number for plug wire in summit, please suggest me a good one
- Oil leak from oil cooler
- rev limiter
- Chassis lubrication
- One Last Time: What Things Are Needed For Heads/Cam Etc...Swap???
