View Full Version : LT1 Based Engine Tech
- shorties or lts
- open loop runs fine, closed doesnt...
- Wanna run a cat, but I've got a big cam
- Thumbs Up For Loud-Mouth
- Descreening of MAF
- Poor cold start and lots of misc questions.
- vacuum help.
- my new stroker: any dyno predictions?
- What size are the brake lines?
- Oil Pressure, engine shutdown?
- Condition of spark plugs
- Y pipe for Jet Hot LT's and SLP LM
- Timing chain options.... (cam install)
- Will This Y Pipe Work?
- What size collector bolts to use?
- Headers and O2 sensors
- Traction Control
- Can someone look at this scan data?
- Flames??
- tranny wont shift HELP force motor amps???
- No spark after cam install
- Catalytic converter question
- Corvette Calipers
- Giant Optima Yellow???
- Rattle from tranny crossmember...
- CMS valve springs(618s) with hot cam
- AIR pump replacement
- broke the rear end.. I think
- Can Bearing's Be Re-Used?
- Do LCA's really help?
- Will Hooker or Mufflex Y-pipe bolt up to stock catback?
- trap speed
- strange problem!!!!
- WOW! Hooker LTs rock
- BIG CAM guys in here
- Motor Mounts
- 1.6 rr
- Digital distributors?
- b4c alternator
- spark plug questions?
- How much RWHP will a 7.5 take??
- 97 Mid lengths on a 94?
- Left O2 spiking over 1000 at idle
- name that sensor
- LT4 or ported Iron heads for a 383
- i think my injectors dont like me much advice please
- Best way to bleed the brake system???
- So I tried doing my spark plugs.
- 3.42 or 3.73 gears in auto cars..
- sound clip results
- what times to expect from Stock 1996 vert??
- crank question
- replacing ignition cylinder?>
- How Much Rwhp Gain Am I Looking At
- How to make a 52mm TB?
- Can a Bad Header Leak cause a rought idle
- drive shaft vibration
- Car starts and dies
- 52mm tthrottle body how much hp on mild motor?
- asp cheapo pulleys versue harmonic balancer pulley
- ABS system
- can someone send me web site for tb bypass
- My heads/cam car only runs 106mph in 1/4, WHY??
- o2 sims and cutout
- Mcleod or Spec???
- How to bleed brakes?
- Power Window Replacement
- Leaking Gaz on top the engine
- o2 Sensors
- Write up on RR adjust
- MAF sensor/PCM -- fuel pressure?
- clear valve colors?
- Help! Lt4 hot cam kit
- Wheel sizes????i wanna go wide!!
- Decent priced tires?
- How much preload do you add?
- steering wheel on colum?
- fuel pump
- Loose rocker cause high rpm miss and idle prob?
- Help car will start then cut off help!!!!!!!!
- Can someone help me with this??
- Whacha think about my engine dress up?
- need another part number
- Which Y pipe Is better for LT headers
- water pump
- Car running hot, low coolant light and coolant smell inside car, what do I do now?
- fuel pump again.....
- SHOEBOX read this.....
- How to Clean Oxidized Aluminum???
- Spark Plug Wires?
- Horrible squeaking coming from my A/C compressor pulley
- Low Oil Light
- Help Quick.........
- black smoke at WOT takeoff?
- Z28 owners that have the SS hood (need help inside)
- what tranny line goes where?
- Flywheel removal? (A4)
- are these stock heads friendly?
- Guys running 175 plus Dry Shot, what are the Jet sizes?
- Installing Heads
- where to get batt. cables?
- dal and jason's numbers?
- Polygraphite Front Sway Bar Bushings
- jason cromer
- Random Technology Y-pipe
- ls1 brake swap
- Off Topic
- Are Pirelli P7000 Supersport tires good?
- Burned 02 wires
- cam walk???
- Draglite XP 15X6 Tires???
- Flame spitting backfire
- how did no maf on 93s work?
- Results from scanning car with SNAP ON scanner
- lightweight battery
- Lost bolt (cat to i-pipe clamp)
- Clutch Help Needed Please.
- intermitent spark at plugs
- Are LT's emissions legal
- Intake problem please help..
- Cheapest Place For Polyurethane Tranny Mount??
- ??? About Codes 51 and 32
- 93z dies please help !!
- O2 Sensor Replacement
- What are signs of a bad ICM?
- Lt4 Aftermarket Cam
- Tire Size for my '97 Camaro SS
- What oil PSI should I have
- Dyno results...opinions?
- computer question
- what should i set my fuel pressure at?
- widest slick/tire that can fit on salad shooter?
- best deal on SVO injectors?
- Holley Intake Manifold
- service engine soon light?
- 160 degrees, worth it?
- can i get a 98 digi gauge on my 96?
- My Jet hot long tubes exit right into the tranny crossmemember
- 230/236, stock heads DYNO #'s
- 200mph speedo
- Just thought you might want to see a video clip of my exhaust
- 95+ cam in a 94 engine without opti conversion?
- Air pumped fix, now wtf is this...
- How bad is too much fluid in an A4?
- Camaro Gauges
- Headlight motor?
- Problems after trans install ( 4L60-e )
- exchanging tranny fluid good or bad?
- Making SFC's?
- No first gear..what happened?
- Do the 96 z28's really have 10 more HP?
- SLP fan switch
- Rotating assbly. for 12 sec n/a 11 n2o 355?
- won't go into reverse
- Wont Start After Cam Install
- Need Your Help With Weird Problem
- 93's w/jet hot headers, did you have to take out oil pressure sending unit?
- Whats normal RPM???? Please help
- Spec Clutch Materials
- Anyone ever beef up stock LCAs?
- ignition switch?
- Help 14.7@95 check out my datamaster file
- REAR brake upgrades?
- Supercharging a 306
- Oil pressure problem
- Need Some Help/Opinions Please
- Which Mufflex to get??
- Sensor Readings???
- how to take out oil pres sensor?
- Something is wrong with my gas guage (not what you think)
- light weight flywheel?
- Installed new 17x9.5 wheels, roaring has occured. Whats wrong?
- exhaust
- Starting/idling problems
- IAC problem
- TDC Code
- Part number question for shoebox...kinda tricky
- oil pump drive ?? please help
- Y Pipe
- how much rwhp gain with LT4 hot cam?
- Bad Battery or bad Opti?
- How many miles are you getting out of your strokers?
- EGR and AIR Removal while manifolds are already off?
- 93 LT1-plugs/wires: 2 hrs 20 min
- ET Streets...tubes or no??
- Anybody have a datamaster file for '93 LT-1?
- reason my car was running like ****
- heads/cam swap help
- Need help thank ICM is bad!!!!!!!!!!!!!!!!!!!!!!!
- The thermostat autozone sold me doesn't look like the stock one....
- A4 to M6 swap??
- ANyone ever have problems with PCMforLess tuning?
- Steel Wheels & hub caps
- LT4 valve covers
- Code P1133 AGAIN, please help.
- O2 Sensors -- 2 for A/F and 2 for ??
- Possible to use 1.7 RRs w/ xe221/227 or xe224/230?
- polishing LT1 heads..
- What to look out for in 95 TA?
- my car is now being used for advertising
- Whole left side of car paralyzed?!
- need spoiler removal help
- 95 Z Obd1
- Need a Part # For a GM Composite Lifter Retainer Set.
- Backfires, and sluggish thro 1000-2000 rpms? after engine is warm
- Fuel pump not shutting off after prime w/ engine off
- Which wire for theft deterrent?
- 383?
- 30th Anniv. LT4's
- bolt sheered off in head
- I Sooo Puzzled! I need help Bad!
- Gaz Leak!
- Does SLP Make a Good Clutch
- power window out?
- mac headers
- tempraly fix for arcing wire
- how to properly jack motor? (and plz insert all hooker super comp install tips here)
- Steering wheel radio controls
- Solid users
- Solid users
- 383 or 396 LT1's users
- Quick oil cooler help please
- Throttle Cable...
- Solid Roller and High lift Hyd Cam Guys !!!
- Price for porting heads??? $400 good?
- Stripped transmission mount bolt hole.
- 58mm, A4, TPS questions
- Scanner
- ok im about to take this POS to a shop if I cant get the window adjusted
- Noisey valve train
- cat
- what cam to use?
- gmmg 2 1/2' tips?
- what does TPS exactly do?
- Why does the same ARP header bolt loosen up??
- #4 Welder wire good for battery relocation?
- ok so its not my oil pres sensor...
- pre-94 Engine, new cam - Optispark drive
- Since Taylor wires suck, what to use?
- Cam timing and opti phasing??
- Question about light over the spark plugs
- heads and cam help!!! please reply if you can help me
- Water pump bolt size?
- Can You Buy This?
- Computer Programing
- Need help with High RPM Miss
- Lt4???
- These valve covers worth getting?
- how to clean maf
