View Full Version : LT1 Based Engine Tech
- Anyone make "stock" looking 93-97 TA fiberglass hood?
- How do you remove the oil pump shaft??
- Anyone use header wrap?
- Spec clutch questions...
- Heads and cam questions....
- Mcleod Clutch break in time?
- What causes smoke to come out front of intake?
- adjusting speedo after gear change
- ATI Intercooled Procharger for LT1???
- Security Light
- Exhaust rattle (heat shield loose)
- Break In Period On Motor?
- Caps for SLP shorties....
- Rebuild Questions??
- .35 plug gap curred my stumble but why?
- All of my plug wires are arcing??
- cometic MLS gaskets?
- Valve Covers for 1.6RRs????
- lt1 vavle covers
- Rough idle?
- Very odd tranny problem (help!)
- Where's the leak?
- What will a miss sound like?
- 93-95 and 96-97 plug wires the same?
- broke another engine mount in 6 months
- Scanmaster install location?
- k&n air filter
- How to cheat emmissions 101! Hopefully
- Racing my auto lt1 some question on overdrive and stuff?
- Where do most people screw up lt1 heads?
- Tranny Broke again
- Timing Cover Torque Specs
- Going to save up for a tranny next summer any ideas?
- Effects of plug gap....
- Did third gens have 1le driveshafts standard.?
- Is vigilanete worth the bucks or should just buy cheaper stall??
- changed fuel filter..still hard starts
- what happens when you unplug the IAC? Idle goes down or up??
- quarter mile time??
- Fuel Pressure Regulator and SES code
- 93-94 Headers.
- Car stutters need help!
- Why does the car only miss in 3rd and 4th gear
- 180-190 miles to empty in my 95 Z ?
- My Car Is Falling On Its Face
- How are these dyno #'s??
- How Much HP?
- Help! fuel question
- Anybody have an inline fuel pump??
- SideExit
- What's needed for LS1 brake upgrade
- ok i am confused
- Need answer quick concerning low temp fan kit
- Could I get into the 12s for $1500???
- LT,Off RD pipe,muffler or no muffler sound clips for LT1???
- no bolt on power steering pulley
- Should I have the rev limiter raised?
- Security light fix
- where does the air pump plug in?? need help fast
- New rims..now what size tire??
- Stroker Kit
- what is this
- HELP!!!...flashing SES light after head/cam install.
- Error Code P0140...help!
- Tube From Back of Intake to Exhaust???
- Charcoal Canister Removal
- EGR Removal
- Where to get Factory Service Manual
- water temp sensor
- Keep car in open cycle? can i?
- Dragging engine on the ground
- Oil leaking out of Oil level sensor....
- repair broken dowel pin/cam
- car stalled 3 times while trying to start this morning
- Engine noise
- K&N intake kit + traction control: any problems?
- All this talk of 1.7RR's, have a couple ?'s
- Guage in cup holder, how did you do it?
- a bad Opti spark, can it cause backfiring?
- Exhaust Manifold Gaskets
- is there a GM (General Motors) brand of gears other than factory?
- Need more traction
- Camaro vs. Caprice Engine Wiring Harness?
- M-18 Drain Plugs??????
- 519 hp and 585 ft lbs of torque at the wheels!!!
- Quick ? about blocking egr
- LT4 valve springs are 1 5/16", WTF?!
- Oil Analysis results from German Castrol 0w30
- To spray or not to spray......
- belt really needed?
- opti spark(TROUBLE CODE) for 1995 Z28 Camaro
- moroso cai
- store parts that have o2's?
- LT1 rebuild
- cam question
- Changing To True Duals....What's Best/LOUDEST Mufflers To Go With?
- popular exhaust systems
- thread size on flowtech cut out
- Good Shop To port heads
- VSS Wires
- Could a gear change cause this?
- Dummy O2
- Where do i find hardened pushrods for a 96 TA ????
- Got some dyno #'s..not good
- What year did they get rid of opti-spark?
- My luck is the worst. LT-1 Honing ?'s
- 1,000 to spend
- McLeod streetwin sucks....need a new clutch!
- which fuel pump?
- right bank running lean! HELP!
- one question about false knock
- Fix a Dent in header?
- Which 1.6 rockers are the best?
- oil leak...
- Adjusting valves while idling...
- Running rich????
- PCV question-injuneer??
- vibration or droning noise at like 120km!!
- cutout...wow
- easy coil Q
- How to Identify an SS hood as OEM?
- What is your favorite mod you've ever done?
- My worst knightmare
- 97 mid VS 94 midlength headers
- Can you dynotune a 93?
- who has removed their EGR.. ?
- Bad vibration @ 1-2 shift on an A4 Z28
- Removing AC
- Big CAm + Emissions
- Rear Brake Issues...
- port stock TB
- Battery level dropped to red...???
- High rpm crap out
- Hard to start, sometimes
- jumping out starter?
- Alignment specs after lowering?
- All My Gauges are off?
- M6 or a stall?
- Can the alternator go out slowly?
- Anyone have success with Cyberdyne fp gauge?
- Cam timing Procedures???
- weird stumbling prob
- Car starts for second then stops! Help
- stroker buildup question
- Will 15" 3rd gen wheels fit a 4th gen?
- low coolant light keeps coming on
- Bleed coolant while engine running? How to exactly..
- Trunk latch on 95 Z how to take out?
- My Borla Doesnt Bolt Up
- Advanced Induction Head Porting
- radiator question
- Purpose of Polished Combustion Chamber????
- 2000 SS Wheels will not fit 4th Gens
- Loose Torque Convertor?
- pipe size
- how to properly jack up my motor for longtube install?
- Need Some Help, Someone Parked On My Hood
- Stock exhaust size?
- SES Light Went On
- CFM #s at what lift?
- Car backfires slightly when cold?
- 275 stock or more a little rumor i heard
- How big is gas tank?
- Jethot headers w/emissions
- Fog lights for a Formy
- What size Drag Radials can I fit on the rear?
- Mufflex Y pipe leaking in several spot?
- Intake Man. and Oil Pan Gaskets
- How hard to change hoses? Also heater hose question
- still misfire(new opti,plugs,ignition)
- New Times at the track
- Electrical question...
- aftermarket cat for hooker shorties?
- LCA and Panhard bar on ebay
- GMPP Hot Cam Kit????
- Possible Cam Install
- Brent's Fix it site???
- Paging anyone with Jet Hot LT, off road Y, and Loudmouth
- Brake Light
- Is there a drain to get rid of leaking coolant around the heater core?
- whats the most you can get out of a 350?
- throttle body question
- Any high mileage/big hp stock rears ends out there?
- Headlight mod; bulb P/N
- AC line touching header tube, any ideas?
- What is a Governor Pressure Sensor?
- Once again, I need advice.......
- 383 Stroker .030 over is 6.3liter, so what's a...
- Keeps Dying
- Question about how our cars learn
- 1993 Style SLP SHORTIES.. USERS INSIDE PLEASE
- Suggestions for Winter Mods?
- Long Term Fuel Trim Values
- stock rearend durability
- Flying air pump....
- Just got Bilstein shocks have questions on install
- Tranny temp. gauge pinned over 250 Deg. !!!!!!
- Degreeing the cam.
- Would I see 11 sec timeslips with this combo?
- 93-97 TA Ram Air Hood and Air Box question?
- !tb
- Hypertech PP III
- What is a AFR hydra rev kit ???
- Bounceing of the Rev limiter?
- Easiest way to hook up fog lights switch to foglights?
- How to spin in a manual
- What size tranny cooler?
- Deep tranny pan part# &...
- PCM differences
- LT4 knock sensor on OBD1
- Which MSD pill to use???
- Any one with this same sound
- spark arching
- Moser 12-bolt...what size U-joint to use?
- hypertech pp3
- car runs then dies and will not start
- relocating battery to the trunk
- Throwing codes,77,83,84 after wreck.
- GM high volume oil pump?
- cats
- neutral safety/reverse lights switches and wires
- LS1 Coil Packs
- Powerglide
- Service Engine Soon!!! AGAIN
- 3rd cat in 1 year... cause?
- GMMG Rev/Cam Idle Vid
- A common hesitation problem?
- Air Pump Relay gone Bad? SES light. Help Please
- Lightweight FLYWHEELS .... pros/cons?
- G-tech Pro Help?
- Motor mount question
- Question about GM parts??
- Should I get 1.6 roller rockers?
- Clutch question
- brake problem
- What plugs with AFR 220 heads?
- I have some Problems....Need Help
- spintech mufflers
- VSS parts forTH350?
- clutch dust ... all the time.. no pilot bearing
- Scanned car-my injector PW is 2.8ms at idle? and more...
- $25 hypertech 160 deg thermostat vs pep boys $5 160 deg thermo?
- winsheild wipers
- Link Error w/ dyno???
- Sloppy steering
- What will happen here
- Cams does it do this???
- What else do I need with the cc306?
- Compression Test
- rough idle?? popping backfire..
