View Full Version : LT1 Based Engine Tech
- LT1 in an '80 Camaro
- Which Long Tubes give the best ground clearance ... This IS my last ? Sorry ...
- Crane Cams PowerMax2050?
- what usually breaks on an opti?
- Lt Header Poll
- headers...just how hot do they get???
- Anyone with dyno results from LT's ?
- K&n Cai
- Any good starters out there?
- throwing code 32, egr code
- Whats a good exhaust with the TPIS LT Headers and no cats?
- intake manifold
- injectors and plug wire noise
- Need help with Accel injectors
- Engine Sensor problem.
- Need Help
- MAP wiring harness problems! Help
- More performance ... anyone dealt with them and their Y pipe ?
- Sound Clip of Stock vs Hooker Catback with MAC Midlength Headers
- What do you all think about this CAI on ebay?
- Need pic of 93 IAC...
- will a 3rd gen rear bolt into my car??
- oil leaking from bottom of slave cylinder
- Stock LT1 specs?
- Will reseting my Pcm mess with Pcmforless or dynotune
- cam/exhaust eith emissions
- how to reset PCM? dark soon help!
- Bad Alternator Cause Power Loss?
- hooking up rev. lights after auto to m-6 conversion?
- RPM drop
- where does this hose go
- Got a problem with car, need help!
- Pin length on camshaft
- New combo coming up...opinions?
- short catalytic converters ... ? length wise
- Ls1 brake conversion
- what wire for ACC on switch??
- steering shaft
- cheapest place to buy a radiator?
- what should i run
- tubes in slicks or not
- TB By Pass Question
- Motor will be out soon, what should I do while it is out?
- What causing a spun bearing?
- Whats wrong with my car??
- Everyone with longtubes, please read ...
- Shifter cable help
- Tps
- somethings screwed, what is it????
- EGR Malfunction??
- mechanic cant even figure out problem with my car
- rtv the oil pan
- 1994 z28 Build numbers
- Rich only in the rear cylinders
- Agostino Night Two
- Water pump removal...
- HELP! SS air filter part #
- Quick question about oil pan
- Stainless Works Y-pipe
- best heads out there....
- Has there been a recall for the Air Pump on the LT1?
- Agosino Nightmare One And Two
- What Will She Run?
- I want to do 1.6 rr amd springs but know nothing
- GM847 question...
- speedometer unacurate
- Update - Hesitation Fixed: Solution inside
- Too much oil?
- What should I run in 1/4
- Cheapest place for CC306????
- Cheapest Place For EGR Block Off Plates & AC Delco O2's?
- Universal X-Pipe
- LT1 optispark Usage
- How to get manifold AIR nut connections off
- Whats with my ride, my O2's or..
- Fuel line
- Oil Burning Smell
- Are Proform Billet Shifters good? I found a good deal on one.
- LT1 and Backpressure?
- tune up tips? Stock manifold
- water pump; please enlighten me?
- Sound Of Cut-0ut with Headers!
- Dumbest Mistakes Part II
- drove car after header install.....
- what if any gains from headers/gears over my setup??
- What rod to go with? 6inch or 5.7 on 355 rebuild?
- zz4 crank with 6 inch rod
- Oil all around intake gasket!
- Fastest Bolt-on LT1?
- LTCC plug wires. Where to buy?
- 93 guys, I need a favor
- First Mod: Intake or Exhaust?
- need a little help
- best Cams out there for LT1s today
- What is a good timing chain to use in a 396 LT1?
- Installing Autometer tach w/ MSD 6AL
- LT1 Engine Markings?
- Lt1 Problems!!?
- Engine WOrk
- I've got a CC306, what are the requirements?
- Shouldnt I be faster??
- Anybody got the trans-am parts manual???
- Would a slightly burnt wire.......
- I need a 92-93 IAC wiring schematic...
- what are the symptoms of a bad egr
- Crank hub install depth?
- You issue about Cam Changes causing problems?
- need valve cover breather suggestions...
- Got my times from the track, halarious!
- cam install
- Are fuel filters reverse thread
- What header bolts are everyone running with jet-hot lt's?
- 224/230 duration, .536"/.544", 112lsa
- Strange exhaust noise
- Getting Technical: Does OBDII sense the front O2 sensors more often than OBDI?
- CC306 cam question
- Who here has hit 400rwhp with just cam or h/c
- How to port 52mm
- car missing? startup..
- 84 corvette with lt1???
- Crankshaft sensor
- This cam with this set of heads?
- ASAP removing crankshaft pulley
- 383
- Can I fix my temp gauge or need a whole cluster?
- question bout gasket change
- Car acting weird??
- With TPIS LT Headers and no cats, what exhaust?
- sound advice
- How to wire in a shift light?
- What plugs to run?
- Loudmouth sounds like booty
- What does it mean to float a valve?
- Valve seal replacement
- Autometer elec F/P guage stoped working! HELP
- Oil leak at valve covers?
- Optispark problem - Imagine that - pic attached
- People cutting 1.4x 0-60ft inside Plz
- Open Loop
- Need pics of air pump solenoid mounting
- no/low oil pressure, help!!
- One rear caliper still won't compress all the way....
- breaking into delco-loc II?
- Shift Points
- Car acting up at the track.
- "Ram air" vs. Cold Air Intake
- Trick Flow LT1 heads are they any good!!!!!!!
- Where to get a 96-97 SS?
- timing set?
- oil pressure gauge or pump broken.......
- anyone using a ported 54mm TB?
- installing OPTI
- Solid Roller
- Pacesetter LT's
- Fun with a QTP valve!
- Moroso CAI fit a thirdgen engine bay using a stock LT1 elbow and MAF?
- Unusual ignition problem...
- LT1 tech
- Pacesetters
- opti/waterpump install complete :)
- Which oil pan to use with 396 stoker?
- Bad alternator?
- D@mn Crank Hub!!!
- Is something supposed to go here?
- Problems with cc305 cam install
- Whats the difference between 3.23 vs. 2.73 in 1/8 and 1/4 on a stock A4 car?
- Help with a couple of connections on a 1997
- Stumble off idle
- LS1 Stock Springs in LT1
- NU-TEK new website
- True Duals
- How much to have a Hotcam Kit installed???
- Car Problems
- car acting weird
- Can anyone tell me what valve springs I have?
- cant get E brake handle back on !
- 95\97 mac no cats
- Where to get header install stuff?
- Fuel Pressure???
- EBCM required for factory computer to operate?
- Help...tick..tick.. after cam install.
- Crank Shaft Sproket key!!!
- Where can I find a valve cover breather?
- Need '93 DTC list
- Another OPti Question
- LT1 starter
- Oil Leak After Head Re-install Wtf
- How to measure head to intake angle???
- whats harder???plz read
- Stock Air Box
- What would cause Timing Chain to Break Twice?
- pictures of stock rails with AN fittings??
- vacuum lines for a 95 z28
- HELP LT1 Temp Riseing and falling with throttle!!!!
- hypertech question
- Received my Jet-Hot Hooker shorties/Y-pipe
- help ...are my heads junk??
- What to look for?
- New Hot Cam times. (what to Improve)
- new times for LE heads / xe 224/230
- Looking to buy another 95z..
- Opti swap and cam question
- Hotcam tuning/gains
- 1994 Camaro Z28 little performance
- dance party at my garage! plug boot acting like a strobe light!
- callies racemaster crank??
- Exhaust Question
- awful 1/4mile times......getting slower
- Running Rich
- Cutout question?
- Thermostat question
- Budget 355
- keyless entry acting up/no key 4 locks???
- Hey guys i need some help...
- How To Tell If My Car Has 3 or 4 Channel ABS?
- how do you pull the oil pan safely, and fast
- Annoying Vibe That Needs Help!
- Open 3" CAI
- Stage 8 vs Breslin
- Question on Alternator plug
- How do these head flow numbers look?
- ss braided over rubber
- EGR not lining up.
- Missing... No Power,Coil,Opti
- What could do this?
- Need help =\
- Firehawk SZ50EP No longer avail?
- timing chain or fuel pump?
- Do Not Buy Other Ngk Plugs !!
- should i get this for my 94 firebird formula
- pic of stock LCA
- CC305 Sound clip?
- Why does my ABS light come on when I get on the gas?
- Just bought car-Running very bad! HELP!
- Back after a long time
- Where to set an Aeromotive regulator?
- Gear drives that sound like superchargers
- Moroso CAI Install ?
- Help Car "pulsing"!!!
- Timing chain
- Why shut off egr and air pump
- Exhaust exit in front of rear wheels?
- anyone got this?
- Lt1 Km
- Cooling Fan Switch Mod????
- -shoebox-
- Split BLMs and car wont idle right...
- O2 bung leaking
- Fuel rail shrader valve leaking
- This Possible?
