Decided on 4.10's....what do I need to order??
Old Jul 19, 2003 | 01:32 PM
Robbie's Avatar
I have a mechanic who runs pro stock cars who said he would install the gears for $150. What do I need to order from ThunderRacing.com?? Cant I just use a spacer instead of changing the carrier? Can I just buy the $200 4.10 gears from Thunder and give it to the mechanic? Also which gear brand would you prefer me to get? Strange, Motive etc?? Thanks.
Old Jul 19, 2003 | 04:04 PM
xchief1320's Avatar
I personally would only get Motive gears,BUT they don't make the 4.10's for the 2 series carrier..So if you don't want to change carriers you have no choice but run a Strange..
Be ready for noise..Motive's are the only ones that never seem to make noise if set up right"and i do them for a living" in the 7.5's..
Good luck
Steve
Old Jul 19, 2003 | 05:18 PM
Robbie's Avatar
Hmm. I might just buy the Motive gears and new carrier. My friend has a 95 Z28 with Strange 4.10's and they whine badd.
Old Jul 19, 2003 | 06:06 PM
zuluman13's Avatar
I probably sound stupid but what is a carrier and what would i need to change i want to do motive 4.10s
Old Jul 19, 2003 | 06:09 PM
raceryan's Avatar
I have motive 4.10's and they wine like a fire engine. I want to try to get them set again.
Old Jul 19, 2003 | 06:28 PM
xchief1320's Avatar
The carrier is also called the Posi..It is the differential in the rearend..And that depends on what gear is in your car now..2.73,and 3.08's all use a 2nd series carrier and 3.23 and above use the 3 series..
Good luck getting them quiet now.After they have been run with a bad setup the pattern is already set..Not saying it can't be fixed,but highly doubtful..It would be a hit and miss kinda thing really..
Good luck
Steve
Old Jul 19, 2003 | 07:04 PM
raceryan's Avatar
So I should just leave them be? I don't know much about them. That's why I paid for the install. I don't want to pay again if it won't help any.
Old Jul 19, 2003 | 07:17 PM
xchief1320's Avatar
How good was the guy you paid to do the install? any people you talked to about his work?
And how many miles have you had them in with the noise?Did you contact the installer and let him know?
Steve
Old Jul 19, 2003 | 07:44 PM
zuluman13's Avatar
Good luck
Steve
I am pretty sure i have 3.23's so that means i dont need to change anything right?
Old Jul 19, 2003 | 10:56 PM
xchief1320's Avatar
Correct IF you have 3.23's and above you have the 3 series carrier..NOW if you have a ZEXEL,or Thorsen Diff you might have to runt he SLP "paddles"aka crosspin as they call them..Otherwise it is impossible to get the center pin in..If you go to SLP site and look for the Zexel take out's the paddle kit is there..
IF you have the Auburn style carrier you don't need them,the stock crosspin will work..
Steve
Old Jul 19, 2003 | 11:08 PM
zuluman13's Avatar
how do i know what i have
Old Jul 20, 2003 | 12:34 AM
kevinsz2895's Avatar
hey man i got richmond hears and they have very litttle roar inthem and i put them in myself and richmond makes them for a 2 series carrrier also just fiqured i'd let you know
Old Jul 20, 2003 | 01:39 AM
Robbie's Avatar
Oh so basically all you needed was the gear set?
Old Jul 20, 2003 | 02:19 AM
kmook's Avatar
Advanced Tech Moderator
I always got an installation kit in addition to my gears-
http://store.summitracing.com/partde...rt=RAT%2D308TK
Old Jul 20, 2003 | 02:43 AM
Robbie's Avatar
OK thanks alot for the info guys. Now one last question.
Strange or Motive??
