Window Help!!! Please Help
Old Jul 19, 2003 | 02:54 PM
stang_killa94's Avatar
Whenever I lower and then higher my window it gets stuck half way up and i have to push the window to the rear of the car and then the window will go all the way up and I also have to hold the window on the way up or else the window will lean into the car and wont close properly. I took off the door trim panel but i cant see into the window area. Has this happened to anyone else? How can i fix this?
Old Jul 19, 2003 | 02:57 PM
You might have some rivets loose or rollers broken. There is some info on my Tech Page on how to make adjustments, but if you have broken parts, you will have to repair or replace.
OutlawPerforman
Oct 30, 2017 05:40 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
