View Full Version : LT1 Based Engine Tech
- Will this valve spring be good enough for this cam...
- McLeod Dual Performance Clutch
- more bolt ons or heads???
- Lt4 heads??`
- Fuel Pump ? (MP3 sound inside)
- Ouch! my dyno sheet sux!!
- Oiling Filters
- Piston rings
- Best way to make 350-400 RWHP?
- Part # for Trans Am Fog Light Assembly?
- #5 & #7 plugs
- i need your .02
- TH400 converter choices
- cheapest place to get new o2 sensor?
- 96-97 SS owners, I need some help
- ABS ipon, low trac,Brake lights on.
- 95z28 with bose
- Oil Questions. Convert to Synthetics?
- Is the top speed lower for a auto than for a 6spd? LT1 or LS1?
- Stock ride height for a 4th gen?
- t56 to 700r4 swap
- a few questions for the experts
- what is causing this noise?
- What does a lifter going bad sound like?
- Paging Patman the oilman
- Did I tighten the top nut on my rear shocks too much?
- New dyno #'s
- Cylinder heads, Flow #'s and things you should know XPOST
- Racetronix, need directions on Plug and play harness...
- Synthetic or natural?
- Just put on subframes. What paint do I use for touch up?
- LS1 Lid to LT1 Questions
- Accel 300+ ignition any good?
- SlP shortys with a cutout...
- is a Comp Cams XR276HR-12 Xtreme a burley cam?
- LT1 replacement blocks, Shoebox & Injuneer
- Ltcc
- Buying A New Car
- Bib
- Difference between the Meziere and CSI wp?
- Burning smell?
- Just some questions I have on the new motor that's finally running(396)
- How mant quarts
- SS VIN NUmber
- remove harmonic bal?
- LT1 to LT4 Experts(NOT another conversion question)
- Injectors with Ford Logo on them
- is the tornado just bs?
- 1.6rr on daily driver.
- 93-95 z28
- lt1 SWAP ?S
- Coolant light please help!!
- Numbers possible with my setup....
- new pics!!
- brake lights don't work sorta.....
- need part #
- Need starter help ASAP!!!!
- Loudmouth vs Cutout
- Car wont start.. help...
- part throttle hesitation/misfire...specific
- What Kind of horse power can I expect.
- y pipe
- Is My Idle Right???
- mass air ?
- Checking RRs after install...
- new lingenfelter heads?
- just need verification if its the blinker bulb or not
- c5 vette wheel 5 spoke, newer style, who makes the.....
- Where to buy brand new lt1 shortblock? How much?
- roll bar
- Middle mileage LT1
- Explain This
- head porting
- Torque
- If I ever needed help now would be a great time!!!!
- Doing exhaust backwards
- Converter
- Throw out bearing wobbles a little, is thta my problem?
- Would this exhaust set up be possible?
- 16 inch mickey thompson sportsman pros
- Clutch problems???????? Help please
- Nu-Tek and Canton Oil Pan
- All bolt ons 12's?
- Best shocks for handling/cornering ??
- Rearend Damage?
- welding questions reguarding roll bars and jacks
- TH400 help...searched for hours :-(
- auto meter shift lite pills
- Keyless Entry
- 3:42's better over stock 3:23's in A4?
- E-Cutout before headers...A problem?
- CC 306, stock heads, hooker lts
- 1.7rr or headers?
- HELP!!!!!! wont start
- Slp Cold Air
- how much to port stock heads
- cheaper/best buy (cam)?
- Bolt size for Hooker LT's
- new track times what do you think
- Mystery Miss: Need help tracing this down
- RWHP From Headers
- Have trans out, how to tell if throw out bearing is bad?
- manual rack for 4th gen cars?
- Vac problem? Car doesnt run well after start
- Vibrates only in gear A4 :-(
- My new toy , LS1 trans Am
- Lowest Mileage LT1
- ANy non progressive 1" drop springs available?
- Crate Motor?
- phone # to combination motorsports??
- *Picture* Is this indeed a tranny cooler line?
- slp line lock kit
- need help please
- 1st gear chatter...... normal?
- Factory Alarm Keeps Going Off
- am i the only M6 driver that....
- what springs for 1.6 rockers with stock cam?
- Car has trouble starting cold...
- OBD1 to OBD2, I have a question about the Knock sensor
- top speed
- please help,,,z probs
- What tires???
- Speaking of gas mileage....strokers in here.
- STILL no power at low rpm's
- I need an oil pump / opti - where do I go?
- Replace struts?
- Screeching noise on start up after clutch install?
- Does sway bar install mess with alignment
- Changing O2 sensors
- Fuel Inejctors, Stock cat p/n, and dumb ??
- Gas Mileage Question
- How to properly break in a clutch?
- EGR block-off plate/s
- high resolution signal failure
- Deep sump pans.....
- Stroker guys. What weight oil do you use?
- Prothane Motor Mounts.....are these it????
- Correct Part Number?
- Guideplates go on top or bottom of stud?
- Hydra rev w/ LT4 km kit?
- rearend gear installed prices
- Do i need tuning for a cam and just a cam?
- speed density
- Spark plug wire R&R, now it won't idle???
- street tires as good as DR
- fair price
- passenger airbag cover???
- Did searches...Degreeing cam???
- Torquing Head Bolts????
- A4 won't reverse
- Bad wire symptoms
- Ge-tech results!!!!!
- Just changed my transmission oil for the first time, thanks guys
- sbc motor mounts compared to lt1
- Head milling
- $1000 dollar tune up
- Winterizing??Couple Questions
- Gas smell and high speed loss of power?
- Anyone use Castrol GTX high mileage formula
- Exhaust
- Installed Summit off-road y-pipe for 96-97 cars.
- Oil changing to dark brown 2 early
- Wires for LT1 with long tubes
- #1 cylinder not firing! (continued from other thread)
- 1993 Z28 VATS bypass? Please help.
- 50lb fuel injectors?? help
- Line lock on rear brakes
- Exasht Cut-out Question
- Guys with an FLP lv 4 inside
- ses
- Is my cooling system working now?
- wierd tranny rattles
- On a heads/cam application will a 1 step colder plug hurt?
- Oil pressure surges and sometimes drops to 0 at idle in gear.
- What states have emission testing??
- everyone sign this autobahn
- Rocker/timingchain/spring suggestion...
- Smoking starter - anybody had this happen?
- Cam Kits
- Horrible Miss???
- Anyone know PN for Opti-elimination cover?
- Scanmaster connections
- rebuild Question
- Does anyone have cutouts after the headers?
- What is on the Side of the heads
- Quick help needed LT4 STARTER
- who uses transgo
- Failed Emissions...again....
- 500hp N/A All bore no stroke?
- STOCK Valve SPRINGS with New CAM OK??
- *Wierd* hesitation/miss/stumble come inside->
- Any write-ups on R&R Heater Core?
- Adjusting roller rocker uncertainties
- Meizere WP users, where did you hook your positive line?
- FLP or Hooker Longtubes
- Anyone have stock 96 head flow numbers?
- Orange or Green Coolant for 95 T/A?
- lifter replacement
- SIMPLE location needed
- LT headers and emmisions?
- Manual tranny fluid reservoir question?
- cam advice please
- finally ran in the 1/4ml
- How hard to take Double Springs off while heads are on?
- car dies
- Jet Hot LT's, question on header bolts and dyno/track gains
- Totally confused. What does this mean?
- 383 Plan...need suggestions..
- Headers/Y-pipe burning and melting through parts of engine wiring harness
- Correct o2 sensor?
- Driveshaft u-joint size?
- g-tech pro-competition QUESTION!!!!
- bad maf?
- Corvette starter in F-body?
- Check my valvetrain parts list...
- Boxed vs. Tubular suspension parts
- My water-proof opti died :(
- Anybody have a part number for a alternator?
- broken lifter
- Who has the best headers? BBK, AS&M, SLP??
- Did clutch install...Still a problem.
- New ignition switch,still no dash lights,fuel pump,no turning my Z28 on! HELP! (LONG)
- Making stock LCA's better...Would this work?
- Knock Diagnosis
- In car Piston Ring Replacement
- Question about LT headers?
- iRotors ???
- How good is the 306 on spray?
- Anyone hear form Brian@ PCMfor less?
- somebody clarify this maf nonsense for me
- which coating?
- Too many miles for a stall?
- checked my fuel pressure, ?
- What kinda water to MiX w/ DexCool?
- How cool is TOO COOL?
- When does going bigger with a TB become effective?
- Can someone explan to me the 2 types of Firehawk suspension?
- Do I really need to get a coated Y-pipe for the LT's?
- No heat
- Dyno tunning a 93?
- Filler neck?
- stock rocker help needed asap
- e.t guestimates???
- Where can i find an engine/tranny/wiring/ECU combo for cheap?
- How do u know what Coil to choose
- is this for a 93-97
- Converting MAP readings to vacuum
- What is good brand for true dual exhaust?
- Do I have to remove my supercharger to install my cam???
- How do you calc. intake port volume
