View Full Version : LT1 Based Engine Tech
- What #s should I spect from "Combination Motorspots" heads
- Magnaflow goes ....
- Part # for Grand Sport Throttle Body?
- Best ignition for Nitrous or boost
- what the hell keeps happening to MY posts!
- problems with my inline fuel pump
- Is there a write up on pulling the 4l60E??
- How much is this Firehawk worth?
- Hot Car = Drives like crap (loss of power)
- Lifters for hotcam.
- MSG Ignition
- 2 questions for those that lowered theri cars......
- I Hate This Street Twin Clutch!!!!
- White smoke?
- Questions? Clutch, Ignition, Fuel
- A4 Tranny
- good muffler for LT's
- intake manifold gaskets
- People with the CC305
- Is it necessary to have a new flywheel and pressure plate balanced before install?
- Code 1642????
- 160 thermostat
- Best way to do exhaust
- LT1 1/4 times
- Quick question
- Fixing the manifold leak, question before i start
- Traction Mods & Stock LT1
- 383 questions
- Ghetto True Duals
- Kenny Brown SFCs & ASM Headers?
- starting issue-mechanic gave odd answer
- 3000 stall lockup conv
- Please Help!!! Whats causing my misfire??
- What To Do Next?
- Will a 93 bbk 52mm tb fit a 94
- RAM AIR or COLD AIR?
- Need help picking out a nitrous kit
- Best Heads for Hotcam
- Where to find gm part numbers
- Can't find some RPO codes
- $500 more to spend, but what mod next?
- 383 stroker rear end
- lighter, defrost, electrical probs. can they be related?
- Where can I get a new or used lt1 block
- Heads are off. Have a cleaning ?
- Magnaflow catback is SWEET!!!!
- overheat, AGAIN!!
- Slight humming/noise while driving in gear...
- What are BLM's and IAC?
- AFR 220's on a n/a 396?
- hardtop
- ARP Bolt/stud for main caps?
- Reprogrammed Chip?
- Raced a ?
- Fans coming on as soon as engine starts?
- HELP?????!!!!!!longtube install question
- Electric WP quetsions
- Tell me about LT1 Edit
- Help me decide, please!
- Water leaking into back seat HELP!!!
- 93 Z28 Mac headers install question (EGR related)
- Freescan
- Car suddenly won't start
- Pulling the tires?
- Head Gasket change
- my ecm gone?
- 93z28 vs 94z28?
- What is this hose that the altenator wore through? Hi pressure air escaping
- Startup Problems? Opti? HELP!
- ZR-1 engine in a camaro
- Guys, I REALLY need some help. I am out of ideas
- Replaced timing cover seals and gasket, now have oil leak. Help!
- Rear end girdle, magic?
- Turnsignal/Brake Light Help
- Advantages of converting to OBDI
- y-pipe demintions LT's
- can u change the front main seal without pulling timing cover?
- tranny problem
- Looking for a zz4
- Convertible leaks when raining SOLUTIONS?
- bigger throttle body??????
- cars misses real bad in every gear at wide open throttle what could it be???
- 383 + mildly ported heads = which cam?
- 160 degree thermostat
- NGK TR4s?
- Who here runs.....
- Fans?
- think I can get into the 12s with just some 1.6 rollers?
- Anyone with Lloyd Elliot Flow Charts?
- strange noise...
- Difference between a Vette LT1 and a Fbody LT1
- Failed emissions
- Pulleys.
- Can Someone Explain to me how to check the High and Low Speed Fans on My 97 Z28?
- Switching to Shorties? cant take the slip-fit!!
- Anyone make their own SFC's?
- Service Engine light question...
- I need some GOOD brakes, where and how much?
- Advice/opinion needed about Opti & WP... and LT1 Edit
- Hooker Shorties
- my POS is driving me insaine!
- Failed smog, for a second time - NO too high
- Solid roller set up in a 383
- Fuel Pressure for 26 lbs Injectors?
- which 1.6 rr's and valve springs are you running w/ 305 cam?
- rims
- 1 or 2 cut outs with LTs?
- 555r's or 3.42s or MAC headers
- SES when radiator fans come on?
- Question for '93 F-cars using PCMFORLESS...
- Hypertech Questions.
- EGR questions
- Where can i get some nice dual/dual slant cut tips?
- HP Gains from Pulleys?
- cut-out
- EGR Hissing? I need help!!
- Just added 12 lbs to the rear is this good or bad?
- Engine blown, got a little question
- I am about to buy headers.. af ew questions
- 2 thumbs and toes up for Bryan at PCMforless
- what kind of gain going from 2.73s to 3.42s?
- Just bought 94 Z28
- Rough HP estimate from MAF reading?
- what do I need to change my differential fluid??
- Why is the passenger window so slow???
- 97+ interior swap complete with install guide
- Doing H/C...replace lifters??
- Ignition cut-off auto enabled itself, can't start car, HELP!
- Replacing Oil Sensor
- Wiring for A/F gauges
- LT1 Head question
- Gauge cluster blew a fuse plus other probs any ideas?
- stainless works hooker longtube y-pipes
- Walbro/Fuel Bucket question
- So what is a good heads/cam package?
- F-body Window Experts....please help!
- pics of my duals w/slp shorties
- How much much tranny noise is normal?
- i would like to make my own o2 extensions please help asap
- Guys with Mac Headers...c'mon in
- does anyone sell an aftermarket I-pipe for our cars?
- Its Alive!!!!
- 383 stroker... slow?
- You Won't believe this, check this out!!!!!!
- gears
- Electrical problem opti, icm, ecm?
- help with speedo re callibration
- O2 extenders
- blower/CR questions...
- smelling anitfreeze after slp header install??
- New mods and no improvement???!
- What do i need with my jet hot lt's??
- Whats a good spark plug and wire combination??
- Ebay Slotted rotor's
- Where to buy 58mm TB gasket?
- How to remove black TRIANGLE piece behind window on a convertible
- SLP SS headers and Jackets/Wrap ?
- Where to buy cheapest stock LT1 clutch?
- Looking for Lightweight Battery
- Clutch chatter driving me insane! help!!
- hole in muffler
- Please not the OPTI
- Power Steering Woes
- M6 guys running spray, please read!
- Can a Scanmaster clear codes on a 97?.
- Slow start sometimes
- 4-bolt tranny dust cover ???
- questions about my power steering situation
- $500 to spend - opinions please
- What resets after 5-10 seconds of off time?
- Quick question about wiring around VATS
- 150 psi of oil....
- Difference between long and short tube headers?
- High RPM stumble!
- A/C Shut Off Relay?
- Easiest way for #8 cylinder wire???
- Transmission Rebuild?
- EGR removal, block-off plates?
- Oil: synthetic or the real stuff
- Rob..Help with a fuel smell please
- Best performing emissions legal headers?
- Quickie on Shiftlight wire
- Flywheel step for Spec stage 3 clutch LT1
- SES light after Mac header install...
- SLP Header Install Q
- LT1 lifters stock or aftermarket ? new lifters w/used cam ?
- How much would this cost????
- People using Comp Cams 218/224
- How would I do?
- Jet Hot LT's with single or dual cat Hooker kit??
- Does anyone know about Grand Am fog lights?
- HELP!! Question on Header Install
- LS1 Brake upgrade question
- paging madwolf
- Guys with stalls come in please
- Gears queston...
- 93 z Help!!!!!!!!!!!!!!!!!!
- Car Not Running Right
- Is their anyway to make my car have true duels?
- Signal Light Don't Flash at all!!!
- So what is an Y pipe and an X pipe?
- Real simple LT1 question
- Looking for LT4 Knock Module and PP3 for 96
- Miles for break in??
- Help adjusting e-brake.
- Code 84 on an automatic
- No Heat
- trans is way too hot!!!
- 3 codes ?? lost
- slp shorties no cats wich muffler should i run??
- O2 Sensor Voltage Readings?
- cd rom car manual
- which stall converter? ~2800
- gmmg
- Everything needed for tuneup..including tools???
- where to buy a fairbanks shift kit??
- Where did you get your slave cylinder at?
- Gear Difference
- Different head gaskets: worth it?
- Degrading Gears
- Please help with my never ending problem
- Another 8.8 rear end ?
- Looking for Gear Install Shop In North Jersey
- cam or no cam???
- Material of stock connecting rods?
- o2 simms diy
- what else for 12's
- installed headers,and have a exhaust leak,or so it sounds???
- LT1 Corvette Harness questions...
- Ticking noise ONLY under acceleration...
- Rear End question
- ac delete
- Quick Exhaust ?
- Removing oil cooler; have a few questions?
- Post Hot Cam - doesn't run right
- NEED HELP. Radaitor problems AGAIN
- Starting Problems.
- Fuel Pump Install
- Just installed 218/224
- Stage 8 bolts
- alternator ?
- LT1 flex plate- neutral balanced?
- skocks and springs
- Removed A.I.R. system > What to plug manifold holes with?
- brake line question...
- hooker y-pipe fit jet hot lt's?
- Free mods for LT1?
- H2O Idiot.
- Fuel pressure woes...help!
- Spark Plug Wire Question??
