One green wire left by the MAF Whats it for ? Shoebox ?
Old Jul 21, 2003 | 06:14 PM
HardcoreRM125's Avatar
Question One green wire left by the MAF Whats it for ? Shoebox ?
I'm almost done hooking up all the wires that were unhooked from the car when i bought it. Im down to one wire. Under the hood, there is a bundle of wires coming towards the front of the car along the driver side valve cover. As this bundle gets up by the ICU and MAF sensor , it splits. The coil wires/plugs, the MAF plugs, and 2 grounds come out of this main bundle ( Its about a 1" thick black plastic bundle. Where the MAF, Coil wires, and grounds come out of the main 1" bundle, there is also a smaller black wire cover that comes off. Its about 3/8" in diameter. In this wire cover is a green or teal colored wire, that the end of it is appently dyked off. What does this go to ? I need to no asap. This is the only wire i have left on the car before Im gonna try starting it. Anyone know what this is too ? Could someone maybe go into the garage pop the hood and follow it to where it goes and lemme no ? Thanks ... Also , the car is a 95 Z28 Vert, M6
Old Jul 21, 2003 | 06:20 PM
Also , the little 3/8" black wire cover with the green wire in it is about 2 feet long if that helps...
Old Jul 21, 2003 | 06:40 PM
Betcha it goes to the temp sensor for the gauge. It is supposed to have a double cavity plug on it, but only one side of it is used ("A"). It's a dark green wire.
Old Jul 21, 2003 | 07:18 PM
Shoebox i owe you yet again... You've been more help then anyone in trying to get this thing back together... I donno how i coulda missed that senser , but owell that is the last of my wiring problems ... i think lol ... Just one more thing tho, I dug through the garage, and found a plug end that goes into the sensor , but how do i hook the wire up to the plug end ? lol wow that is a stupid ? ... but it needs to be asked i suppose ...
Old Jul 21, 2003 | 07:26 PM
Since i got the plug outta the garage, it has A and B labeled on it, but its not from a F-body so incase it is switched from the way a F-Body is labeled , which side of the plug is the wire in? Like base whether it is left or right as if you were looking at the plug head on with the clippy part that holds it in place on the top. Thanks ... If thats undoable for you now then ill go with the one you sed to use in the first place
Old Jul 21, 2003 | 07:37 PM
Looking at the plug (the part with the wire on it ) and the clip on top, the wire should be on the left.
Old Jul 21, 2003 | 07:44 PM
Noenav
Mar 1, 2019 07:38 AM
pete53
Dec 9, 2014 07:31 AM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
