View Full Version : LT1 Based Engine Tech
- I Need to know the Length of my Z28 So I can Buy a car Cover!!
- plug recommendation for 383
- Trans brake or not
- Temp Gauge Not Working
- Listen To This
- How to tell what kind of pushrods I have.
- Trans or ignition?
- Can I use a cracked bellhousing
- hardened or chromemoly ???
- more OBD II trouble codes
- vented opti swap\electric h20\cloyes questions
- Which retainers with these springs?
- water pump drive shaft o-rings
- Electric w/p question....
- O2 sensors
- ignition module
- Lost 3rd and 4th today
- ppl with bbk headers for dual cat car's inside please
- burning oil
- PCV question
- TB bypass
- LS1 Brake Upgrade. Please tell me what I need & need to know..
- Homemade CAI Help
- is there a way to disable the reverse lockout
- waht cai ?
- Airfoil Help
- launching question
- Noooo!!!!!!!!!
- LM and Hooker catback Question????(not normal question)
- valve springs
- AFPR - ideal PSI????
- Two questions about optis
- 94 coil upgrade to 96-96 coil?
- Yokohama's or Sumitomo's
- Can we use wheels with standard offset?
- Headers
- Who Would Win
- A4 Question
- XE comparison
- B&M Ripper vs Pro 5.0 my opinion(just switched)
- ? about removing the EGR system.
- Why NGK TR55's...Whats so special?
- Just pulled my engine from the top!
- question before i change my fuel filter
- 383, 15 psi Vortech, how much power?
- the count down starts...help me b4 i do stupid....
- Shift knob
- mc cords website
- cam surge!?!?
- How much tranny fluid does a T56 hold?
- Mech Temp Gauge
- Muffler/CAI Question
- Roll Cage
- Installing an LS1 Master Cylinder, anyone do this? Having a Problem...
- Where to buy a distributor for $300 shipped
- Electric Fuel Pressure Guage Install
- What's this ghetto CAI unit?
- skinnies up front
- need answers quicly about diff. tires sizes front and back. ABS EXPERT inside pls
- anyone know why heater won't come one?
- Trans Mount Part Number?
- Car wont run after stopping it while doing cam break in!
- will having differential oil change help??
- RLB/LCA Help
- what is the logic behind the AIR pump?
- WOnt let me regester my z28
- 6 speed gauge cluster in an a4 car???
- Comp R lifters are in production again
- Blown Head Gasket
- Sound clip/video of 383, big cam, FLP headers, borla or similar. Anyone?
- Guess my codes before I PCM scanned
- What size bolts for the mufflex ypipe?
- Updated my HVAC controls from a 94 to a 99 (lit nobs), need defrost wiring diagram...
- exhaust question
- whats my car worth
- Rapidfire platinum plugs
- XE 230/236 on the way, what heads though?
- will v6 guages work on a v8?
- easy lt1 mods
- PCM codes, deleted for emissions?
- factory alarm / keyless entry
- Freeze Plug? for Water Pump
- Street Twin.....will a stock master cylinder work?
- Jet hot egr hook ups were wrong
- BAD Torque Converter, killed my tranny
- hub ?
- What Are Some Good Upgrades for LT1's That Can Be Had From LS1 Cars?
- code 34
- Anyone use Header Studs?
- any thoughts on 4.56 gears with cc306 cam
- 95 with stock quad tips??bs?
- Which head gasket? LT4 or Felpro 1074
- Autozone or Custom
- Where can i get an LT4 knock module?
- Cobalt Fuel Pressure..........
- Is It Ok To Drive My A4 Home After 3.42 Gear Change Without Programmnig
- Quick Fan Wiring Question!
- Drive through car wash - opti question
- LT1 Block
- backspacing with weld wheels
- Lt1 Edit Cable
- Valve to piston clearance with CC306
- dealing with AC on cam install....
- 4:10 or 3:73 from 3:42???
- What plugs are you guys running?
- Help!!!!!!
- MAC Headers question
- built 4L60E?
- Radiator fluid in oil pan? Rad. fuid leaking from pass. side head area?
- brake light stuck on after a hard lockup
- looking for low mount alt. bracket
- What mod to do next??
- Installing 1.6 rrs and LT4 valve springs?
- Local Engine rebuild?
- 94 t/a a4
- Mixing oil
- 96-97 camaros with the Hooker long tube- O2 question
- LT4 cam kit or 75 shot nx?
- Does anyone daily drive a th-400 or 350 down the highway??// what rpm??
- LT-1 against a 700-R4
- 1st Time down track...
- 4" Mufflex w/ Spintech too big?
- Serpentine belt keeps getting tossed out thru the bottom of the car!
- is the LT4 pressure plate better than a McLeod one?
- Ses Light
- ls6 maf on lt1
- is the SLP pressure plate the same as an LT4 one?
- Simple fan switch
- Mod vs. Improvements list?
- code 45??
- Which cam for my '93?
- Paging Shoebox--Oil Pressure Sender Question
- Taking Alternator apart??
- why wont my valve springs compress all the way?
- Mez wp in LT1 pump housing?
- 1.6rr???
- Installed Newest Canton Oil pan!
- Houston porters?
- Best price for FLPs?
- Budget Catback
- so if you break a bolt off in the head taking off the stock manifolds...
- transmission mount Q???
- Can anyone go WOT in 1st gear? What tires do you have?
- Frt Sway Bar Quick Disconnects,anyone make em??
- Quick question for those who bought the cmotorsports cam, rockers and springs
- 1993 4l60 shift kit problem?
- What fluids/ how much?
- dont know whats goin on HELP!
- what does an lt4 knock module do?
- AC Delco Wires and Plugs - Need p/n's
- tac wire for shift light, where is it??
- Blew Head Gasket! Help?!
- Difference In sound between 3" and 4" exhaust?
- HELP QUICK! Clutch fork: goes between t.o. bearing & square? or on input shaft...
- i think i messed up getting 18s
- technical pulsewidth/ignition question (Accel DFI)
- 2000 rpm stumble tried it all!HELP
- which are better for racing
- quick dynatech question
- New ignition
- Dynatech or hooker
- If you've changed plugs/wires on a dual cat lt1....HELP!!!
- Jet hot headers are wrong
- LT4 Knock Module----WOW!!!
- Next Mod Opinion
- can i get 18in Nitto DRs? or BFG DRs?
- anybody running true duals with longtubes?
- 396 oil pan?
- Oil Pump HELP!
- Any Problems w/ CAI After Rain?
- Underdrive Pulley's Good or Bad!!!
- Ported Heads without porting the intake? How much HP will I loose?
- What is the stock stall on a 94 z28
- 3:23 vs. 3:73
- Qustion??
- lt1 to ls1
- t5 5 speed trans
- How Much????
- Ignition Wires
- My Jet hot long tube install also slps for sale
- Feedback, Opinoins on Speed Inc. in Il.
- I have gas in my OIL!!!!
- Corsa owners....
- Tourqe specs for Weld Prostar XP
- 3:73's or 4:11's?
- Rear Main Seal: Lube prior to installation?
- Derrick >>>>
- Leaded fuel?
- TCI Convertor Part number help
- MSD injectors
- oil
- Shoebox-->> Charging System Q
- where can i buy a just an air-bag (suspension)?
- Anniversary SS Filter??
- How much should a water pump cost?
- MSD 6AL mounting location?
- 150miles to the tank....
- Wheel backspace questions.
- determining options on your car from factory
- ANy one know this part? converts centerbolt ValveCovers to standard bolts pattern
- what's that oil smell???
- where to put cutout
- PCMFORLESS questions
- about to purchase firehawk
- factory sway bar size??
- 3600 stall too much on stock LT1?
- put my car to WOT, sometimes no torque?? wtf
- Gear question?
- Gas smell help..
- Anyone who did DIY 02ext in here.
- Need Help blew clutch?
- PCMforless OBD1 conversion
- broke exhaust manifold studs leading to y-pipe, how to fix?
- 315-35's and a line-lock
- just bought lt1 & tranny... good deal?
- 305vs306. 305 wins it hands down!
- Ported heads for free!!
- What kind of 1/4 mile times w/ hotcam
- looking for 1.6rr install guide
- SFC In Canada???
- Stupid question. I don't need guide plates do I?
- Gears
- ZR1 Wheel Back Spacing Question
- Help, Car is running like crap!
- I have about wheels and tires
- What's some good springs that won't lower my car?
- Which clutch/flywheel to get ?
- LT1 head question
- 383
- Change ABS reluctor with gear install?
- All power in the car dies after turning the key
- Bone Stock 13's? Post Your Slips...
- people who's in mid to low 12's with a stock heads, inside please
- SES light
- Z06 MAF, 4 simple questions
- Picture Of My Car Leaving On My New Best 60FT- 1.7!!!
- not sucking in seafoam
- LM with hooker aero chamber muffler???
- Which Cam ????
- radiator removal question
- Fuel pressure problems
- Felpro gasket kit same for Impala and F-bod??
- THe engines done now a few timing questions
- Can I run with.......
- Car On Last Breath? Need Help!
- tapping at idle
- Head gasket thickness and cam selection
- 93 Speedo
- Mufflex Y-pipe and Driveshaft Loop?
- I really need a definite answer, no maybe's here
