View Full Version : LT1 Based Engine Tech
- How big of stall?
- Lts and GMMG on a dd??
- Delteq ignition setup, Round 1
- For those of you with TCS
- input on the random tech catback system?
- Fuel pump question
- AF what should it be???
- HELP!!!!!!!!!! car won't start
- Jet Hot long tube install nightmare
- Got problems with oil pressure
- changing plugs ???s
- 1.6 roller rocker diff. in brands
- Dyno #'s with 150 shot
- mtr mounts
- F.A.S.T. xfi help
- Bob Bailey still doing the LTCCs?
- opti cap and rotor install??
- any drone with TSP rumbler?
- true dual
- Electrical Problems !?!
- cam removal
- Recommended headers for a 93 Lt1?
- Help. High Rpm Miss. Tried Everything.
- Oil Pressure problem
- Getting a LT1 to run 12's and 13's?
- GMPP Guideplates, need part#
- The Right Shorties
- Injector install how-to?
- So i'm starting to rethink my duals.
- help! oil pan on 383
- Keeping comp rockers from coming loose?
- LE2 Heads/Cam Track times inside... and I broke..
- Car acting funny
- polylocs and 0 lash?
- what else can i do???
- Mass Air Flow Sensor Question
- My Track Results...
- Corvette Fuel rails
- 54mm throttle body
- I need help with a miss, I've basically tried everything
- changing spark plugs and header gaskets
- correct Spark plug gap?
- header paint
- Need help figuring out some codes
- PIc's of edelbrock's LT1/4 Intake
- Hows this rotor look?
- Rod knocking?
- Fuel System Questions
- Autozone doesn't have IAC and dealer wants $120
- cam button
- cooling problem
- 383ci= running like crap and backfireing...
- Capping off vented opti
- no power to starter or fuel pump
- lt1 runs way rich
- cam question
- idle stalling
- Am i over-analyzing this.. Timing chain installed wrong??
- Plugs & wires
- Oil pan gasket replacement
- Adjusting valves - Comp 1.6 RRs - What did i do wrong ?
- Valves covers install : proform polished aluminium
- Hot Cam and CC305 : what is needed ?
- Injector questions
- Which MAC's should I get for my car?
- Help please
- Speed Density LT1 Message Board
- Stock LT1 TB Diameter?
- need to get old gas out,fuel pump prime?
- SLP Shorty Install Gaskets and Hardware
- Headers back install
- vented opti conversion questions.....
- BAd gas smell after FULL tank?
- What are you header/cai/exhaust guys running in the 1/4?
- Gas still in oil?
- pushrod question
- Engine stumble
- AS&M 58MM on a 93Z??
- Started my 383 Up
- Passenger head removal?
- LE3 head cam on a CARBED motor
- Quiet Exhaust option?
- What size cam
- Question for the CC503 guys
- Best Cam for STOCK heads, 1.6RR, under 6400RPM's
- Cant identify these injectors
- Blowing Header Gaskets
- Single Plane Intake Idea
- Springs?
- New engine overheating
- LE2 Heads/Cam are in! Videos inside!
- Idling issues on cold start up, any way to remedy?
- Converting a 94-97 Throttle Body to 93
- How do I know if my Opti-spark is vented?
- AI and LE trickflows...
- Taking out rad, any tips?
- hp rating on fuel rail and lines ?
- How Many Motor Mounts??
- problem after h/c install
- Throttle got stuck open
- Header Bolts?
- Experienced Opti Users (GM, aftermarket, and MSD) info/problems
- Give me some ideas.
- How to tear down a LT1 throttle body
- Cold Air Intake
- Dyno results
- 1993 header install
- Found out my solution to my oil pressure drop!
- My DYNO results-basic bolt on LT1
- Need help ASAP about fuel pressure
- how to get a long dowel pin cam to fit in short pin engine.
- Afr Lt1 Heads Vs. Trickflow's
- cheapest place for optispark replacement
- Identify the injector?
- fms cam
- 160* tstat... What temp should my fans kick on?
- Opinions and questions on exhaust setup
- what exactly would i need to get or do?
- ZZ4 block
- Adjusting my rr's
- Anyone know how to check engine codes without scanner?
- wires melting again...???...
- New fasteners when doing a cam, rod bolts etc.
- weird exhaust problem
- Code 36, heat related?
- Need help picking cam for new setup>>
- trying to find the right pistons and such.
- How to check for split BLM's?
- Valve? Lifter? Rod? Help ME!
- Will 00 LS1 heads bolt onto my 96 LT1?
- A lot of new parts and car isn't running right anymore
- 100,000 mile mark
- Which brand gasket and seals?
- fisrt time out with the FMS cam.
- Speedometer problem?
- Bad rings?
- converter or not?
- sound clip of my exhaust
- cloyes double roller on 94
- redtop injectors bigger than 30# ????
- My 94 Z28 wont fire up.
- long tubes installed air queastion
- drag or not to drag
- 383 runs like total crap
- black box with vaccum line?
- Hotcam Kit + Bolt Ons - Dyno Results
- cc306 with 130k?
- high miles cam swap question
- Rumors true edelbrock lt4 intake
- I got a water pump problem
- PacesetterLT's and ORY & Borla catback
- Need your 2 cents worth
- Tip of oil pressure sensor broke!
- Ok sucking oil in between heads and intake
- cat or no cat with headers
- 02 sensors
- o2 Sensor Question??
- question about air pump wires.. whos hot?
- High rpm clatter
- Different Alternator
- problems after 94/95 LT1 swap ??? help
- Pics of my vacuum canister setup.
- head gasket or not ?
- Borla Lt1 exaust
- Exhaust flaming at high RPM
- Best Head Gaskets?
- WIll this kit work for me
- Change Cam bearings??
- Knock sensor?
- most hp gain
- Miss after long periods of driving, then exhaust starts to pop
- Coolant problem?
- Electric cutout problem
- Help with new head choice
- Can this be done?
- Help with a miss
- replacing the lifters
- On a 96, which wires go to the coolant temp sensor?
- lt1 in an rx7?
- Replacing Oil pan seal, hard?
- Vibrates at the end of 1/4
- How much power is this Y-pipe costing me?
- FLP headers and Breslins header bolts
- is there a LT4 Knock sensor?
- 95 z28 fuel filter location?
- Oil pressure drops at WOT
- P1371
- I'm amazed at my gas mileage...
- Vacum Canister Question.
- LE3 guys
- Having some coolant leakage/power steering issues
- HELP! Very high idle after headers & rockers installation
- MALF 43 - ESC Fail, knock sensor checks out
- Knife Edging the Crank ????
- any pics of PaceSetter LT and Y-pipes ?
- Requesting Dyno Feedback -- Cutout Results
- stumble and dies 3000-3500 erratic
- painless wiring question
- XE 224/230 110LSA video
- how big of stall with cc306?
- how far apart will my headers be
- Need help pulling this crank pulley (pics)
- Mac mid headers
- ported heads with hotcam, bigger injectors?
- Header leak?
- Headers
- 93 z28 Corsa exhaust
- Hand porting the intake?
- New best speed.........but why?
- Setting 0* lash and checking for a intake leak?
- Lifter Retainer Hardware
- CC503 VS CC305 VS Hot Cam, which one, and why?
- will a comp cam from 96lt1 go right in my 93lt1
- Some Port Porn from Airflowdevelopment
- 30ibs svo injectors
- new here need help badly please
- Steam tube leaking coolant at head
- what springs for 224/236 114 lsa??
- Sick Lt1
- Not Starting, White Smoke?
- AFR heads, im confused
- Will these mods get me in the 13's?
- can arcing plug wires kill the ICM?
- TB for 383/LE trickflows/bauer cam
- spark plug type and gap for LE2/XE233/WS6
- Valvetrain Geometry
- Super budget exhaust.
- does wiring on injectors matter?
- Which Throttle Body?
- Spark plug tips are clean to the meatal?
- Hooker LT Question
- Which of these cams would you guys pick? Poll
- Regrinding a cam from a stock lt1 core?
- Forged 383 Le2 Setup
- Car down NEED HELP PLZ!!!!
- LT1 Header Selection (Mids or LT's?)
- Optispark Questions
- Can a 94Z opti be installed "wrong"?
- Final Dyno numbers LE 355
- OVC Wires
- Damn these Mr. Gasket 5716's....
- Lifter?????
- part number
- What cams would have me shifting at <6200RPMs?
- Fuel Injector Problem...
- 95 lt1 with 178,000 miles what to do next.
- Redline for a CC503
- checking voltage at the spark plugs
- afr 215rr
