View Full Version : LT1 Based Engine Tech
- 383 ?'s
- passenger side o2??
- What Head Gaskets and Head Bolts are You Using??
- subframe connectors/ torque arm???
- 383 stroker questions
- filing down 98-up rims to fit 95 Z28
- Help Me Out With Some Problems...Heads/Cam Car
- upgrading fuel injectors.........bosch or delphi/lucas ?
- need pics of shifter
- SES LIGHT GIVES 7 CODES!!! HELP! Please Read!
- Need Help A S A P !!!!!!!!!!!!!!!!!!
- Rear brake pad that stops good, no dust, no wheel hop
- pageing lt1_car
- Stock Lifters for LT4 Hotcam????
- Anyone ever hear of an aluminum LT1 block?
- is there any good spring kits taht retain stock hight?
- Headers
- Anyone wanna trade sportlines for my pro-kit springs?
- underdrive pulleys and ram air box problem
- emissions
- "EGR recirculation failure" after LT install (OBD2:P0400)
- anyone dyno with a cm 227/233 cam yet?
- winter project question
- Anyone replace brake lines w/custom ones?
- How much HP can an LT1/LT4 block handle?
- cc 306, comp 224/230, or lt4 hotcam
- Rough Idle smoothes out with cooler outside temperature?
- I need the size of the bolts that hold the power steering pump in place
- Peak Global Extended Life Coolant?
- Time for new brakes....
- Best intake for an LT1
- down shifting ion & others
- Spun Bearing maybe?
- To manual shift or not to manual shift????
- Wires touching.....
- Storage problem
- Pressure needle bounces.....
- Torque arm mount bolts.. all of them..
- Can you remove and replace the glass in side mirrors?
- Evap system experts inside please!!
- just got back from the track, some times inside
- C5 Rims on my 97 LT1 Z28, questions???
- help me Decide PLEASEE!
- Will headers really help that much?
- Is thos on right?
- Getting exhaust?
- of these 2 cams, what would you pick
- Does anyone have a cc306 or a LT4 HC???
- Setting the Valves....Big Issue
- need a little help lt1 guys needed
- Whats better and whats quieter- Resonator or Cone?
- Length of stock "vented" Cam Dowel??
- 60 ft times
- Going from LT's to Mid/Shorties
- Bad Vibration
- cc 306 without tuning
- sorry its another lt header question
- Should I get mid's or LT's? Please Help!!!
- SLP Loudmouth for LT1
- i have a 94 will a 95 opti just go on or what do i need
- car wont start....
- Anyone ever use glasspacks?
- Air Bag light is on all the time.
- Best Exhaust to Get.
- Installing Scanmaster on 97 SS w/ OBDI?!?!?
- Opti-Spark Question??
- Welding stock rear end axles to pumpkin?
- PLEASE HELP ME!!! Car STILL runs like crap and nobody knows why!
- passing smog without a cat?
- what's the difference?
- where to buy an opti
- SLP Loudmouth VS Magnaflow
- What do I do now?
- o2 location??
- shoebox, and those with experience
- CHeapest Place to buy SLP Loudmouth
- braking problem
- Really Easy Question, Fast Answer Needed!!!
- Clicking noise from cat
- If you could only pick one.......
- installing catback
- Pre-ignition
- Getting Rid of CATS
- Oil Filler cap is a funny color...
- O2 sensor failure analysis
- Gas mileage with Hot Cam?
- jet hots here, drivers side has only 3 bolt ups...
- 93z28 Frame Questions
- Coolant Light On
- ECM/PCM question??
- O2 sensors and MPT
- Eagle .010 under on the mains crank
- RE POSTING this AGAIN. 224/236 XE cam too big FOR MY MOTOR
- Jason Cromer
- Paging shoebox
- How far?!?!?
- venting an unvented opti
- obvious ?, just want reassurance
- Jet hot longtube ?'s
- Is this normal for a TC????
- OBDI to OBD II Conversion for higher stall
- Electric WP question on hook up
- HELP! Major Overheating Problem
- valve springs and pushrods question
- 230/236 cam question
- No heat please help
- Injectors not firing....
- Look at this
- TB bypass now wont start
- Replacing Hotchkis panhard rod bushing?
- Keep popping out pushrods
- Jet Hot headers and K member tolerances
- Nitrous UH-OH
- Any tricks to bleeding/changing brake fluid?
- Got the squeakies? I am sharing my fix info.
- Stage 8 bolt washer and clip?
- Hot cam kit or LTs and 1.6rrs?????
- Back Fire
- aftermarket Y -VS- fabricated Y
- Stainless Works Y-Pipes
- Id like to hear some sounds of diffrent catbacks, anyone got any?
- 1994 lt1 vats question
- Dual Exhaust System
- Where can i get the hotcam kit?
- Howling gears when decelerating...
- Cam that doesnt lose bottom end or give me cam surge...
- Strange Electrical Problem after 13 month storage!
- rear main replacement
- need opinion on cheap ebay suspention parts
- thermostat vs. fan settings?!?!
- Should I reset my valve lash?
- Will I Benifit at All?
- 93's have different front brakes than 94-97?
- You woulnt believe this!
- Bad exhaust leak! HELP!
- Exhaust leak -- Affects on O2
- Possible front end problem
- Constant vibration after wheel spinning?
- Dyno Tune vs. Mail Order Tune
- Are there any free tuning software, or anywhere to download one for free :)
- TB. Bypass
- Which headers should I go with
- started disassembling today....
- Tire arm, or steering arm?
- ed timing chain
- Inlet Air Temp. Sensor question
- DIfferential BEarings!!!!
- How much Lift can LT4hotcam springs handle??
- exhaust suggestions
- High beams wont turn on
- success story finally (hard start)
- Emissions "Frendly" cam Question
- reliability issues
- oil leaks after cam install
- Headlight Bulb Size
- which of these to cams should i go with
- Distributor
- lt1 2 LT5
- Exactly What Do I Need...
- Poppy backfire??
- Optispark delete???
- looking for kmember install pics
- ABS INOP light on...where to start?
- how much is a torque converter install cost?
- Whats wrong?????
- Wheel Spacing
- will Lug Pattern 5 x 114 fit a 93 z28???
- headers hooker or jet hot
- exhaust ideas / suggestions???
- Problem with anti theft
- how to clean head/block mating surface before putting on headgasket and heads?
- How much does a cam, rockers, and springs cost to install?
- How to install B&M shift improver??
- Seatbelt dash light won't shut off.
- Question about LT4 springs against CC springs...
- Will this get me 12.8??
- LT1 Corvette Block
- help please, overheating!
- New lifters w/ a xe 230/236 112??
- Anyone know where I can find a replacement remote for my car?
- opti is on...but still broke
- Help me pick
- 1.77rr Gp
- SLP CAI Filters?
- Dual Cat LT Y-pipe?
- CC 612 springs ?
- PHR's breaking?
- Help on A/F gauge.
- Please Help: Pooping/Loss of Power?
- TC need help ???
- $500
- speedometer swap
- check gauges light volt drop wtf ????help plz
- stroker kits
- Tires are going bald...any recommendations for a new set?
- any reason to replace water pump coupling?
- How long for RR install
- Questions about LT4 Hot Cam Kit install...
- Long Term Storage, what should I do?
- muffler + I-pipe vs. catback
- Videos of my 260/260 solid roller with xpipe and dynomax bullets
- Stock HP on LT1`s 93-97
- Dead car...
- preferred way to install cam
- Starting issues, hesitation problems, need help
- Low RPM stumble?
- Tire sizes(skinnies/15x8's)
- Car goin in shop this week..what should i expect....
- Rear End
- Stock HP peaks at wheels
- 1.6 rr's and stock valve covers....
- 1.7 rrs. where to buy??
- How Hard And Long Will And Engine Swap Take!!
- LS1 Stall convertor in LT1 car????
- Curb vs Gross
- caution* lunati cranks bad
- Quick Fuel gage/ Pump question - tie wraps?
- Will these injectors fit?
- LT4 Knock Module ??
- Difference in strut tower brace between v6 and Lt1
- will this crank work in the lt1
- heads are done...but engine feels "tight"
- Driverside door lock problem
- opti question
- Quick Conveter Question
- Hp & Tq
- LT1 stock horsepower question
- How good are Sealed Power Lifters??
- Custom exhaust question.
- Howz this sound for mods..... Any suggestions?
- Drag Bags
- Torque Arm Suggestions
- TPiS Longtubes
- 383 help
- New ATI supercharger part numbers for the LT1
- Engine Problem
- electric water pump life?
- Pulling The Engine???
- Heads and Header install question.
- Problems problems problems....
- keeping the engine cool
- Plug Wire Heat Protectors
- all the possible boltons u can think of?
- Some TPS Trouble
- LT 1 Scanmaster Install
- acceptable draw on the battery?
- 3.90 gears now available for the Strange 12 bolt
- rockers(will they work?)
- faulty maf.
- Are all radiators the same from 93-97?
