View Full Version : LT1 Based Engine Tech
- 17 x 11 wheels fit with modification?!?
- Can I???
- Need Help Asap! Wtf Do I Do?
- PCM 4 Less HP Gains??
- AutoXray Capture Results
- Porting Heads
- X-pipe H-pipe Crossover on True Duals Why???
- Fuel Pump Replacement
- crank hub bolt length??
- yet another holley TB issue
- cam selection
- spark plugs?
- my new problem (drivetrain)
- will this be the cause of my miss? pic inside
- How much lower of a time if...
- Cat back sound clips
- 160 thermo
- quick yes or no question
- well i blew the crap out of my opti
- IT STARTED!!! (Does the happy dance)
- SHOEBOX: I unhooked the right vacuum lines right?
- Header primary touching brake line
- clutch choice
- plug gap and type on 12:1 383 with MSD
- Anyone know this guy?
- How are OVC wires routed?
- Timing cover gasket question
- 383 Piston Selection?
- LT1 Alternator Relocation Bracket is DONE FINALLY
- Which gear should I buy? Please help!
- what brake fluid to use?
- will these 3rd Gen rims fit my car?
- Part # for accelerator cable??
- Does anyone still port throttle bodies??
- worth goin to Gm847 from XE236/242?
- So me and this LS1 kinda played around.
- Driveshaft Balancing
- Electric waterpump install tips
- IS it worth it
- coolant temps low with FAST
- Those with Comp "R" lifters, please help!
- HELP car won't run after cam install!
- How nasty is the HOT CAM with gas mileage?
- GM replaced the oil filter!!??
- Burning out....smoke was coming into the car
- o2 wiring.
- Gonna run the new cam tonight
- My AC switch is acting funny..Advice needed..
- Guys with 383 Strokers...What TB are u using? 52mm or 58mm?
- Torsen take out diff?
- Is it true you can use LT1 knuckles for the LS1 upgrade?
- brake line bending
- Has anyone switched rear ends?
- high Idle!!??
- boxed or tubular
- How do I plug the exhaust port on the rear of the intake?
- When I hit a bump, my interior light turns on...
- Bore TB or buy new
- are these injectors compatible with lt1?
- Which brand is better.
- Thanks for all the help!
- What other suspension mods?
- Weird stumbling...
- vacum line undr the TB what does it do? i broke it
- starters 93 to 97 camaro / 9* impala/roadm
- A4 tranny
- degreeing a cam
- 58mm tb problems
- 1 3/4 Slp
- Anyone running the Comp 915 beehive springs with a CC306 cam?
- Cam or no Cam?
- Tci Ssf3500???
- best fuel filter?
- traction?
- egr ??
- How much would you buy my car for?
- 16" SS rims?
- thumping noise from front end when turning
- 396 cam choice...cc306? GM847?
- What do ya'll think? No Start Problem
- Do I need
- Cragar SS wheels
- My car overheats or could it just be my gauge?
- Any body convert there LT1 TO A LT4
- Transmission Knocking!
- Electric Cutout Problems/Car won't start
- Unplugged MAF, car dies...
- top speed question
- Ok I got backfire :)
- tore it all apart
- calipers
- What MPH would you expect?
- Are the injectors tied into the power distribution some how?
- Crossmember ?
- how to adjust 4l60 tbody cables
- console swap
- 3200 vigilante or Long Tubes?
- Would E/T drags be too much for rear end?
- bottom end rod i think is ****** please help
- otvc wire kit
- Attention Gearheads!!!
- lil lt1 help
- Need part numebrs for guage clusters
- Refreshing front suspension (What bushings/parts do I need??)
- possible tps problem?
- SLP LM problem
- Running rich!!!
- Good garage in Toronto?
- Broken battery tray how hard to install new one..??
- Passenger side prothane motor mount problem?
- Price of your f-body
- Question about getting rid of my egr and air..
- Whch one do I need???
- Shifting Question
- Slp Header
- TB Bypass
- blocking off AIR and EGR on Jet Hot long tubes?
- Hypertech Programming 3
- Any Tips or Hints for Installing Racetronix Pump and Harness Kit??
- How do I reset the timing on the opti distributor
- Changing brake line
- can i run GM 847 with comp 987's and 1.5 rr
- Oil pressure drop during braking help please
- coolant swap?
- People w/ QA1 in the front...
- Northstar ignition module and coils, is this complete?
- What size Inj On my 383
- iat sensor problem!
- Running Temperature
- modifying stock fuel rails.
- reverse lights wont come on!!!
- wtf!? help
- Red Intake Manifold?
- Header wrap?
- Longtube Install Success
- New LCA worth it?
- G-Tech results on M6 conv--seem slow?
- whine from rear area ONLY under power.....???
- Hooker cat back exhaust tip question....
- Best spark plugs??
- Are stock 94 pushrods hardened?
- What Injector Size?
- Anyone wire mallory 685 w/o harness?
- Reviving a motor...
- Trying to figure out if I have TB bypassed or not
- Violent wheel hoop
- Manual Fan Switch?
- Weird???
- •••øøø Weird Noise Please Help øøø•••
- Rattle is driving me insane. Help.
- good or bad to remover the rev limiter?
- what I need for TB bypass???!!!!!!!!
- Security system bypass... Without vehicle BCM, just a ECM.
- Where is this part?
- hitting rev limiter
- Opty Spark Replacement Parts list?? anyone?
- Where do these opti spark rotor rubber o-rings go?
- code #P0443? Help!
- lt4 hotcam dyno
- Oil pan gasket part #, can I change it with motor still in car?
- which is more aerodynamic
- Blasted hub/belts
- Check engine and both fans...
- Metal alternator fan - not MBA
- Waterpump timing cover block
- LT1 auto flywheel bolts,..
- Where can i get a PCM?
- What a bunch of horse****!!!
- Speedo Re-cal after gears?
- Comp Hardened pushrods didnt cut it.
- GEARS, 3.42 or 3.73. ?
- 1993 Cooling System
- Quietest gears??
- LTCC problem..error light 3 blinks..anyone experienced..?
- What's the diameter for the intermediate pipe...
- anyone know anything about the INTERNAL TRANSISTOR on our PCM's?
- Is my optispark on its way out?
- Boost-a-pump install with Racetronix harness
- opti?
- Tranny Cooler
- Bearings gone after cam swap.
- Can I splice Flat type 02 sim's for use with my square type?
- Tail Lamp/ Brake Light Troubles.....
- Some great stories
- best header gaskets to buy and bolts
- Over the axle true duals with DS loop - Pics inside
- New Member with questions
- all bilsteins the same?
- Egr Simulator
- Which Torque converter and where can I get it?
- msd 8.5 wires and pro boot guard
- car only spins one wheel
- Dex cool or regular?
- Bad leak where pass. side header meets Y, what to use?
- Can I rebuild my own tranny???
- anyone daily driving with a th350?
- where can I get good SFC?
- XE 230/236 and parts
- 13.2 @108 w/a problem....INSIDE
- Hit 11's all motor
- 3" of clearance?
- What Should o2's read like?
- exposed flywheel
- Stall or Gears First?
- 1LE Lower A-arms
- 52mm tb or 58mm?
- Walbro 255lph fuel pump
- 1994 TA stock, what gears would it have??????
- Bitter Sweet
- minor tune-up
- Hooker Aerochamber Installed!
- How high can I stall my stock '95 Z28 with 3.23 gears?
- question
- SES light on stroker...suggestions?
- OBD2 scan programs
- First impressions 236/245 115lsa stock heads bottom end
- LT1 engine file for dyno2000
- Moroso Spiral Flow
- best mods for this setup
- Is this an LT1 timing chain? Looks a bit different
- fuel pump/spark knock
- Header Sealing
- Eagle Crank
- alternator bracket
- ignition switch
- How much for install
- Timing Chain question
- anyone use MR gasket ultra seal header gaskets
- New best on xe224/230
- Has anyone passed emmisions w/o egr
- What cam for my ported heads???
- N/A lt1 141.5 mph and new record ;)
- 93 headers on a 94?? will they fit??
- mac mid's vs hooker longtubes
- Want to geta Bullet mufflere can i just replace my flowmaster?
- How Much should I sell for?
- How do i remove the front wheel bearing?!
- extra bracket after cam swap!
- Any sensors that will shut the car off at a certain temp???
- Egr
- SLP 2OTL cone
- autozone scan
- Thermostat question
- anyone running a locker on a street car
- 383 Stroker times?
- Convertible M6 guys ?
- car wont turn over
- how do get the steering column cover off
- xe224/230 Gains from tune + exhaust?
- AS&M the only good Throttle Body? Seems no one likes Holley/BBK
