View Full Version : LT1 Based Engine Tech
- HotCam - Wowee
- Fuel pumps?
- Grinding noise from shifter after new clutch install!
- 383 new engine breakin?
- electrical problems, car will not start...
- New best times
- Buying a new"Pawl"
- Dyno results for ProjectTranzAm!
- HELP - electrical problem
- PCM Location?
- What does everybody think about the SLP CAI?
- anyone have any info or experience with the crane cam 234\242?
- Exhaust runs hotter, engine runs cooler after O2 sensor replacement
- LS1 exhaust on LT1 Camaro?
- Right turn signal/brake light.
- fuel in ports and oil
- BBK or AS&M TB?
- Ebay auction ss airbox?
- the tranny is slipping when it does what??
- Intake manifold and water pump bolt sizes?
- Signs of a failing coil or ignition ?
- PCM fuse keeps blowing
- SS Hood Vs CAIs?
- Symptoms of a bad pressure plate??
- Washing your camaro...
- got error codes 16 and 48
- Couple of interesting questions.....
- Swapping out 95 Camao dash to 97+ style??
- 94 shorty headers on a 97?any probs?
- Vented vs. Non-Vented Opti Internals?
- Which Ones?
- Taking aprat the center console for A4's????
- Dyno of the Firehawk, A/F questions
- Combination Motorsports recommended this...
- Worth paying for GM additive with Torsen diff?
- Primaries 6 and 8 glowing red please help, been working on it for 3 days
- Dtc 64
- Can a stock MAF go bad gradually??? Z06 MAF???
- Ebay LT1 intake
- ?? about fuel needs for 370RWHP
- SLP muffler
- Any way to disable the Anti Theft device on a 1995 Z28?
- O2 sensors
- Who has had their intake manifold coated???
- Heater doesn't get hot?
- Security Light on car wont start
- SPEC stage III issues! are these things CRAP?
- What else should i buy for my clutch install?
- Rotor Replacement Suggestion
- Help - Service Engine Soon Light
- water is coming out of my overflow lid!!!!!
- Best way to clean fuel injectors?
- Big Problem with my new SLP clutch
- Paging Madwolf
- Cold Air Intake Temp.
- After H/C install "no" heat
- Exhaust opinion SLP LM with or without cats
- Cam install where do i shift
- building 383 - whats the best for the $?
- Locktite the same as thread sealant?
- heads and cam? (for a 383 kit)
- need firing order and help ASAP
- are these flow #'s any good?
- hydralic to solid roller conversion, whats it take
- Where is the factory keyless entry brain at????????
- Can hydra rev be installed wrong?
- Ram air Firbird pn needed.
- Need OVC pics and install
- What idle speed and RPM shut-off for 230/236?
- PCM Forless and AKM cables........
- o2 sensors...
- power loss with 114 LSA over 112
- Will STEEL FORGED crank out of truck engine fit an LT1?
- where is the oil pres sending unit
- NEED HELP, Problem w/ speed density and cam
- adv. induction/cms heads?!?!?
- Car over heating HELP!!!!!
- what spark plug gap?
- shifting my car
- Aftermarket T56 bellhousing?
- how to access passenger plugs/wires?
- new forum right here in HOUSTON
- what bolts to use with lca's??
- What are good shift points for my car?
- 1 power programmer 2 cars...possible?
- Performance Chips... garbage?
- Just ordered 1.6 RRs from cmotorsports!
- has anybody ever used ring gear spacers
- Chugging driving me nuts
- lt4 intake, lt4 heads, cc306 cam good stroker setup?
- What type of Cam??
- Stroker Mileage
- 383 stroker lt1 (fuel injector question)
- what rpm are you lauching at with DR's
- 1.6rr on intake and 1.5rr on exhaust....why
- Anything wrong with the AC Delco 454 oil filter?
- Time for heads, what should I look for?
- Royal Purple Diff oil already has the limited slip additive?
- LT1 Diagnostic experts..... Need help ASAP
- LT4 Hot Cam, 1.6 rr, pcmforless, still running stock time?!?!?!
- HELP!! Problems...
- Anyone install a speedometer guage?
- Emissions Sticker
- first time to the drag strip in the Z28 -- results -- what do you think?
- Brake problem
- hooker muffler
- header installation costs??
- crossthreaded head bolt???
- Increased trap speed with a 4.11 gear?
- intake elbow screwed up
- anyone whose ever made taylor wires...please come in
- Keyless Entry!
- daytime driving lights
- IS THIS SAFE, clutch stuff:
- What am I doing wrong?????
- My engines getting stroked
- GM shop manual
- go to 3rd gen tech section says l98's beat lt1's
- Stupid ?, what way to discern which bank which head?
- Which cam for stock LT1
- How do I remove the exhaust headers?
- whining sound in rear end
- running lean and TPS
- what mods do i need to be in the mid 13's?
- Loose Header Bolts???
- running lean or rich
- Why cant i find a cam that sounds and lopes like a stock car?
- FLP Long Tubes and 2OTL exhaust
- Best Air-Box Assembly?
- Anything I should do berfore putting on FLP's LT?
- Have a hesitation, logs inside
- Tranny Problems? Please help...
- Airbox that goes with oem ss hood?
- speedo gears
- where can i get a x pipe that will fit a 94 lt1?
- Replacing cooling line hoses??
- Is this Motor worth it?
- What % od horsepower do i lose through my drivetrain?
- window
- Tranny "pops" out in reverse?
- Why does installing a TC help in getting rid of cam surges?
- Advanced OBDII Question
- How many of you are using 10w30 motor oil?
- How to get off plug #6?
- valve spring install
- best mid-lenght/long tube headers
- Torque converter flex plate wobble?
- Broke bolt off in headers
- Question about mid-lengths VS. Sorties
- Anyone have any problems with SLP clutch?
- Where to get new gasket for cutout?
- Best way to do a data log run?
- Spedometer cable O-ring leak
- Is rebuilding the cheapest thing to do?
- rebuild question
- strange noise
- Question about the TPS
- Sea Foam, use it or not
- Looking at getting a 93'
- intake system & injector cleaning supplies. What's needed??
- STB for '96-'97SS/v6's fit a Z28?
- Can bose speakers be replaced by Monsoon speakers from LS1
- Ignition Coil Suggestion
- 8.8" rear end?
- Cruise/wiper/turn signal switch/lever change
- fuel filter
- Questions about 3.73 rear end
- stage 2 head/cam package from cms
- help 14.2's
- Suspension help?
- Fuel Pressure Testing..
- melted opti
- 306 on a 110, i have a question.
- will 986 springs work on a 306.
- Help with damaged Hypertech Programmer
- what are symptoms of bad opti?
- best adj. timing chain?
- finding top dead center?
- What rear end gears do I have
- On a A4 - M6 swap do I have to have flywheel balanced?
- Another cam question
- Whats next?
- P0430, HO2S #2 position ?
- Car has died 3 times
- radiator fans
- How hard are 1.6 RR's on the engine?
- Supercharged LT1 Rebuild
- LS1 or 1LE driveshaft???
- mac headers for LT1 vs LS1 ... for true duals
- Best hooking regular radial tires?(not drag radials)
- How do you know when you're not running on all 8 cylinders???
- need answers for my engine swap
- brake probs with pics
- Which MOD next?
- OVC wires
- possible to make your own exhaust gaskets?
- Need help with an upper engine noise...
- What is the Torque spec for header bolts?
- Not a kill story but....
- Granatelli maf??
- any ET or MPH to be gained
- pulls like no joke...sometimes
- Stupid Mistake, Big Consiquence
- Shorties V. Long Tubes
- fuel control
- What can cause miss or stumble at idle?
- Tired of seeing security light
- Intake Elbow?? where can i get one??
- Will a Y-pipe off of a single cat car fit a dual cat car with shorites?
- best price on steet twin
- Removing Front Sway Bar
- Stock Valve size???
- Thinking about getting a Cam need some advice
- help car quit yesterday
- any one have a high revvin lt1?
- Cool!
- Oil guage Questions
- Shoebox?? IAC question
- Polished Zr1's maintance
- Canton Oil Pan?
- who used NGK spark plugs
- Drive train noise
- Is 7 quart oil pan needed for 383?
- The ol' what do you think i'm gonna run thread! :D
- $1,100 for a McLeod Installed.... Is it worth it?
- ram air lower airbox options?
- Synthetic Oil?
- 4L60E Stall
- Thunder Racing kicks azz!!!!
- Stupid Trans Cooler question
- True Duals Quiet??...possible?
- Oxygen Sensor Removal!
- Throttle & Cruise Cable Removal
- high idle?
- Spare Tire & Jack
- Sound clips w/videos
- I need help! LT1 issues..... (long)
- what the hell,,,jet hott install????
- coil problem?
- Friend Wrecked his z28
- can anyone run a carfax for me...help w/in
- 396
- smaller cam wih my heads
- edelbrock headers
- Future Fuel Suggestions
- question about 847 cam
- Differences?
- burnt hose of some sort?
- need help on spark plugs
