View Full Version : LT1 Based Engine Tech
- M6er's help needed
- Mailorder tunes???
- ? about flowmaster super 40 series
- 227- 227 112 lobe?
- Electric water pump Q's
- show me your QTE Cutout pics
- Which air filter.. Please read
- Rough Idle and backfiring (bad opti?)
- Need LT1 help ASAP
- Stupid 95 LT1 camaro................
- Need your opinion on heads...
- Just got my Headers Installed
- Custom cam HELP!!!
- Sounds like raocks banging around between 1000 and 2200 rpm...???
- Plugs/Wires? Other tune-up stuff?
- Stripped Thread
- mechanical speedo w/ 4L60e
- Is it possible Im blowing the spark out?
- Motor won't start.
- Hesitation problem
- tranny gone bad help plz
- I want to build a LT1 383...
- Adjusting Valves on a Hotcam Kit???
- Stock Heads, BRE Custom Cam
- Car takes a while to come down to normal idle
- A Series of Problems
- Clutch Chatter?
- What would YOU install first?
- Differential part #
- stock fuel pump
- 383, 6 inch rod, 224/230... clearance issues.
- Temp question
- Jet Hot LT install done
- Any have a RPG to shoot at my car?? (long)
- LT1 guys, is there an O-ring on your dipstick?
- Front and rear sway bars. What size to get?
- Pst Front End Rebuild Kit!
- Fuel Pressure check guage
- A couple fresh rebuild questions?
- Anyone running a SB Carburated Engine?
- backfires like hell... wont go over 3k RPM
- Rattling / squeaking from console
- crane enrgizer
- Computer tuning
- Norm for Coolant Temp?
- car starts, idles for 10 seconds, backfires, then dies
- High Flow Fuel Pump....
- can I use my hypertech with hot cam??
- Hypertech Programmer HELP!
- Buying a Delteq
- Valve timing
- Ok Now I really need help, Im overheating like crazy
- How do i remove the instrument cluster on my 95 TA fora white face gauge install???
- ECT Sensors - Quick Question
- how to get out a messed up head bolt
- Are we sure a vented opti works on a 94?
- LT1 Dave from lt1dave.com
- figure this one out
- oil pump driveshaft?
- Open Thermostat
- what to do with 383??
- taction control question!
- What should I expect for times?
- Cooling Question
- Ho2s
- Stock fuel pump question
- Any Wisconsinites want to help install LT's!
- Racenet Stage II heads?
- How do I know if this is really a LT4 shortblock?
- homemade CAI - heat shield
- Tourqe Converter Upgrade
- Headed To The Track!! Predictions???
- Just ordered my true dual setup, what do you guys think, to quiet?
- Poly/Rubber LCA
- Shoebox, Brake Problem Question
- Alternative induction to CAI and Ram Air?
- Can someone verify the Injector settings for me
- Coolant Leak - What's leaking?
- Need help finding spring seats
- best timing chain upgrade?
- Coolant light has come on...now wont go off!
- Threaded rod for camshaft install
- SVO injector swap
- Fireball ?
- WoW, a coil change more of an improvement than an optispark change!
- adjustable suspension
- P/N for oil dipstick ??
- Starter probs w/ trunk mounted battery
- Best Performance for less than $300
- broken spring screwed up everything...
- bad braking
- Just got 224/230 - the dowel pin is in too far...
- Will the included suspension mods really help 1/4 mile times?
- Can this be done?
- where to buy KB pistons
- FP 40PSI idle 35 revved
- weird noise in left rear on hard acceleration
- Speedo keeps dying
- oil pressure?
- DMH Electric cutouts - a few questions
- Rock Block after machining?
- slick tires selection
- PCM comp. for fuel pressure changes
- LCA/suspension help
- cags ?
- Quick Plug Coloring Question
- 2ND Shot Pacesetters VS. Jet-Hots
- Replacing Opti @ 90K, Need Coil Too???
- Leaking Coolant Hose
- exhaust leak
- Oil SLP CAI filters?
- Delteq question
- car runs lean
- Prothane compared to energy suspension tranny mounts
- How do you know if you need o2 sensors?
- Best place to put cut out??
- Water in the oil
- Guy who sold homemade CAI?
- ZO6 MAF Question
- Ticking noise.
- 95 Z-28 proportioning valve ??
- young mechanic, need help with Z
- Compression Test vs Leak Down Test
- good rockers?
- LT1 cars in the snow???
- My LT1 block has 4-bolt mains
- Shaking at high speed.
- car won't start need help looking for shoebox input please help
- Who makes a 383 Windage tray?
- Electric waterpump light
- H+C nightmare
- quick silly questions regarding 1.6 rockers
- Need the best price on a set of injectors, Finally diagnosed my "missfire"
- Where are you guys shifting with your XE 224/230 cams?
- Affordable True Dual Setup
- Drove a Black 97 SS
- Car wont start, and when does, wont stay running..
- Aluminum vs steel Flywheel
- LT4 extreme timing swap
- LT1 vs LT4 starter
- Will a 96' lt4 shortblock work in a 95lt1?
- Opti Problem
- 96 97 4L60E Differences ?????
- EGR Crap!
- Here I come Z28! Old Engine.
- Canfield Heads????
- Starting Problem
- LT's coated/non-coated??
- how much for an engine rebuild?
- Camaro Wont Turn OVER!!!
- Vortech Aluminum Intake Elbow can you use a air foil with it
- new lifters necessary w/ cam install ??
- how much to install long tubes?
- optispark 4 wire connector
- Hard stop = No Oil pressure
- R.I.P to my Baby I owe it this much....
- track times for new setup!
- Can new gears affect Opti?
- Proper Use of Fuel Pump Prime Connector
- Guys with AFR heads, recmd. on plugs
- What Aftermarket radiator are you using?
- Jet-Hot LT owners, sealing the slip fitting?
- check engine light
- Will I need a tune???
- what ET gain with these mods?
- Help can't get car started and I have tried everything I can think of
- car randomly dies?
- car is having starter problems help!
- Extreme Vibration problem
- Car shakes at idle, rattle in dash, "flutter" during light throttle
- Knock Modules
- So I blow all my antifreeze on the road today.
- Luck with street tires at the track?
- 355 Shortblock
- aeromotive AFPR vacuum line
- Random Low Oil Light, question about sensor in pan
- anyone try a "chambermouth" or a dynomouth?
- hooker ypipe, who has it in stock?
- Where to buy LT4 Starter?
- Another very satisfied MadWolf tuning customer!
- LS1 Style intake?
- Car still backfires?
- Valve springs for cc306
- Lloyd E. heads/Nu-Tek SB Dyno #'s inside
- Pacesetter LTs to X pipe, would I use a clamp like this?
- Electrical Component connected to drivers side AIR tube HELP!!
- what can i expect with this
- How many people had to Dent in driver side floor pan when installing Jet Hot LTs?
- Smells like burning coolant.....but where?
- Buy heads or port and polish??
- Lt's and Emissions
- Will a traditional oil pan work on an lt1?
- akm or mastach obd1 cable?
- installing electric gauges
- Screws used in the coil bracket
- oxygen sensor simulators and smog/ses
- will these rockers work with stock valve covers?
- Rod knock, need info on a new shortblock
- Can I use the stock balancer with a 383 stroker?
- Looking at a Z
- small base circle cam???
- Am I Making a big mistake
- Very quick question about CSI pump
- What do you have to do to get rid of traction control?
- car sounds ready for take off?
- Shift Skip Elim. resistor and exhaust measurments
- having trouble please help!
- Cam components
- Just changed distributor...
- Went to the track last night
- check valve adapters
- Air pump delete plug sizes..
- Need header plugs for AIR tube holes
- Anyone in here ever throw a rod?
- What happenes with an open EGR?
- What Will it take to keep up with my cuz's 2000 T/A
- What is Needed to run
- Name that sensor
- Thank you and farewell...
- Flatlander racing... reasonable shipping & reliability?
- intakes
- What should my idle be set to for a GM 847 cam?
- Possible header leak?
- Traction control-what do you do with the 3 brake lines.
- Are there front oil galley plugs? (Car makes no pressure)
- How do LT1s sound with LTs ORY @ Catback?
- PCM For Less help a stockish car?
- Hesitation Problem
- Compression Stroke
- Worthwhile to grind/polish oil return holes?
- Help Idling Probs!
- Spray or No spray
- heat range of plugs
- Does anyone know the size of the EGR studs?
- Damn wires are arcing again.
- JET fan switch and SLP headers???
- My injector ohms readings
- 32lb injectors and stock fuel pump???
- Need part # for NGK TR55s
- Overheating (groundeffects)??
- Torque wrench for water pump install?
- 97 LT1 into a 89 bird
- Fan problems
- Loudmouth clip....sounds bad but gets the point across
- 396 kit
- Flashing SES after plugs/wires changed
- Edelbrock vs trickflow
- who makes th optispark block off plate
- fram air filters?
- BUYING SHOTBLOCK Is this a good Deal guys? Come let me know:
