View Full Version : LT1 Based Engine Tech
- Bad alternator, or maybe a bad battery?
- Radiator Baffle ...
- BAD hi-speed vibe.
- suspension
- LT1 swap into 3rd gen. Should I use Mass air or speed density?
- Vibration above 60mph with energy tranny mount?
- How much trouble can i get in for having a off road pipe?
- How loud are roller rockers supposed to be?
- what kind of hp gain
- Gear Grinding
- rebuilding rear calipers
- AFR 190s or Ported LT1 heads for 383 / part-time N20 engine
- guys with ported heads& xe 230/236 what stall are you runnin
- How To Remove EVAP Purge Solenoid?
- I need a new (used) computer (A/C problems)
- Having problems installing crank gear
- Removing Cone of Silence
- Data Logging Software
- thread of m6 shifter?
- Oil leaking.....
- HELP! Car running like crap after Headers and Cam
- AC = less power
- Do most people take out, or add timing when tuning your car OBD1
- Flywheel???
- Rough Idle problem
- HOW TO REMOVE AC COMPRESSOR?!?! SHOEBOX! (again)
- window help
- AC compressor storage
- under dash connections
- I bought a moser 12 bolt used...
- internet how to?
- ABS in 12 bolt
- are hooker and jethot problems the same for tpis and as&m?
- Opti-sensor?
- How to install driver side motor mount....
- Why do i keep going through alternators?? Also question about a/c delco waranty
- Flywheel balancing question
- Wierd Sound
- Does the defroster on our cars kick on the A/C
- Has trouble starting when hot?
- 9 inch question
- 218/224
- Injectors, LT1 and LS1 the same?
- Random KR and other weird readings log inside
- Widest and smallest sidewall for Kumho's
- Dynatech long tubes
- Flowtech Warlock?
- which springs for cam (cc306)?
- Wingbut size on flowtech cutout
- why did this happen?!?!
- heads and intake manifold cleaner
- VSS leaking
- Hooker Y pipe ??
- 02 sensor ?'s
- biggest valves in stock LT1 heads?
- Does anyone have a dropped suspension and true duals?
- My first time and I suck!!
- Thinking about taking my CAT's off?
- LT4 hotcam and 1.7 rockers
- ram air hood?
- Brodix Lt1 Heads? Flow 308!
- Oil Cooler Removal!
- Clutch problem (any suggestions?)
- Attn: Shoebox, Coil test question
- LT1 probs: will start then die
- Comp Cam 305 Questions?
- Anyone ever have their Posi break (not the gears)
- Do your A4's shift like this?
- Do I have a bad lifter?
- Engine Blown! Whats next????
- Question for shoebox.
- What is the best RWHP from a 396?
- Corvette vs Camaro
- valve spring installed height??
- relocation brackets required for aftermarket LCAs? or just better to have?
- LT1/4 Starter Differances?
- What times SHOULD i be running
- which would you swap out first?
- What is this cord under my hood??
- I am so sick of my car!!!!
- weird ass problem w/ car! Anybody got any ideas??
- Initial Dyno Numbers with 224/230 XE
- Mass Air Flow Sensor 1995 Z28 Camaro
- Oil pressure woes
- 95 Z28 Camaro Solid Roller Cam
- Best Price on Hooker Exhaust
- new track times
- The BIGGER Oil Filter!
- LT4 Hot Cam Setup Vs. MD Emissions
- 95 Z28 Camaro Trunk
- shift kits
- xe cam ?
- Thoughts after installing Racetronix pump "the RIGHT way"
- lt4valve spring?
- Max RWHP on stock heads N/A.
- does anybody use octance boost??
- SLP and MAC headers?
- Spin bearing
- From LT1 to v6.
- Gear Change?
- Fuel pressure regulator location????
- Low oil senser
- How do O2 Sims work?
- Backfiring like a MOFO/Burning after LTs
- Forest Green Z28....$3300...what do you guys think? ( More info )
- Alternator
- What all can cause a high rpm miss??
- Part Number Help....
- Anyone with Edlebrock headers and..............
- Best cats and mufflers for true duals
- Change in weather = enhanced performance??
- shift points w/ xe 224/230 112
- Tranny Rx
- Which Plugs to run?
- I Think I have a bad FPR or leaky injectors
- Low Oil Light on...no oil leak
- Which Transmission and Gears do I have?
- Drag Radials?
- what's a good tuning program??
- Good installation prices?
- Found a 97 Z28 6 spd. w/74K for $7950
- Anyone know the K&N part #
- plug
- Rear caliper mounting bracket
- Anyone running 500+ h/p and 3.5" or smaller exhaust???
- Dropping the K-Member; Instructions
- Thought this was weird....
- SES light after header install!!
- y-pipe an longtubes
- random miss but no code please help(long)
- Converting Over, My Mustang Sucks!
- RPM Vs Speed....What is it
- hot cam install-loud ticking-help please
- Torque Arm bracket on tranny top bolt size?
- which header will work
- Fuel pump question
- O2 sensors??
- questions for the guru's
- LIst of all the free mods...
- Pro Magnum 1.6RR's
- Scanmaster or Autoxray...
- Cheapest Place To Get Goodyear Egale F1 G3
- Hey whats this crap about the Harmonic Balancer?
- installing aftermarket speakers
- Stick with the 3.73 or go to a 3.42
- IAT, Low RPMs Stumble, K&N relationship?
- 30# Injectors???????
- Anyone Run a HotCam with their 383? If so, any numbers/times?
- How much gain from switchin 3.23's out for 3.73's? M6 !Guru's only!
- Pinion Seal and Ring Gear Question
- best mod for under 500....
- 30th ann Z28, how much?
- cat or O2 sensor?
- is it worth changing ONLY the cam?
- ? about rebuild....cam/timing chain/opti,H20 pump?'s
- Problems with AFR heads and FLP Headers
- Engine wise whats the best way to go?
- 30lb injector p/n
- Brakes/rotor need replacing...advice?
- How many say no to radiator stop leak?
- were to buy nitto's on-line
- Need Help...asap
- T-56
- Torque converter cover.
- How are the 02 sensors supposed to ready??
- Cat Rattling....
- Need Your input on this.
- any one have bbk headers?
- 75% water and 25% antifreeze safe for anti-corrosion and WV winters?
- bad o2 sensors can cause my car to run rich??
- Hawker Genesis G16EP lightweight battery good for my application?
- Scary Valvetrain Noise
- blown head gasket, NO PROBLEM.....but, is this for real??
- lt1dave.com
- short block build ?'s
- weird bounce
- Two raw eggs in the radiator and call me in the morning.....?
- looking for somone who does powder coating
- does my SPEC ressure plate need to go on certain way for balance
- 315/30 18's?
- Guys who rev their car and get the pop sound at the end read inside..
- Tomorrow!!!!!!!!!!
- Cruise control, ABS, shifter and steering linkages, wiring harness ... PROS/SHOEBOX!!
- idle vacuum for cammed cars
- drag shock question. please help!
- My Dyno numbers?
- msd blaster coil
- Anyone with SLP headers?
- Radiator Hose?
- header "tick - tick" leak
- LS1 brake INSTALL Q's
- B&M Trick shift fluid good or bad????
- Hot Cam guys...What stall converter????
- vaccuum leak Q/A
- how long do i leave seafoam in oil???
- what muffler should i go with
- I can't believe my 02 sensor is bad??
- heads
- Transmission
- 17'x11' Zr1 rims
- getting rid of emissions crap
- Suspension
- engine vacuum, and etc.
- lt4 intake or port??
- Quicktime Electric Cutout
- 93 lt1 optispark from Autozone, does this look right?
- Starter Slowly Dying?
- Stange hissing noise coming from the back of car
- LT1 alternator questions...
- Where to get replacement bulbs for AutoMeter Gauges??
- Big valves in LT1 heads?
- 93 LT1 had a bad miss, help!!!
- oil leak on intake
- Gear change
- replacing clutch
- Quick Help!!! How to turn the Flywheel when the engines Seized(T/C Removal)
- Anyone ever replaced ignition lock?
- clutch and pressure plate combos
- does not start
- Header Question
- Ok, I'm confused now (torque converter)
- Torque Converter Stall????????????????
- Magnaflow vs loudmouth
- Hmmmmm?
- What is the cheapest way to reprogram your speedo???
- Emission testing
- Which engine rebuild kit to get?
- Replacement for oil pump drive gear retainer plate?
- Idleing at a very hot temperature
- Solid motor mounts anyone?
- Best CC306 Stock Short block N/A and Spray 1/4 Times inside.
- Intro and Question
- Is it worth it to get an opti rebuild kit?
- having problems with this rebuild
- Anyone thinking of rebuilding their motor, check this out
- Cooling-Fan is running all the time
- ABS light is on constantly
- gas guage
- Car has trouble starting?
- Map Sensor
- Drivers Side Wiper Blade!
- Worrying about Emissions
- Best performance gains for around $1000?
- 4L60E Speedometer reluctor wheel part #
- 4.10's... too much for a stock LT1
- Cooling fans only go on with A/C??
- Is anyone else's gas Gauge off ?
- Car running rich, why?
- A few problems with car. Plz help.
- Roller rockers and springs?
