View Full Version : LT1 Based Engine Tech
- Sounds like marbles in the trans case??
- Falken GR Beta FK-451
- Timing gears?
- Quick help needed, car won't start
- Unregulated Fuel Pressure??
- Looking for a clutch part.
- Porting heads by yourself?
- Fuel pressure question.
- Tornado performance
- HOT Cam folks, How loud are your Rockers??
- AC will not blow???
- stock fuel system till???
- MAC hi-flow cat and 3" i-pipe? hiflow cat owners inside please
- How hard is it to remove the front sway bar?
- Lt1
- theoretically..
- Hard start and stumbling problems, please help
- OBDII Programming Released.
- Pice of crap tranney...........
- Radiator Fill Runthrough, (need someone to read through this)
- ATI mod
- car crapped up on dyno....need help
- Weep hole tube?
- K-member bent! Where to get new one?
- Car wont start
- Leaking tranny
- Car wont Start!!!
- Lean condition with new Cam?
- finally completed v6-lt1 swap
- 160* stat... worth the install?
- Quick SES question
- Brodix-headed monster came to life!
- How much hose do i need w/tranny cooler?
- Got a problem with a Z28 at a friends speed shop. Need your opions
- Opinions on Nitto 555 Extreme
- Anyone ever replace a window REGULATOR or sping before??
- Where can I find fittings for a Rad?
- How can I calculate what spring height I need for my new cam?
- Do lifter need to be "pumped up" when setting valve lash?
- Putting a used engine in anything I should do....
- Check out my airbox...
- Anyone got pics of welds or centerlines on their cars?
- where do I buy seafoam from???
- Buying a camaro, bit of help
- Having a hard time getting cam dowl out????
- If I block off the EGR on the intake...will I pass emissions?
- anyone who knows about o2 extensions and simms please help
- anyone with true duals please help
- T-56 gurus please come in and help me out......
- Can I use this block?
- Movie - XE230/236 cam & GMMG Idle
- Fuel Pressure low
- Serious Help - Rebuilding My Engine!
- Low top end power, rough idle
- Plugs and Wires
- Hypertech PP3 Deprogramming?
- Car died on way home today! Help.
- Pulling My Lt1
- Free mods for C4's??
- Manifold leak(?)
- Performance Trans Mode
- Guys who port heads
- performance shift button stuck?
- How to install Taylor Opti ends on Accel wires???
- BFG Drag radials- What PSI on the street??
- Turn motor half a revolution then stops, whats up?
- MAGNAFLOW exhaust systems. Comments Fellas...
- Car Is Acting Crazy!!!
- OMG HELP, this is really bad. A4 Trans Related.
- Rear hatch rattle, help!
- Jason Cromer's Contact Info
- Accel Ignition Questions
- HELP 95+ opti harness into main elec. harness problem????
- What fuel system upgrades will i need? (if any)
- Can you make 94 opti harness work on vented opti?
- URGENT: Tire suggestions needed ASAP
- Who is running a billet material cam with a factory oil pump drive gear?
- Rubbing noise when driving slow
- Gasket for MAP?
- Drive shaft
- PCM/Wiring Harness/Engine what goes where
- LT1 intake block change
- Fuel Pressure Gauge help
- tire size
- those who know there automotive wiring please help
- gas smell question...
- Big problem! Did I fry my TPS!?
- oops... now what was this grinding noise?
- idle relearning
- who converts heads to reverse flow? Head Porters Please enter!
- Looking for diagram or pic of exactly where vacuum lines go for OPTI
- any body tried a nascar select ignition coil ????
- So who else has rust on their Jet-Hot coated headers?
- Difference between F41 sport and FE2 touring suspension.
- Will Jet-Hot long tubes work?
- lt1 vs ls1
- Hard Time Shifting at 5,000+ RPM
- NEW LT1 products from Summit Racing
- Jet-hot/Hooker LT guys inside please
- leave my heads alone or not?
- pcm prog-VATS??
- Tranny
- Got a bunch of free 12 bolts... now what
- Headliner woes- need new or redo?
- what fuel pump to get
- im new here, need opinions please!
- How wet can the opti get?
- LT1 MAF Sensor..GO or NO!?!?!?!
- CMMG style exhaust question
- Passenger Headers
- Rear Main Seal
- 3.73 Install
- TH350 conversion: speedo signal hookup
- Fuel
- Waterpump weeping: replace pump+opti+timing chain?
- Quick Dumb Question.......
- will 2.05 1.60 fit in stock lt1 heads??
- How to bold Motor Mount
- I need new Exhaust Manifold Bolts, what size????
- what year had the most power for LT1
- 97 gauge cluster
- Replace oil pan gasket with cam swap??
- Jet Hot Headers
- Still confused about Royal Purple in M6
- What does it take to get into the 11's
- What kind of wheel balancing weight on chrome?
- pro 5.0 shifter dust boot question
- Ordered a billet cam from comp cams, need a bronze oil pump gear drive!
- Solid roller too aggresive for stock PCM and stock bottom end?
- doing a tune up
- the black dot on the left
- iac dead?
- New Times on 224/230 XE
- Dont really know where to put this....
- Surges during Accelation between 2k-3k Rpm
- Help With Cam Swap Please?
- What is the motor mount
- cam 4 n2o
- Damn LT1..... Hardcore Stubleing and Not running right! PLease need help bad!!!
- dowel pin?
- wtf... all my gauges are off
- Best Replacement Transmission for 96Z?
- Question about too much oil on the engine
- Do you have to cut the wires from your 02 sensor??
- A/C not working????
- whats a good rpm for idle?
- crane gold 1.6 roller rockers ?
- Trans Am door ??
- Where to buy LT1 Edit?
- what is needed to swap 94 rearend into 97?
- Most affordable place for 12 bolt
- Where can i get 315's?
- Best place to mount Trans Cooler.
- Which one of these LT1's should I get?
- 94-95 headers on a 97???A few ?'s
- Is there a site on taking out engine and installing new crate engine?
- Is there a company that makes a bronze gear for the oil pump drive, that actually fit
- Guys w/Hooker shorties come on in.
- HELP...car stumbles low RPM's
- Hey Shoebox, update inside
- Edelbrock T.E.S. Headers?
- ? about Roller Rockers
- ET for 108.44 trap speed
- Has anyone had a Comp Cam dowel too long for a vented opti?
- true duals
- Help I am idling at 1200rpms
- lt1 recall ????????
- sounds like im turboed...but i'm not...
- No clutch pedal after tranny install
- What is this code trying to tell me?
- Hmm does this really give the gains it promises????
- Got my 1LE elbow, questions??
- ripped oil pan gasket
- slp shorties
- Throttle body airfoil for LT1???
- Is it a bad optispark??
- Suspension tunning???
- whats the best rear end for the buck?
- quick question
- Horn Problems
- cat making funny noises
- 1.6rr with stock springs debate
- Drove Without Maf!!!!
- What will the nittos take first??
- how to remove fuel from the tank?
- disadvantages of taller tires ?
- Need quick help!!!!!!!!!
- How to install 02 sensors?
- Bigger Valvesprings from the CCA-986-16
- Stinky air vents - help Im dying
- header wrap.. in a different place
- need advice on putting my new AC compressor on
- Need Help, Getting the Fuel Lines Off
- Orientation of flywheel / TDC????
- obd 2 codes
- Please Help: Convertible True duals
- Changing gears need info
- Part # for (front) PFC brake pads. ..
- Best underdrive pulley?
- have you guys ever heard of zMAX?
- part number for passenger side wheel hub
- Please help ! $600 later and the same problem is still there...
- Can I just put water in the radiator?
- plugs arching
- Gas coming out of gas cap
- How to disable THEIFTLOCK ON RADIO?????
- Replace Dual cats on a 96?
- Engine light coming on in 6th gear, any idea what's wrong?
- Fuel pump recommendation
- found some pics of my welded intake
- MAC Headers are owning Me....
- need quick answer...pressure test related.
- Please HELP! I'm Lost. All TECH Guys Inside!
- All Valentine One owners come inside.
- NO EGR on a 97???
- headers
- How much would I gain with LT & X-Pipe and bullet mufflers
- Source for Longer Wheel Studs
- Why isnt my #1 exhaust lifter compressing?
- Bad Feeling....
- I'm about to kill my car!
- Stero Wiring Diagram for 1997 Camaro
- trying to track down coolant leak..
- Guys runnin 12's inside.
- CC 1.6 RR set screw backed out at high rpm! 2x!
- HORN problem...of all things
- exhaust leak in rear how do i find it??
- Jet Hot vs Hooker LT headers
- Remove EGR
- wiring help asap!!
- 383 stroker components
- What am I doing wrong?(intake leak related)
- how can I get to the radiator reservoir tank?
- Efect of more lift on Emissions?
- volt gauge takes about 30 seconds to come up after startup ?!
- Ignition Question - 97 LT1
- Cobination Motorsports Heads/Cam packages
- Vortech elbow installed!
- couple rebuild questions
- TB bypass=broke engine?
- Ceramic coating on ypipe Gone!
- How much and where to cut exhaust?
- P0336 Random Mult. Missfires
- Anybody ever install a 95+ LT1 into a 93 Camaro?
- Grinding/rubbing with front suspension travel-What is it?
- jet-hot long tube guys inside, NOW
- help need pilot bushing part # for 96 ta
- Opti wiring harness connector questions
- Fuel injector size.......How is this figured??
