Vig 2800
Old Jul 21, 2003 | 02:27 PM
FacelessZ's Avatar
Vig 2800
Anyone running this converter? What is it actually stalling up at? Mine seems to be stalling up pretty low but I was told that the stall would increase after more bolt-ons, etc
Old Jul 21, 2003 | 04:15 PM
FacelessZ's Avatar
anyone?
Old Jul 21, 2003 | 05:10 PM
1st and goal's Avatar
I got a 2800 Vigilante multi disc t/c. I had it spec'd for my old combo which was dyno'd at 405 RWHP / 418 RWTQ and I only had it for three days before blowing up the motor anyway I only got two runs in on it before I roasted the motor and on the fatefull pass I power braked it to 2500 no problem and it flashed up a little and took off. After putting my new motor in I'd have to say it stalls around 3300-3500.
The pass I ran before blowing up the motor was the best I had run on pump gas (12.09 @ 112). I picked up 3 tenths with the Vig as the only mod while leaving soft and cutting a 1.800 sixty ft, on the pass it blew up on I cut a 1.66 sixty ft and after spinning the second, third and fourth main bearings at 3/4 track it still managed to run a 12.5@100.
A vigilante t/c is definatly worth the money and a quality mod
Marc
Old Jul 21, 2003 | 05:37 PM
FacelessZ's Avatar
I got ya...thats cool.
My Vig 2800 is stalling right around 2200-2400 rpm's...but I'm hoping for a slightly higher stall after a few more mods...
Old Jul 21, 2003 | 10:47 PM
Pro Built Automatics's Avatar
Only if you do modifications that "increase" low end torque?, then the stall will increase, (increased compression, more cubic inches, etc.).
Old Jul 21, 2003 | 10:50 PM
96redformula7's Avatar
I get my car back with the 3.73's pcmforless and 2800 vigilante like you. What tires are you running and how is your traction?
Old Jul 21, 2003 | 10:56 PM
FacelessZ's Avatar
I have some crappy Futura Z rated tires from Pep Boys on my stock salad shooters. Better tires are my next step...
How about you?
Old Jul 22, 2003 | 12:02 AM
WheelmanZ28's Avatar
Going to pickup my Vigi 2800 Tomorrow
I did a lot of research into this brand of Torque Converter before I decided to order it. Vigilantes are known as nearly bullet proof converters and I have had extremely few people have bad experiences with them. I'm looking forward to see how it performs when i get my PCM reprogrammed by Brian, as well as a new set up tires.
i plan on running BFGoodrich drag radials with that setup. I'm hoping to acheive a 60 foot time of 1.7 with the stall and DRs. Right now I'm cutting 2.0s on Dunlop 5000 Comps with a SFCs, LCAs, and RLBs.
Old Jul 22, 2003 | 12:18 AM
FacelessZ's Avatar
You'll be very happy with your Vig 2800...it's a great addition...
Keep me posted
Old Jul 22, 2003 | 12:21 AM
hey faceless do you have aim I would like to ask you about you car some things? I can email you if you like my aim and all that too.
IndyZman
Oct 22, 2015 02:17 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
cobrakilling101
14
Mar 17, 2015 10:42 AM
Red_94Formula
Jan 22, 2015 12:17 AM
CaptainHam
Jul 9, 2002 06:28 PM
